slow_death
print char to screen
Thu Aug 09, 2012 1:58 am
Does anyone have any sugestions on were to begin just standard i/o to the screen - with the video
or hdmi? just print a char.. ?
jackokring
Contact: ICQ
Re: print char to screen
Thu Aug 09, 2012 2:58 am
after logging in
echo "my favourite words"
Cheers Jacko
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
slow_death
Thu Aug 09, 2012 4:44 am
are u referring to the command line in Linux..
to print to screen there should be an address or method to gain access..
an example would be vga..
in a lower level arm or c...
is there a set mode? for text io versus graphics?
tufty
Thu Aug 09, 2012 6:04 am
You'll need a framebuffer driver, blitting code and a bitmap font. In short, you need to do it all yourself, and no, there is no 'text mode'.
Cycl0ne
Thu Aug 09, 2012 9:05 am
as tufty said, you need some basic graphic routines. i can post some here in about 2-3 weeks when im finished. still fiddling with some layered graphics.
romell
Thu Aug 09, 2012 11:29 am
Do you have anything running in bare metal at the moment? Otherwise I suggest that you first look at this: http://www.raspberrypi.org/phpBB3/viewt ... 72&t=10850 thread to get you started.
Then you need to set up a framebuffer according to the specs here: https://github.com/raspberrypi/firmware/wiki/Mailboxes. You can choose if you want to do it via the framebuffer channel (1) or the property tags channel (8). The first is probably easier, but the latter is the currently supported method.
When you have the framebuffer set up, you have to manually plot your characters from for example a bitmap font.
Good luck :)
Cycl0ne
Thu Aug 09, 2012 12:48 pm
Code says more than 1000words ;)
Here the mailbox "things":
#define BCM2708_PERI_BASE                 0x20000000
#define GPUCORE_MAILBOX                   (BCM2708_PERI_BASE + 0xB880)
#define GPUCORE_MAILBOX_READ_REGISTER     0x00
#define GPUCORE_MAILBOX_WRITE_REGISTER    0x20
#define GPUCORE_MAILBOX_STATUS_REGISTER   0x18
#define GPUCORE_MAILBOX_CONFIG_REGISTER   0x1C
struct DriverBase
	struct bcm2835framebuffer	fb;
	APTR						memory;
	APTR						GfxBase;
struct bcm2835framebuffer {
   unsigned int width;        // width in pixels
   unsigned int height;       // height in pixels
   unsigned int vwidth;       // == width
   unsigned int vheight;      // == height
   unsigned int pitch;        // set by GPU
   unsigned int depth;        // == 24
   unsigned int x;            // == 0 (offset)
   unsigned int y;            // == 0 (offset)
   unsigned int fbaddr;       // set by GPU
   unsigned int fbsize;       // set by GPU
typedef struct vc_mailbox_tag {
   unsigned int id;
   unsigned int value_buffer_size;
   union {
      struct {
         unsigned int value_length  : 31;
         unsigned int type          : 1;     // 0 = request, 1 = response
      } bits;
      unsigned int word;
   } ctrl;
   VUINT32 value_buffer;     // The first (of possibly many) values
   unsigned int value_buffer2;     // The first (of possibly many) values
} vc_mailbox_tag;
typedef struct vc_mailbox_hdr {
   unsigned int size;            // Size in bytes including header, end tag and padding
   unsigned int type;            // requests: 0x0 = process request, responses: 0x80000000 = success, 0x80000001 = error
} vc_mailbox_hdr;
typedef struct vc_mailbox_ftr {
   unsigned int end_tag;         // always 0x00000000
   unsigned char padding;
} vc_mailbox_ftr;
unsigned int read_mm_reg32(unsigned int base, unsigned int reg) {
   memory_barrier(); //Make sure we read the right thing
   return *(volatile unsigned int *)(base + reg);
void write_mm_reg32(unsigned int base, unsigned int reg, unsigned int value) {
   *(volatile unsigned int *)(base + reg) = value;
   memory_barrier(); //Make sure the write is visible elsewhere (see ReadMmReg32 for note on how necessary this is)
void mbox_write_gen(unsigned int channel, unsigned int v)
   while (read_mm_reg32(GPUCORE_MAILBOX, GPUCORE_MAILBOX_STATUS_REGISTER) & MAILBOX_STATUS_FULL);
   write_mm_reg32(GPUCORE_MAILBOX, GPUCORE_MAILBOX_WRITE_REGISTER, channel | (v & 0xFFFFFFF0));
unsigned int mbox_read_gen(unsigned int channel)
  unsigned int r = 0;
   do {
      while (read_mm_reg32(GPUCORE_MAILBOX, GPUCORE_MAILBOX_STATUS_REGISTER) & MAILBOX_STATUS_EMPTY); //wait for data
      r = read_mm_reg32(GPUCORE_MAILBOX, GPUCORE_MAILBOX_READ_REGISTER); //Read the data
   } while ((r & 0xF) != channel); //Loop until we received something from the frame buffer channel
   return r & 0xFFFFFFF0;
unsigned int arm_to_vc(void *p) {
   return ((unsigned int)p) + 0x40000000;
void *vc_to_arm(unsigned int p) {
   return (void *)(p - 0x40000000);
and here the initialisation of the videocore:
UINT8 *OpenDriver(struct DriverBase *dbase, UINT32 size_x, UINT32 size_y, UINT32 bpp)
	struct GfxBase *GfxBase = dbase->GfxBase;
	unsigned int buffer_size = sizeof(vc_mailbox_hdr) + sizeof(vc_mailbox_ftr) + (sizeof(vc_mailbox_tag)*7) + 16;
	APTR memory = (unsigned char *)AllocVec(buffer_size, MEMF_CLEAR|MEMF_FAST);
	unsigned char *vc_mailbox_buf = (UINT8*) ALIGN(memory);
	unsigned int response;
	DPrintF("memory: %x size: %d\n", vc_mailbox_buf, buffer_size);
	vc_mailbox_hdr *hdr  = (vc_mailbox_hdr *)vc_mailbox_buf;
	vc_mailbox_tag *tag1 = (vc_mailbox_tag *)(((UINT8*) hdr) + sizeof(vc_mailbox_hdr));
	vc_mailbox_tag *tag2 = (vc_mailbox_tag *)(((UINT8*) tag1) + sizeof(vc_mailbox_tag));
	vc_mailbox_tag *tag3 = (vc_mailbox_tag *)(((UINT8*) tag2) + sizeof(vc_mailbox_tag));
	vc_mailbox_tag *tag4 = (vc_mailbox_tag *)(((UINT8*) tag3) + sizeof(vc_mailbox_tag));
	vc_mailbox_tag *tag5 = (vc_mailbox_tag *)(((UINT8*) tag4) + sizeof(vc_mailbox_tag));
	vc_mailbox_tag *tag6 = (vc_mailbox_tag *)(((UINT8*) tag5) + sizeof(vc_mailbox_tag));
	vc_mailbox_tag *tag7 = (vc_mailbox_tag *)(((UINT8*) tag6) + sizeof(vc_mailbox_tag));
	vc_mailbox_ftr *ftr  = (vc_mailbox_ftr *)(((UINT8*) tag7) + sizeof(vc_mailbox_tag));
	DPrintF("Tag: %x %d\n", tag1, sizeof(vc_mailbox_tag));
	DPrintF("Tag: %x\n", tag2);
	DPrintF("Tag: %x\n", tag3);
	DPrintF("Tag: %x\n", tag4);
	DPrintF("Tag: %x\n", tag5);
	DPrintF("Tag: %x\n", tag6);
	DPrintF("Tag: %x\n", tag7);
	hdr->size = buffer_size;
	hdr->type = VCBUF_PROCESS_REQUEST;
	ftr->end_tag = 0x00000000;
	tag1->id = VCTAG_SET_BPP; // VCTAG_GET_FIRMWARE_VERSION;
	tag1->value_buffer_size = sizeof(unsigned int)*2;
	tag1->ctrl.bits.value_length = 0;
	tag1->ctrl.bits.type = VCTAG_REQUEST;
	tag1->value_buffer = bpp;
	tag1->value_buffer2 = 0;
	tag2->id = VCTAG_SET_PHYS_WIDTHHEIGHT;
	tag2->value_buffer_size = sizeof(unsigned int)*2;
	tag2->ctrl.bits.value_length = 0;
	tag2->ctrl.bits.type = VCTAG_REQUEST;
	tag2->value_buffer = size_x;
	tag2->value_buffer2 = size_y;
	tag3->id = VCTAG_SET_VIRT_WIDTHHEIGHT;
	tag3->value_buffer_size = sizeof(unsigned int)*2;
	tag3->ctrl.bits.value_length = 0;
	tag3->ctrl.bits.type = VCTAG_REQUEST;
	tag3->value_buffer = size_x;
	tag3->value_buffer2 = size_y;
	tag4->id = VCTAG_SET_ALPHA;
	tag4->value_buffer_size = sizeof(unsigned int)*2;
	tag4->ctrl.bits.value_length = 0;
	tag4->ctrl.bits.type = VCTAG_REQUEST;
	tag4->value_buffer = 0;
	tag4->value_buffer2 = 0;
	tag5->id = VCTAG_SET_VIRT_OFFSET;
	tag5->value_buffer_size = sizeof(unsigned int)*2;
	tag5->ctrl.bits.value_length = 0;
	tag5->ctrl.bits.type = VCTAG_REQUEST;
	tag5->value_buffer = 0;
	tag5->value_buffer2 = 0;
	tag6->id = VCTAG_SET_PIXELORDER;
	tag6->value_buffer_size = sizeof(unsigned int)*2;
	tag6->ctrl.bits.value_length = 0;
	tag6->ctrl.bits.type = VCTAG_REQUEST;
	tag6->value_buffer = 1;
	tag6->value_buffer2 = 0;
	tag7->id = VCTAG_ALLOCATE_BUFFER;
	tag7->value_buffer_size = sizeof(unsigned int)*2;
	tag7->ctrl.bits.value_length = 0;
	tag7->ctrl.bits.type = VCTAG_REQUEST;
	tag7->value_buffer = 0;
	tag7->value_buffer2 = 0;
//	hexdump (SysBase,vc_mailbox_buf ,buffer_size);
	mbox_write_gen(MAILBOX_CHANNEL_ARM_TO_VC, arm_to_vc((void *)vc_mailbox_buf));
	mbox_read_gen(MAILBOX_CHANNEL_ARM_TO_VC);
	response = tag1->value_buffer;
	DPrintF("Response HDR: %x\n", hdr->type);
	DPrintF("Response: %x %d \n", tag1->ctrl.word, response);
	DPrintF("Response: %x %d x %d \n", tag2->ctrl.word, tag2->value_buffer, tag2->value_buffer2);
	DPrintF("Response: %x %d x %d \n", tag3->ctrl.word, tag3->value_buffer, tag3->value_buffer2);
	DPrintF("Response: %x %d x %d \n", tag4->ctrl.word, tag4->value_buffer, tag4->value_buffer2);
	DPrintF("Response: %x %d x %d \n", tag5->ctrl.word, tag5->value_buffer, tag5->value_buffer2);
	DPrintF("Response: %x %d x %d \n", tag6->ctrl.word, tag6->value_buffer, tag6->value_buffer2);
	DPrintF("Response: %x %x x %x \n", tag7->ctrl.word, tag7->value_buffer, tag7->value_buffer2);
	struct bcm2835framebuffer *fb = (APTR)&dbase->fb;
	fb->width = tag2->value_buffer;
	fb->height = tag2->value_buffer2;
	fb->vwidth = tag3->value_buffer;
	fb->vheight = tag3->value_buffer2;
	fb->pitch = 0;
	fb->depth = tag1->value_buffer;
	fb->x = tag5->value_buffer;
	fb->y = tag5->value_buffer2;
	fb->fbaddr = arm_to_vc((APTR)tag7->value_buffer);
	fb->fbsize = tag7->value_buffer2;
	DPrintF("GFX BCM Driver finished\n");
	//for(;;);
	FreeVec(memory);
	return (UINT8*)fb->fbaddr;
driverbase.fb = framebuffer infos:
i fill the old struct with values:
FBADDR = Address of the Framebuffer
this code is a mixture of mine + valtonias have fun.
Cycl0ne
Thu Aug 09, 2012 1:38 pm
Here a Rom Font 8x8 to play with.
/* ROM 8x8 Font bios mode 10 */
static unsigned short rom8x8_bits[] = {
/* Character   (0x00):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character  (0x01):
   ht=8, width=8
0x7e00,
0x8100,
0xa500,
0x8100,
0xbd00,
0x9900,
0x8100,
0x7e00,
/* Character  (0x02):
   ht=8, width=8
0x7c00,
0xfe00,
0xd600,
0xba00,
0xc600,
0xfe00,
0x7c00,
0x0000,
/* Character  (0x03):
   ht=8, width=8
0xc600,
0xee00,
0xfe00,
0xfe00,
0x7c00,
0x3800,
0x1000,
0x0000,
/* Character  (0x04):
   ht=8, width=8
0x1000,
0x3800,
0x7c00,
0xfe00,
0x7c00,
0x3800,
0x1000,
0x0000,
/* Character  (0x05):
   ht=8, width=8
0x1000,
0x3800,
0x1000,
0xee00,
0xee00,
0x1000,
0x3800,
0x0000,
/* Character  (0x06):
   ht=8, width=8
0x3800,
0x7c00,
0xfe00,
0xfe00,
0x6c00,
0x1000,
0x3800,
0x0000,
/* Character  (0x07):
   ht=8, width=8
0x0000,
0x1800,
0x3c00,
0x7e00,
0x3c00,
0x1800,
0x0000,
0x0000,
/* Character  (0x08):
   ht=8, width=8
0xff00,
0xe700,
0xc300,
0x8100,
0xc300,
0xe700,
0xff00,
0xff00,
/* Character 	 (0x09):
   ht=8, width=8
0x0000,
0x1800,
0x3c00,
0x6600,
0x6600,
0x3c00,
0x1800,
0x0000,
/* Character
 (0x0a):
   ht=8, width=8
0xff00,
0xe700,
0xc300,
0x9900,
0x9900,
0xc300,
0xe700,
0xff00,
/* Character  (0x0b):
   ht=8, width=8
0x1e00,
0x0e00,
0x1e00,
0x3600,
0x7800,
0xcc00,
0xcc00,
0x7800,
/* Character  (0x0c):
   ht=8, width=8
0x7e00,
0xc300,
0xc300,
0x7e00,
0x1800,
0x7e00,
0x1800,
0x1800,
/* Character  (0x0d):
   ht=8, width=8
0x1e00,
0x1a00,
0x1e00,
0x1800,
0x1800,
0x7000,
0xf000,
0x6000,
/* Character  (0x0e):
   ht=8, width=8
0x3e00,
0x3e00,
0x3600,
0x3600,
0xf600,
0x6600,
0x1e00,
0x0c00,
/* Character  (0x0f):
   ht=8, width=8
0xdb00,
0x3c00,
0x6600,
0xe700,
0x6600,
0x3c00,
0xdb00,
0x0000,
/* Character  (0x10):
   ht=8, width=8
0x8000,
0xc000,
0xf000,
0xf800,
0xf000,
0xc000,
0x8000,
0x0000,
/* Character  (0x11):
   ht=8, width=8
0x0200,
0x0600,
0x1e00,
0x3e00,
0x1e00,
0x0600,
0x0200,
0x0000,
/* Character  (0x12):
   ht=8, width=8
0x1800,
0x3c00,
0x7e00,
0x1800,
0x7e00,
0x3c00,
0x1800,
0x0000,
/* Character  (0x13):
   ht=8, width=8
0x6600,
0x6600,
0x6600,
0x6600,
0x6600,
0x0000,
0x6600,
0x0000,
/* Character  (0x14):
   ht=8, width=8
0x7f00,
0xdb00,
0x7b00,
0x3b00,
0x1b00,
0x1b00,
0x1b00,
0x0000,
/* Character  (0x15):
   ht=8, width=8
0x3c00,
0x6600,
0x3800,
0x6c00,
0x6c00,
0x3800,
0xcc00,
0x7800,
/* Character  (0x16):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0xfe00,
0xfe00,
0xfe00,
0x0000,
/* Character  (0x17):
   ht=8, width=8
0x1800,
0x3c00,
0x7e00,
0x1800,
0x7e00,
0x3c00,
0x1800,
0x7e00,
/* Character  (0x18):
   ht=8, width=8
0x1800,
0x3c00,
0x7e00,
0x1800,
0x1800,
0x1800,
0x1800,
0x0000,
/* Character  (0x19):
   ht=8, width=8
0x1800,
0x1800,
0x1800,
0x1800,
0x7e00,
0x3c00,
0x1800,
0x0000,
/* Character -> (0x1a):
   ht=8, width=8
0x0000,
0x1800,
0x1c00,
0xfe00,
0x1c00,
0x1800,
0x0000,
0x0000,
/* Character  (0x1b):
   ht=8, width=8
0x0000,
0x3000,
0x7000,
0xfe00,
0x7000,
0x3000,
0x0000,
0x0000,
/* Character  (0x1c):
   ht=8, width=8
0x0000,
0x0000,
0xc000,
0xc000,
0xc000,
0xfe00,
0x0000,
0x0000,
/* Character  (0x1d):
   ht=8, width=8
0x0000,
0x2400,
0x6600,
0xff00,
0x6600,
0x2400,
0x0000,
0x0000,
/* Character  (0x1e):
   ht=8, width=8
0x0000,
0x1000,
0x3800,
0x7c00,
0x7c00,
0xfe00,
0x0000,
0x0000,
/* Character  (0x1f):
   ht=8, width=8
0x0000,
0xfe00,
0x7c00,
0x7c00,
0x3800,
0x1000,
0x0000,
0x0000,
/* Character   (0x20):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character ! (0x21):
   ht=8, width=8
0x1800,
0x3c00,
0x3c00,
0x1800,
0x1800,
0x0000,
0x1800,
0x0000,
/* Character " (0x22):
   ht=8, width=8
0x6c00,
0x6c00,
0x6c00,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character # (0x23):
   ht=8, width=8
0x6c00,
0x6c00,
0xfe00,
0x6c00,
0xfe00,
0x6c00,
0x6c00,
0x0000,
/* Character $ (0x24):
   ht=8, width=8
0x1800,
0x7e00,
0xc000,
0x7c00,
0x0600,
0xfc00,
0x1800,
0x0000,
/* Character % (0x25):
   ht=8, width=8
0x0000,
0xc600,
0x0c00,
0x1800,
0x3000,
0x6000,
0xc600,
0x0000,
/* Character & (0x26):
   ht=8, width=8
0x3800,
0x6c00,
0x3800,
0x7600,
0xcc00,
0xcc00,
0x7600,
0x0000,
/* Character ' (0x27):
   ht=8, width=8
0x1800,
0x1800,
0x3000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character ( (0x28):
   ht=8, width=8
0x1800,
0x3000,
0x6000,
0x6000,
0x6000,
0x3000,
0x1800,
0x0000,
/* Character ) (0x29):
   ht=8, width=8
0x6000,
0x3000,
0x1800,
0x1800,
0x1800,
0x3000,
0x6000,
0x0000,
/* Character * (0x2a):
   ht=8, width=8
0x0000,
0xee00,
0x7c00,
0xfe00,
0x7c00,
0xee00,
0x0000,
0x0000,
/* Character + (0x2b):
   ht=8, width=8
0x0000,
0x1800,
0x1800,
0x7e00,
0x1800,
0x1800,
0x0000,
0x0000,
/* Character , (0x2c):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0x1800,
0x1800,
0x3000,
0x0000,
/* Character - (0x2d):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0xfe00,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character . (0x2e):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x3800,
0x3800,
0x0000,
/* Character / (0x2f):
   ht=8, width=8
0x0600,
0x0c00,
0x1800,
0x3000,
0x6000,
0xc000,
0x8000,
0x0000,
/* Character 0 (0x30):
   ht=8, width=8
0x7c00,
0xc600,
0xce00,
0xde00,
0xf600,
0xe600,
0x7c00,
0x0000,
/* Character 1 (0x31):
   ht=8, width=8
0x1800,
0x7800,
0x1800,
0x1800,
0x1800,
0x1800,
0x7e00,
0x0000,
/* Character 2 (0x32):
   ht=8, width=8
0x7c00,
0xc600,
0x0c00,
0x1800,
0x3000,
0x6600,
0xfe00,
0x0000,
/* Character 3 (0x33):
   ht=8, width=8
0x7c00,
0xc600,
0x0600,
0x3c00,
0x0600,
0xc600,
0x7c00,
0x0000,
/* Character 4 (0x34):
   ht=8, width=8
0x0c00,
0x1c00,
0x3c00,
0x6c00,
0xfe00,
0x0c00,
0x0c00,
0x0000,
/* Character 5 (0x35):
   ht=8, width=8
0xfe00,
0xc000,
0xfc00,
0x0600,
0x0600,
0xc600,
0x7c00,
0x0000,
/* Character 6 (0x36):
   ht=8, width=8
0x7c00,
0xc600,
0xc000,
0xfc00,
0xc600,
0xc600,
0x7c00,
0x0000,
/* Character 7 (0x37):
   ht=8, width=8
0xfe00,
0xc600,
0x0600,
0x0c00,
0x1800,
0x1800,
0x1800,
0x0000,
/* Character 8 (0x38):
   ht=8, width=8
0x7c00,
0xc600,
0xc600,
0x7c00,
0xc600,
0xc600,
0x7c00,
0x0000,
/* Character 9 (0x39):
   ht=8, width=8
0x7c00,
0xc600,
0xc600,
0x7e00,
0x0600,
0xc600,
0x7c00,
0x0000,
/* Character : (0x3a):
   ht=8, width=8
0x0000,
0x1c00,
0x1c00,
0x0000,
0x0000,
0x1c00,
0x1c00,
0x0000,
/* Character ; (0x3b):
   ht=8, width=8
0x0000,
0x1800,
0x1800,
0x0000,
0x0000,
0x1800,
0x1800,
0x3000,
/* Character < (0x3c):
   ht=8, width=8
0x0c00,
0x1800,
0x3000,
0x6000,
0x3000,
0x1800,
0x0c00,
0x0000,
/* Character = (0x3d):
   ht=8, width=8
0x0000,
0x0000,
0xfe00,
0x0000,
0x0000,
0xfe00,
0x0000,
0x0000,
/* Character > (0x3e):
   ht=8, width=8
0x6000,
0x3000,
0x1800,
0x0c00,
0x1800,
0x3000,
0x6000,
0x0000,
/* Character ? (0x3f):
   ht=8, width=8
0x7c00,
0xc600,
0x0600,
0x0c00,
0x1800,
0x0000,
0x1800,
0x0000,
/* Character @ (0x40):
   ht=8, width=8
0x7c00,
0xc600,
0xc600,
0xde00,
0xdc00,
0xc000,
0x7e00,
0x0000,
/* Character A (0x41):
   ht=8, width=8
0x3800,
0x6c00,
0xc600,
0xc600,
0xfe00,
0xc600,
0xc600,
0x0000,
/* Character B (0x42):
   ht=8, width=8
0xfc00,
0x6600,
0x6600,
0x7c00,
0x6600,
0x6600,
0xfc00,
0x0000,
/* Character C (0x43):
   ht=8, width=8
0x3c00,
0x6600,
0xc000,
0xc000,
0xc000,
0x6600,
0x3c00,
0x0000,
/* Character D (0x44):
   ht=8, width=8
0xf800,
0x6c00,
0x6600,
0x6600,
0x6600,
0x6c00,
0xf800,
0x0000,
/* Character E (0x45):
   ht=8, width=8
0xfe00,
0xc200,
0xc000,
0xf800,
0xc000,
0xc200,
0xfe00,
0x0000,
/* Character F (0x46):
   ht=8, width=8
0xfe00,
0x6200,
0x6000,
0x7c00,
0x6000,
0x6000,
0xf000,
0x0000,
/* Character G (0x47):
   ht=8, width=8
0x7c00,
0xc600,
0xc000,
0xc000,
0xde00,
0xc600,
0x7c00,
0x0000,
/* Character H (0x48):
   ht=8, width=8
0xc600,
0xc600,
0xc600,
0xfe00,
0xc600,
0xc600,
0xc600,
0x0000,
/* Character I (0x49):
   ht=8, width=8
0x3c00,
0x1800,
0x1800,
0x1800,
0x1800,
0x1800,
0x3c00,
0x0000,
/* Character J (0x4a):
   ht=8, width=8
0x3c00,
0x1800,
0x1800,
0x1800,
0xd800,
0xd800,
0x7000,
0x0000,
/* Character K (0x4b):
   ht=8, width=8
0xc600,
0xcc00,
0xd800,
0xf000,
0xd800,
0xcc00,
0xc600,
0x0000,
/* Character L (0x4c):
   ht=8, width=8
0xf000,
0x6000,
0x6000,
0x6000,
0x6000,
0x6200,
0xfe00,
0x0000,
/* Character M (0x4d):
   ht=8, width=8
0xc600,
0xee00,
0xfe00,
0xd600,
0xd600,
0xc600,
0xc600,
0x0000,
/* Character N (0x4e):
   ht=8, width=8
0xc600,
0xe600,
0xe600,
0xf600,
0xde00,
0xce00,
0xc600,
0x0000,
/* Character O (0x4f):
   ht=8, width=8
0x7c00,
0xc600,
0xc600,
0xc600,
0xc600,
0xc600,
0x7c00,
0x0000,
/* Character P (0x50):
   ht=8, width=8
0xfc00,
0x6600,
0x6600,
0x7c00,
0x6000,
0x6000,
0xf000,
0x0000,
/* Character Q (0x51):
   ht=8, width=8
0x7c00,
0xc600,
0xc600,
0xc600,
0xc600,
0xd600,
0x7c00,
0x0600,
/* Character R (0x52):
   ht=8, width=8
0xfc00,
0xc600,
0xc600,
0xfc00,
0xd800,
0xcc00,
0xc600,
0x0000,
/* Character S (0x53):
   ht=8, width=8
0x7c00,
0xc600,
0xc000,
0x7c00,
0x0600,
0xc600,
0x7c00,
0x0000,
/* Character T (0x54):
   ht=8, width=8
0x7e00,
0x5a00,
0x1800,
0x1800,
0x1800,
0x1800,
0x3c00,
0x0000,
/* Character U (0x55):
   ht=8, width=8
0xc600,
0xc600,
0xc600,
0xc600,
0xc600,
0xc600,
0x7c00,
0x0000,
/* Character V (0x56):
   ht=8, width=8
0xc600,
0xc600,
0xc600,
0xc600,
0x6c00,
0x3800,
0x1000,
0x0000,
/* Character W (0x57):
   ht=8, width=8
0xc600,
0xc600,
0xd600,
0xd600,
0xfe00,
0xee00,
0xc600,
0x0000,
/* Character X (0x58):
   ht=8, width=8
0xc600,
0x6c00,
0x3800,
0x3800,
0x3800,
0x6c00,
0xc600,
0x0000,
/* Character Y (0x59):
   ht=8, width=8
0x6600,
0x6600,
0x6600,
0x3c00,
0x1800,
0x1800,
0x3c00,
0x0000,
/* Character Z (0x5a):
   ht=8, width=8
0xfe00,
0x8600,
0x0c00,
0x1800,
0x3000,
0x6200,
0xfe00,
0x0000,
/* Character [ (0x5b):
   ht=8, width=8
0x7c00,
0x6000,
0x6000,
0x6000,
0x6000,
0x6000,
0x7c00,
0x0000,
/* Character \ (0x5c):
   ht=8, width=8
0xc000,
0x6000,
0x3000,
0x1800,
0x0c00,
0x0600,
0x0200,
0x0000,
/* Character ] (0x5d):
   ht=8, width=8
0x7c00,
0x0c00,
0x0c00,
0x0c00,
0x0c00,
0x0c00,
0x7c00,
0x0000,
/* Character ^ (0x5e):
   ht=8, width=8
0x1000,
0x3800,
0x6c00,
0xc600,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character _ (0x5f):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0xff00,
/* Character ` (0x60):
   ht=8, width=8
0x3000,
0x3000,
0x1800,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character a (0x61):
   ht=8, width=8
0x0000,
0x0000,
0x7800,
0x0c00,
0x7c00,
0xcc00,
0x7e00,
0x0000,
/* Character b (0x62):
   ht=8, width=8
0xe000,
0x6000,
0x7c00,
0x6600,
0x6600,
0x6600,
0xfc00,
0x0000,
/* Character c (0x63):
   ht=8, width=8
0x0000,
0x0000,
0x7c00,
0xc600,
0xc000,
0xc600,
0x7c00,
0x0000,
/* Character d (0x64):
   ht=8, width=8
0x1c00,
0x0c00,
0x7c00,
0xcc00,
0xcc00,
0xcc00,
0x7e00,
0x0000,
/* Character e (0x65):
   ht=8, width=8
0x0000,
0x0000,
0x7c00,
0xc600,
0xfe00,
0xc000,
0x7c00,
0x0000,
/* Character f (0x66):
   ht=8, width=8
0x1c00,
0x3600,
0x3000,
0xfc00,
0x3000,
0x3000,
0x7800,
0x0000,
/* Character g (0x67):
   ht=8, width=8
0x0000,
0x0000,
0x7600,
0xce00,
0xc600,
0x7e00,
0x0600,
0x7c00,
/* Character h (0x68):
   ht=8, width=8
0xe000,
0x6000,
0x7c00,
0x6600,
0x6600,
0x6600,
0xe600,
0x0000,
/* Character i (0x69):
   ht=8, width=8
0x1800,
0x0000,
0x3800,
0x1800,
0x1800,
0x1800,
0x3c00,
0x0000,
/* Character j (0x6a):
   ht=8, width=8
0x0c00,
0x0000,
0x1c00,
0x0c00,
0x0c00,
0x0c00,
0xcc00,
0x7800,
/* Character k (0x6b):
   ht=8, width=8
0xe000,
0x6000,
0x6600,
0x6c00,
0x7800,
0x6c00,
0xe600,
0x0000,
/* Character l (0x6c):
   ht=8, width=8
0x1800,
0x1800,
0x1800,
0x1800,
0x1800,
0x1800,
0x1c00,
0x0000,
/* Character m (0x6d):
   ht=8, width=8
0x0000,
0x0000,
0x6c00,
0xfe00,
0xd600,
0xd600,
0xc600,
0x0000,
/* Character n (0x6e):
   ht=8, width=8
0x0000,
0x0000,
0xdc00,
0x6600,
0x6600,
0x6600,
0x6600,
0x0000,
/* Character o (0x6f):
   ht=8, width=8
0x0000,
0x0000,
0x7c00,
0xc600,
0xc600,
0xc600,
0x7c00,
0x0000,
/* Character p (0x70):
   ht=8, width=8
0x0000,
0x0000,
0xdc00,
0x6600,
0x6600,
0x7c00,
0x6000,
0xf000,
/* Character q (0x71):
   ht=8, width=8
0x0000,
0x0000,
0x7600,
0xcc00,
0xcc00,
0x7c00,
0x0c00,
0x1e00,
/* Character r (0x72):
   ht=8, width=8
0x0000,
0x0000,
0xdc00,
0x6600,
0x6000,
0x6000,
0xf000,
0x0000,
/* Character s (0x73):
   ht=8, width=8
0x0000,
0x0000,
0x7c00,
0xc000,
0x7c00,
0x0600,
0x7c00,
0x0000,
/* Character t (0x74):
   ht=8, width=8
0x3000,
0x3000,
0xfc00,
0x3000,
0x3000,
0x3600,
0x1c00,
0x0000,
/* Character u (0x75):
   ht=8, width=8
0x0000,
0x0000,
0xcc00,
0xcc00,
0xcc00,
0xcc00,
0x7600,
0x0000,
/* Character v (0x76):
   ht=8, width=8
0x0000,
0x0000,
0xc600,
0xc600,
0x6c00,
0x3800,
0x1000,
0x0000,
/* Character w (0x77):
   ht=8, width=8
0x0000,
0x0000,
0xc600,
0xc600,
0xd600,
0xfe00,
0x6c00,
0x0000,
/* Character x (0x78):
   ht=8, width=8
0x0000,
0x0000,
0xc600,
0x6c00,
0x3800,
0x6c00,
0xc600,
0x0000,
/* Character y (0x79):
   ht=8, width=8
0x0000,
0x0000,
0xc600,
0xc600,
0xce00,
0x7600,
0x0600,
0x7c00,
/* Character z (0x7a):
   ht=8, width=8
0x0000,
0x0000,
0xfc00,
0x9800,
0x3000,
0x6400,
0xfc00,
0x0000,
/* Character { (0x7b):
   ht=8, width=8
0x0e00,
0x1800,
0x1800,
0x7000,
0x1800,
0x1800,
0x0e00,
0x0000,
/* Character | (0x7c):
   ht=8, width=8
0x1800,
0x1800,
0x1800,
0x0000,
0x1800,
0x1800,
0x1800,
0x0000,
/* Character } (0x7d):
   ht=8, width=8
0x7000,
0x1800,
0x1800,
0x0e00,
0x1800,
0x1800,
0x7000,
0x0000,
/* Character ~ (0x7e):
   ht=8, width=8
0x7600,
0xdc00,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character  (0x7f):
   ht=8, width=8
0x0000,
0x1000,
0x3800,
0x3800,
0x6c00,
0x6c00,
0xfe00,
0x0000,
/* Character € (0x80):
   ht=8, width=8
0x3c00,
0x6600,
0xc000,
0x6600,
0x3c00,
0x1800,
0xcc00,
0x7800,
/* Character  (0x81):
   ht=8, width=8
0x0000,
0xc600,
0x0000,
0xc600,
0xc600,
0xce00,
0x7600,
0x0000,
/* Character ‚ (0x82):
   ht=8, width=8
0x0e00,
0x0000,
0x7c00,
0xc600,
0xfe00,
0xc000,
0x7c00,
0x0000,
/* Character ƒ (0x83):
   ht=8, width=8
0x7c00,
0xc600,
0x7800,
0x0c00,
0x7c00,
0xcc00,
0x7e00,
0x0000,
/* Character „ (0x84):
   ht=8, width=8
0xc600,
0x0000,
0x7800,
0x0c00,
0x7c00,
0xcc00,
0x7e00,
0x0000,
/* Character … (0x85):
   ht=8, width=8
0xe000,
0x0000,
0x7800,
0x0c00,
0x7c00,
0xcc00,
0x7e00,
0x0000,
/* Character † (0x86):
   ht=8, width=8
0x3800,
0x3800,
0x7800,
0x0c00,
0x7c00,
0xcc00,
0x7e00,
0x0000,
/* Character ‡ (0x87):
   ht=8, width=8
0x0000,
0x0000,
0x7c00,
0xc000,
0x7c00,
0x1800,
0x6c00,
0x3800,
/* Character ˆ (0x88):
   ht=8, width=8
0x7c00,
0xc600,
0x7c00,
0xc600,
0xfe00,
0xc000,
0x7c00,
0x0000,
/* Character ‰ (0x89):
   ht=8, width=8
0xc600,
0x0000,
0x7c00,
0xc600,
0xfe00,
0xc000,
0x7c00,
0x0000,
/* Character Š (0x8a):
   ht=8, width=8
0xe000,
0x0000,
0x7c00,
0xc600,
0xfe00,
0xc000,
0x7c00,
0x0000,
/* Character ‹ (0x8b):
   ht=8, width=8
0x6600,
0x0000,
0x3800,
0x1800,
0x1800,
0x1800,
0x3c00,
0x0000,
/* Character Π(0x8c):
   ht=8, width=8
0x7c00,
0xc600,
0x3800,
0x1800,
0x1800,
0x1800,
0x3c00,
0x0000,
/* Character  (0x8d):
   ht=8, width=8
0xe000,
0x0000,
0x3800,
0x1800,
0x1800,
0x1800,
0x3c00,
0x0000,
/* Character Ž (0x8e):
   ht=8, width=8
0xc600,
0x3800,
0x6c00,
0xc600,
0xfe00,
0xc600,
0xc600,
0x0000,
/* Character  (0x8f):
   ht=8, width=8
0x3800,
0x3800,
0x0000,
0x7c00,
0xc600,
0xfe00,
0xc600,
0x0000,
/* Character  (0x90):
   ht=8, width=8
0x0e00,
0x0000,
0xfe00,
0xc000,
0xf800,
0xc000,
0xfe00,
0x0000,
/* Character ‘ (0x91):
   ht=8, width=8
0x0000,
0x0000,
0x6c00,
0x9a00,
0x7e00,
0xd800,
0x6e00,
0x0000,
/* Character ’ (0x92):
   ht=8, width=8
0x7e00,
0xd800,
0xd800,
0xfe00,
0xd800,
0xd800,
0xde00,
0x0000,
/* Character “ (0x93):
   ht=8, width=8
0x7c00,
0xc600,
0x0000,
0x7c00,
0xc600,
0xc600,
0x7c00,
0x0000,
/* Character ” (0x94):
   ht=8, width=8
0x0000,
0xc600,
0x0000,
0x7c00,
0xc600,
0xc600,
0x7c00,
0x0000,
/* Character • (0x95):
   ht=8, width=8
0x0000,
0xe000,
0x0000,
0x7c00,
0xc600,
0xc600,
0x7c00,
0x0000,
/* Character – (0x96):
   ht=8, width=8
0x7c00,
0xc600,
0x0000,
0xc600,
0xc600,
0xce00,
0x7600,
0x0000,
/* Character — (0x97):
   ht=8, width=8
0x0000,
0xe000,
0x0000,
0xc600,
0xc600,
0xce00,
0x7600,
0x0000,
/* Character ˜ (0x98):
   ht=8, width=8
0x0000,
0xc600,
0x0000,
0xc600,
0xce00,
0x7600,
0x0600,
0x7c00,
/* Character ™ (0x99):
   ht=8, width=8
0xc600,
0x3800,
0x6c00,
0xc600,
0xc600,
0x6c00,
0x3800,
0x0000,
/* Character š (0x9a):
   ht=8, width=8
0xc600,
0x0000,
0xc600,
0xc600,
0xc600,
0xc600,
0x7c00,
0x0000,
/* Character › (0x9b):
   ht=8, width=8
0x0000,
0x1800,
0x7e00,
0xd800,
0xd800,
0x7e00,
0x1800,
0x0000,
/* Character œ (0x9c):
   ht=8, width=8
0x3800,
0x6c00,
0x6000,
0xf000,
0x6600,
0xf600,
0x6c00,
0x0000,
/* Character  (0x9d):
   ht=8, width=8
0xc300,
0x6600,
0x3c00,
0x7e00,
0x1800,
0x3c00,
0x1800,
0x0000,
/* Character ž (0x9e):
   ht=8, width=8
0xfc00,
0xc600,
0xfc00,
0xcc00,
0xde00,
0xcc00,
0xce00,
0x0000,
/* Character Ÿ (0x9f):
   ht=8, width=8
0x0c00,
0x1e00,
0x1800,
0x7e00,
0x1800,
0x1800,
0xd800,
0x7000,
/* Character   (0xa0):
   ht=8, width=8
0x0e00,
0x0000,
0x7800,
0x0c00,
0x7c00,
0xcc00,
0x7e00,
0x0000,
/* Character ¡ (0xa1):
   ht=8, width=8
0x1c00,
0x0000,
0x3800,
0x1800,
0x1800,
0x1800,
0x3c00,
0x0000,
/* Character ¢ (0xa2):
   ht=8, width=8
0x0000,
0x0e00,
0x0000,
0x7c00,
0xc600,
0xc600,
0x7c00,
0x0000,
/* Character £ (0xa3):
   ht=8, width=8
0x0000,
0x0e00,
0x0000,
0xcc00,
0xcc00,
0xdc00,
0x7600,
0x0000,
/* Character ¤ (0xa4):
   ht=8, width=8
0x0000,
0xfc00,
0x0000,
0xbc00,
0x6600,
0x6600,
0xe600,
0x0000,
/* Character ¥ (0xa5):
   ht=8, width=8
0xfe00,
0x0000,
0xc600,
0xe600,
0xf600,
0xce00,
0xc600,
0x0000,
/* Character ¦ (0xa6):
   ht=8, width=8
0x3800,
0x6c00,
0x3e00,
0x0000,
0x7e00,
0x0000,
0x0000,
0x0000,
/* Character § (0xa7):
   ht=8, width=8
0x7c00,
0xc600,
0x7c00,
0x0000,
0x7c00,
0x0000,
0x0000,
0x0000,
/* Character ¨ (0xa8):
   ht=8, width=8
0x1800,
0x0000,
0x1800,
0x3000,
0x6000,
0x6600,
0x3c00,
0x0000,
/* Character © (0xa9):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x7c00,
0x6000,
0x6000,
0x0000,
0x0000,
/* Character ª (0xaa):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x7c00,
0x0c00,
0x0c00,
0x0000,
0x0000,
/* Character « (0xab):
   ht=8, width=8
0xc000,
0xcc00,
0xd800,
0x3000,
0x7c00,
0x3600,
0x0c00,
0x3e00,
/* Character ¬ (0xac):
   ht=8, width=8
0xc000,
0xcc00,
0xd800,
0x3000,
0x6c00,
0x3c00,
0x7e00,
0x0c00,
/* Character ­ (0xad):
   ht=8, width=8
0x1800,
0x0000,
0x1800,
0x1800,
0x3c00,
0x3c00,
0x1800,
0x0000,
/* Character ® (0xae):
   ht=8, width=8
0x0000,
0x3600,
0x6c00,
0xd800,
0x6c00,
0x3600,
0x0000,
0x0000,
/* Character ¯ (0xaf):
   ht=8, width=8
0x0000,
0xd800,
0x6c00,
0x3600,
0x6c00,
0xd800,
0x0000,
0x0000,
/* Character ° (0xb0):
   ht=8, width=8
0x2200,
0x8800,
0x2200,
0x8800,
0x2200,
0x8800,
0x2200,
0x8800,
/* Character ± (0xb1):
   ht=8, width=8
0x5500,
0xaa00,
0x5500,
0xaa00,
0x5500,
0xaa00,
0x5500,
0xaa00,
/* Character ² (0xb2):
   ht=8, width=8
0xdd00,
0x7700,
0xdd00,
0x7700,
0xdd00,
0x7700,
0xdd00,
0x7700,
/* Character ³ (0xb3):
   ht=8, width=8
0x1800,
0x1800,
0x1800,
0x1800,
0x1800,
0x1800,
0x1800,
0x1800,
/* Character ´ (0xb4):
   ht=8, width=8
0x1800,
0x1800,
0x1800,
0x1800,
0xf800,
0x1800,
0x1800,
0x1800,
/* Character µ (0xb5):
   ht=8, width=8
0x1800,
0x1800,
0xf800,
0x1800,
0xf800,
0x1800,
0x1800,
0x1800,
/* Character ¶ (0xb6):
   ht=8, width=8
0x3600,
0x3600,
0x3600,
0x3600,
0xf600,
0x3600,
0x3600,
0x3600,
/* Character · (0xb7):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0xfe00,
0x3600,
0x3600,
0x3600,
Cycl0ne
second part:
/* Character ¸ (0xb8):
   ht=8, width=8
0x0000,
0x0000,
0xf800,
0x1800,
0xf800,
0x1800,
0x1800,
0x1800,
/* Character ¹ (0xb9):
   ht=8, width=8
0x3600,
0x3600,
0xf600,
0x0600,
0xf600,
0x3600,
0x3600,
0x3600,
/* Character º (0xba):
   ht=8, width=8
0x3600,
0x3600,
0x3600,
0x3600,
0x3600,
0x3600,
0x3600,
0x3600,
/* Character » (0xbb):
   ht=8, width=8
0x0000,
0x0000,
0xfe00,
0x0600,
0xf600,
0x3600,
0x3600,
0x3600,
/* Character ¼ (0xbc):
   ht=8, width=8
0x3600,
0x3600,
0xf600,
0x0600,
0xfe00,
0x0000,
0x0000,
0x0000,
/* Character ½ (0xbd):
   ht=8, width=8
0x3600,
0x3600,
0x3600,
0x3600,
0xfe00,
0x0000,
0x0000,
0x0000,
/* Character ¾ (0xbe):
   ht=8, width=8
0x1800,
0x1800,
0xf800,
0x1800,
0xf800,
0x0000,
0x0000,
0x0000,
/* Character ¿ (0xbf):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0xf800,
0x1800,
0x1800,
0x1800,
/* Character À (0xc0):
   ht=8, width=8
0x1800,
0x1800,
0x1800,
0x1800,
0x1f00,
0x0000,
0x0000,
0x0000,
/* Character Á (0xc1):
   ht=8, width=8
0x1800,
0x1800,
0x1800,
0x1800,
0xff00,
0x0000,
0x0000,
0x0000,
/* Character  (0xc2):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0xff00,
0x1800,
0x1800,
0x1800,
/* Character à (0xc3):
   ht=8, width=8
0x1800,
0x1800,
0x1800,
0x1800,
0x1f00,
0x1800,
0x1800,
0x1800,
/* Character Ä (0xc4):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0xff00,
0x0000,
0x0000,
0x0000,
/* Character Å (0xc5):
   ht=8, width=8
0x1800,
0x1800,
0x1800,
0x1800,
0xff00,
0x1800,
0x1800,
0x1800,
/* Character Æ (0xc6):
   ht=8, width=8
0x1800,
0x1800,
0x1f00,
0x1800,
0x1f00,
0x1800,
0x1800,
0x1800,
/* Character Ç (0xc7):
   ht=8, width=8
0x3600,
0x3600,
0x3600,
0x3600,
0x3700,
0x3600,
0x3600,
0x3600,
/* Character È (0xc8):
   ht=8, width=8
0x3600,
0x3600,
0x3700,
0x3000,
0x3f00,
0x0000,
0x0000,
0x0000,
/* Character É (0xc9):
   ht=8, width=8
0x0000,
0x0000,
0x3f00,
0x3000,
0x3700,
0x3600,
0x3600,
0x3600,
/* Character Ê (0xca):
   ht=8, width=8
0x3600,
0x3600,
0xf700,
0x0000,
0xff00,
0x0000,
0x0000,
0x0000,
/* Character Ë (0xcb):
   ht=8, width=8
0x0000,
0x0000,
0xff00,
0x0000,
0xf700,
0x3600,
0x3600,
0x3600,
/* Character Ì (0xcc):
   ht=8, width=8
0x3600,
0x3600,
0x3700,
0x3000,
0x3700,
0x3600,
0x3600,
0x3600,
/* Character Í (0xcd):
   ht=8, width=8
0x0000,
0x0000,
0xff00,
0x0000,
0xff00,
0x0000,
0x0000,
0x0000,
/* Character Î (0xce):
   ht=8, width=8
0x3600,
0x3600,
0xf700,
0x0000,
0xf700,
0x3600,
0x3600,
0x3600,
/* Character Ï (0xcf):
   ht=8, width=8
0x1800,
0x1800,
0xff00,
0x0000,
0xff00,
0x0000,
0x0000,
0x0000,
/* Character Ð (0xd0):
   ht=8, width=8
0x3600,
0x3600,
0x3600,
0x3600,
0xff00,
0x0000,
0x0000,
0x0000,
/* Character Ñ (0xd1):
   ht=8, width=8
0x0000,
0x0000,
0xff00,
0x0000,
0xff00,
0x1800,
0x1800,
0x1800,
/* Character Ò (0xd2):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0xff00,
0x3600,
0x3600,
0x3600,
/* Character Ó (0xd3):
   ht=8, width=8
0x3600,
0x3600,
0x3600,
0x3600,
0x3f00,
0x0000,
0x0000,
0x0000,
/* Character Ô (0xd4):
   ht=8, width=8
0x1800,
0x1800,
0x1f00,
0x1800,
0x1f00,
0x0000,
0x0000,
0x0000,
/* Character Õ (0xd5):
   ht=8, width=8
0x0000,
0x0000,
0x1f00,
0x1800,
0x1f00,
0x1800,
0x1800,
0x1800,
/* Character Ö (0xd6):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0x3f00,
0x3600,
0x3600,
0x3600,
/* Character × (0xd7):
   ht=8, width=8
0x3600,
0x3600,
0x3600,
0x3600,
0xff00,
0x3600,
0x3600,
0x3600,
/* Character Ø (0xd8):
   ht=8, width=8
0x1800,
0x1800,
0xff00,
0x1800,
0xff00,
0x1800,
0x1800,
0x1800,
/* Character Ù (0xd9):
   ht=8, width=8
0x1800,
0x1800,
0x1800,
0x1800,
0xf800,
0x0000,
0x0000,
0x0000,
/* Character Ú (0xda):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0x1f00,
0x1800,
0x1800,
0x1800,
/* Character Û (0xdb):
   ht=8, width=8
0xff00,
0xff00,
0xff00,
0xff00,
0xff00,
0xff00,
0xff00,
0xff00,
/* Character Ü (0xdc):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0xff00,
0xff00,
0xff00,
0xff00,
/* Character Ý (0xdd):
   ht=8, width=8
0xf000,
0xf000,
0xf000,
0xf000,
0xf000,
0xf000,
0xf000,
0xf000,
/* Character Þ (0xde):
   ht=8, width=8
0x0f00,
0x0f00,
0x0f00,
0x0f00,
0x0f00,
0x0f00,
0x0f00,
0x0f00,
/* Character ß (0xdf):
   ht=8, width=8
0xff00,
0xff00,
0xff00,
0xff00,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character à (0xe0):
   ht=8, width=8
0x0000,
0x0000,
0x6600,
0xdc00,
0xd800,
0xdc00,
0x6600,
0x0000,
/* Character á (0xe1):
   ht=8, width=8
0x0000,
0x7800,
0xcc00,
0xf800,
0xcc00,
0xc600,
0xcc00,
0x0000,
/* Character â (0xe2):
   ht=8, width=8
0x0000,
0xfe00,
0x6200,
0x6000,
0x6000,
0x6000,
0xe000,
0x0000,
/* Character ã (0xe3):
   ht=8, width=8
0x0000,
0xfe00,
0x6c00,
0x6c00,
0x6c00,
0x6c00,
0x6c00,
0x0000,
/* Character ä (0xe4):
   ht=8, width=8
0xfe00,
0xc600,
0x6000,
0x3000,
0x6000,
0xc600,
0xfe00,
0x0000,
/* Character å (0xe5):
   ht=8, width=8
0x0000,
0x7e00,
0xd800,
0xcc00,
0xcc00,
0xd800,
0x7000,
0x0000,
/* Character æ (0xe6):
   ht=8, width=8
0x0000,
0x6600,
0x6600,
0x6600,
0x6600,
0x7c00,
0xc000,
0x0000,
/* Character ç (0xe7):
   ht=8, width=8
0x0000,
0x7600,
0xdc00,
0x1800,
0x1800,
0x1800,
0x3800,
0x0000,
/* Character è (0xe8):
   ht=8, width=8
0xfe00,
0x3800,
0x6c00,
0xc600,
0x6c00,
0x3800,
0xfe00,
0x0000,
/* Character é (0xe9):
   ht=8, width=8
0x3800,
0x6c00,
0xc600,
0xfe00,
0xc600,
0x6c00,
0x3800,
0x0000,
/* Character ê (0xea):
   ht=8, width=8
0x3800,
0x6c00,
0xc600,
0xc600,
0x6c00,
0x6c00,
0xee00,
0x0000,
/* Character ë (0xeb):
   ht=8, width=8
0x3e00,
0x6000,
0x3800,
0x6600,
0xc600,
0xcc00,
0x7800,
0x0000,
/* Character ì (0xec):
   ht=8, width=8
0x0000,
0x0000,
0x7e00,
0xdb00,
0xdb00,
0x7e00,
0x0000,
0x0000,
/* Character í (0xed):
   ht=8, width=8
0x0600,
0x7c00,
0xde00,
0xf600,
0xe600,
0x7c00,
0xc000,
0x0000,
/* Character î (0xee):
   ht=8, width=8
0x3800,
0x6000,
0xc000,
0xf800,
0xc000,
0x6000,
0x3800,
0x0000,
/* Character ï (0xef):
   ht=8, width=8
0x7c00,
0xc600,
0xc600,
0xc600,
0xc600,
0xc600,
0xc600,
0x0000,
/* Character ð (0xf0):
   ht=8, width=8
0x0000,
0xfe00,
0x0000,
0xfe00,
0x0000,
0xfe00,
0x0000,
0x0000,
/* Character ñ (0xf1):
   ht=8, width=8
0x1800,
0x1800,
0x7e00,
0x1800,
0x1800,
0x0000,
0x7e00,
0x0000,
/* Character ò (0xf2):
   ht=8, width=8
0x3000,
0x1800,
0x0c00,
0x1800,
0x3000,
0x0000,
0x7e00,
0x0000,
/* Character ó (0xf3):
   ht=8, width=8
0x0c00,
0x1800,
0x3000,
0x1800,
0x0c00,
0x0000,
0x7e00,
0x0000,
/* Character ô (0xf4):
   ht=8, width=8
0x0c00,
0x1e00,
0x1800,
0x1800,
0x1800,
0x1800,
0x1800,
0x1800,
/* Character õ (0xf5):
   ht=8, width=8
0x1800,
0x1800,
0x1800,
0x1800,
0x1800,
0x7800,
0x3000,
0x0000,
/* Character ö (0xf6):
   ht=8, width=8
0x0000,
0x0000,
0x1800,
0x0000,
0x7e00,
0x0000,
0x1800,
0x0000,
/* Character ÷ (0xf7):
   ht=8, width=8
0x0000,
0x7600,
0xdc00,
0x0000,
0x7600,
0xdc00,
0x0000,
0x0000,
/* Character ø (0xf8):
   ht=8, width=8
0x7c00,
0xc600,
0xc600,
0x7c00,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character ù (0xf9):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x1800,
0x1800,
0x0000,
0x0000,
0x0000,
/* Character ú (0xfa):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0x1800,
0x0000,
0x0000,
0x0000,
/* Character û (0xfb):
   ht=8, width=8
0x1f00,
0x1800,
0x1800,
0x1800,
0xf800,
0x3800,
0x1800,
0x0000,
/* Character ü (0xfc):
   ht=8, width=8
0xd800,
0x6c00,
0x6c00,
0x6c00,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character ý (0xfd):
   ht=8, width=8
0x7000,
0xd800,
0x3000,
0xf800,
0x0000,
0x0000,
0x0000,
0x0000,
/* Character þ (0xfe):
   ht=8, width=8
0x0000,
0x0000,
0x7c00,
0x7c00,
0x7c00,
0x7c00,
0x0000,
0x0000,
/* Character ÿ (0xff):
   ht=8, width=8
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
0x0000,
DexOS
Thu Aug 09, 2012 6:38 pm
You could try DexBasic, if you like basic or assembly coding
http://www.dex-os.com/DexBasic/DexBasic.htm
It has a set of easy to use functions and more are being added each week.
Hello world example
include 'DexBasic\DexBasic.inc'
print "Hello World!"        ; prints hello with ending line break
sync                        ; write screen buffer to screen
end                         ; end program, just loop over and over again
align 4
ProgramSize:                ; this label = size of this program
ScreenBuffer:               ; off screen buffer address
Batteries not included, Some assembly required.
slow_death
Thu Aug 09, 2012 11:57 pm
Thanks for all the responces.
I will start with just clearing the screen and writing a few pixels..
and see what happens..
if there are any other examples or good links - please let me know..
working on learning more about the mailbox ...
