zyte
RPI 3 SD Card
Fri Oct 14, 2016 2:22 pm
Has anyone had any luck with accessing the SD card on a RPI 3 - I just seem to get junk back - am i missing something?
Ultibo
Re: RPI 3 SD Card
Sun Oct 16, 2016 12:19 am
zyte wrote:Has anyone had any luck with accessing the SD card on a RPI 3
I can't comment on the results of others but I know that for the Ultibo project (https://github.com/ultibohub/Core) exactly the same code works for accessing the SD card on RPi, RPi2 and RPi3.
zyte wrote:I just seem to get junk back
Maybe if you could provide an example of the code which returns junk someone might be able to offer more suggestions.
Ultibo.org | Make something amazing
https://ultibo.org
Threads, multi-core, OpenGL, Camera, FAT, NTFS, TCP/IP, USB and more in 3MB with 2 second boot!
zyte
Re: RPI 3 SD Card
Sun Oct 16, 2016 1:23 pm
Ultibo - thank you so much for your response, it clarified what I thought - i.e. that RPI 3 was the same and RPI 2 regarding SD access - spent some time going through the code and wouldn't-ya-know couple of incorrect shifts were causing all my errors.
Thanks again for the clarification.
