Stovent
Segmentation fault while controlling GPIO in assembly
Mon Nov 19, 2018 10:04 pm
Hi all
I'm trying to control the GPIO in assembly. After a quick look at the ARM peripherals documentation, I wrote this program :
.globl _start
_start:
	LDR r0, =0x20200000
	MOV r1, #0x200000
	STR r1, [r0, #4]
	MOV r1, #0x20000
	STR r1, [r0, #0x1C]
loop:
	B loop
However, I have a segmentation fault when executing the first STR (STR r1, [r0, #4])
Could someone explain me what I'm doing wrong please ?
Thanks,
Stovent
rst
Re: Segmentation fault while controlling GPIO in assembly
Wed Nov 21, 2018 2:43 pm
I guess, your code is running on Linux, because you wouldn't get a segmentation fault otherwise. You have to map the GPIO address space into the address space of your process to be able to access it, first. There is a mmap system call, with which you can do this mapping. I have only done this using C so far, so I do not have an assembly code snippet by hand and this would belong into the C / C++ programming forum.
Stovent
Fri Nov 23, 2018 11:18 pm
Using mmap fixed the problem, thanks.
I ended doing it in C because I couldn't find any documentation on system calls parameters in ARM .
rst
Sun Nov 25, 2018 9:48 am
Because I was interested in how system calls are implemented in Linux on ARM, I figured this out now. Here is a simple assembly program, which shows how to get access to the GPIOs:
	.text
	.globl	_start
_start:
	ldr	r0, =gpiomem
	ldr	r1, =0x101002	/* O_RDWR | O_SYNC */
	mov	r7, #5		/* open */
	svc	#0
	mov	r4, r0		/* file descriptor */
	mov	r0, #0		/* kernel chooses address */
	mov	r1, #4096	/* map size */
	mov	r2, #3		/* PROT_READ | PROT_WRITE */
	mov	r3, #1		/* MAP_SHARED */
	mov	r5, #0		/* offset */
	mov	r7, #192	/* mmap2 */
	svc	#0
	/* access GPIOs via r0 */
	ldr	r1, [r0, #0x34]	/* read GPLEV0 */
	mov	r0, #0		/* return code */
	mov	r7, #248	/* exit */
	svc	#0
	.data
gpiomem: .asciz	"/dev/gpiomem"
jahboater
Sun Nov 25, 2018 9:54 am
You can do inline system calls in C with:-
 *  Get the terminal (window) size.
 *  Return non-zero if not a terminal.
static int
screen_size( const int fd, struct winsize * const buf )
  register int rc reg( "w0" ) = fd,
               w1 reg( "w1" ) = TIOCGWINSZ,
               nr reg( "w8" ) = SYS_ioctl;
  register struct winsize *x2 reg( "x2" ) = buf;
  asm( "svc 0" : "+r" (rc) : "r" (nr), "r" (w1), "r" (x2) : "memory" );
  return rc;
Its much easier on x86 because you have named registers in the constraints.
rst
Sun Nov 25, 2018 10:24 am
Yes, but the intention here was to do it with bare assembly language. Normally one would probably do this from C by simply calling open() and mmap().
