tribes
How to handle a simple IRQ via QEMU
Fri Nov 11, 2016 3:01 pm
I have been trying to handle a simple IRQ from the emulated RPI 2 with QEMU but wasn't successful :/
Here is my commented code: http://lpaste.net/586201347288727552
Let me explain roughly what I do:
- Put my interrupt table at 0x00
- Set up the interrupt stack
- Handle the interrupt, save the state, print a Hello IRQ, then return to the previous state
On the C side all I do is printing a "Hello world" on the serial port then run a simple loop
My IRQ handler is supposed to print "Hello IRQ" the same way "Hello world" is printed
Anyone seeing an error or have any idea of what could go wrong ?
Thanks,
Tribes
Ultibo
Re: How to handle a simple IRQ via QEMU
Sun Nov 13, 2016 4:58 am
tribes wrote:Anyone seeing an error or have any idea of what could go wrong ?
Just a thought, are you sure the variation of LDM you are using in irq_interrupt_handler is correct for an exception return?
According to the "ARM® Architecture Reference Manual ARM®v7-A and ARM®v7-R" section B6.1.2 the LDM (exception return) can have a mode of DA, DB, IA, IB but it doesn't list FD. If you are not using the exception return version of the LDM instruction then it will return to the location in LR without restoring CPSR from SPSR and therefore not return to the original mode.
Ultibo.org | Make something amazing
https://ultibo.org
Threads, multi-core, OpenGL, Camera, FAT, NTFS, TCP/IP, USB and more in 3MB with 2 second boot!
tribes
Tue Nov 15, 2016 7:19 pm
Hi Ultibo,
Ultibo wrote:If you are not using the exception return version of the LDM instruction then it will return to the location in LR without restoring CPSR from SPSR and therefore not return to the original mode.
ARM System Developer's Guide wrote: The ^ at the end of the LDMFD instruction means that the cpsr will be restored from the spsr, which is only valid if the pc is loaded at the same time.
Tribes
AlfredJingle
Wed Nov 16, 2016 9:05 am
In my irq handling routine I do the following different from you:
		stmfd r13!, {r0-r12, lr}	@ no need to save sp -  r13=IRQ stack, to be set at system init.
		@ here I do the actual irq actions and enabling and disabling of the irq and what have you not
		ldmfd r13!, {r0-r12, lr}
		subs pc, lr, #4            @ return from irq
Works for me.
going from a 6502 on an Oric-1 to an ARMv8 is quite a big step...
