jpd
initrd/initramfs problems
Thu Oct 03, 2013 3:20 pm
I am trying to use a current kernel on the Pi with an initrd/initramfs, but
cannot get it to work properly.
http://www.elinux.org/RPiconfig shows the following initramfs/initrd-related options for /boot/config.txt:
  • ramfsfile (string) ramfs file to load
  • ramfsaddr address to load ramfs file at
  • initramfs (string address) ramfs file and adress to load it at (it's like ramfsfile+ramfsaddr in one option). NOTE: this option uses different syntax than all other options - you should not use "=" character here. Example:
    initramfs initramf.gz 0x00800000
I am using a self-built kernel (current git, 3.11.y branch); kernel and initrd image were built using the Debian kernel-package tools. The kernel itself is configured for both initramfs as well as for "classic" (block device) ramdisk support:
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=4096
# CONFIG_BLK_DEV_XIP is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
# CONFIG_RD_LZO is not set
# CONFIG_RD_LZ4 is not set
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
Booting the kernel without initrd options works ok (just "kernel=vmlinuz-3.11.2-rpiinitrd" in /boot/config.txt). When adding
  initramfs initrd.img-3.11.2-rpiinitrd 0x00a00000
as described in http://www.raspberrypi.org/phpBB3/viewt ... =28&t=7626, the kernel log shows the following error message:
[    1.286546] Trying to unpack rootfs image as initramfs...
[    1.292336] rootfs image is not initramfs (junk in compressed archive); looks like an initrd
[    1.332560] Freeing initrd memory: 3604K (c0a00000 - c0d85000)
The file /boot/initrd.img-3.11.2-rpiinitrd is a gzip-compressed ASCII cpio archive (SVR4 with no CRC), i.e. valid initramfs
format, so the error message "image is not initramfs" seems to be wrong. Maybe the kernel is looking at the wrong memory address?
I have then tried to let the firmware determine the initramfs load address itself by just putting
without address information into /boot/config.txt. This resulted in
[    1.286662] Trying to unpack rootfs image as initramfs...
[    1.795917] Freeing initrd memory: 3604K (dbc6a000 - dbfef000)
but the actual initramfs code does not seem to be executed. To further test that, I have tried to boot a self-contained mini-system in an initramfs. For this, I have taken the files from https://github.com/raspberrypi/target_fs and built an initramfs image from them:
find . -print -depth | cpio --quiet -R 0:0 -o -H newc > /boot/rescue.cpio
gzip /boot/rescue.cpio
and then changed the initramfs line in /boot/config.txt to
initramfs rescue.cpio.gz
This resulted in:
[    1.300421] Trying to unpack rootfs image as initramfs...
[    1.664563] Freeing initrd memory: 3140K (dbcde000 - dbfef000)
and the system then just booted the root partition from the SD card instead of falling into a busybox shell within the initrd.
The given sizes in both cases (3604K/3140K) correspond roughly with the respective initramfs file sizes, so it seems that the kernel has actually found the initramfs in memory.
I would appreciate very much if anybody could give me a hint what is going wrong here.
Regards,
jpd
summers
Re: initrd/initramfs problems
Fri Apr 18, 2014 9:13 am
What I've always done on my pandaboard is to create the filesystem I want to live in. convert to cpio archive. gzipped the result. Then during kernel compile when configuring initramfs there is an option to give the file that contains the cpio archive. The build kernel then has the filesystem directly embedded in it - and that boots fine.
I'd only do this for fairly small file systems btw, I have little more that uClibc + busybox, with some configuration files, and some wifi configuarion programs - so the gzipped cpio archive is ~9MB, which sill turns out to be most of the kernel image (~13MB).
Havn't tried loading the initramfs up seperatly into memory from the kernel, guess its possible with uboot - but seems far easier to package it up in the kernel image itself. On a Pi don't even know how you would load up the initramfs into memory - its not like you boot from uboot ...
uski
Sun Apr 17, 2016 7:55 am
I'm digging up a very old thread but I have exactly the same problem.
I'm using the latest Arch Linux for the RPi, it's a RPi version 1 model B.
I get exactly the same problem :
[    2.442697] Trying to unpack rootfs image as initramfs...
[    2.448633] rootfs image is not initramfs (junk in compressed archive); looks like an initrd
[    2.474632] Freeing initrd memory: 2536K (c0f00000 - c117a000)
When using cmdline.txt :
initrd=0x00f00000,0x27952e
And config.txt :
initramfs initrd.gz 0x00f00000
The initrd.gz file has been made with mkinitcpio -g /boot/initrd.gz
I also tried removing the initrd config option from the cmdline and using initramfs with followkernel, but my kernel shows this and I really don't like it :
[    0.383618] No ATAGs?
It looks like the bootloader doesn't pass the ATAGs to the kernel.
Normally the INITRD location is passed through an ATAG by the bootloader... the RPi bootloader doesn't do that ?
I also get this line when not specifying initrd to the cmdline and using followkernel in the config.txt initramfs option. That's bad, it means the followkernel option will never work if the bootloader doesn't pass the corresponding ATAG to the kernel...
Anyway, if anyone has a successful configuration to setup an initrd for an RPi, I'd gladly appreciate any help.
uski
m0rphium
Tue May 17, 2016 6:44 am
I'm pretty happy someone in irc told me that it will work using a different image, e.g. raspbian netinstaller which has a default initramfs and which supports the followkernel option.
Return to “Linux Kernel”
