ruzz
Updating kernel on arch
Mon Jul 08, 2013 2:14 pm
I've cross compiled a kernel for raspian which works, though I'm having some issues with Arch linux.
In fact, I've tried to rule out my build and use the following to copy latest release from the firmware repo:
sudo ./automount.sh /dev/sdc
sudo cp firmware/boot/kernel.img /pi/boot/
sudo cp firmware/boot/bootcode.bin /pi/boot/
sudo cp firmware/boot/fixup.dat /pi/boot/
sudo cp firmware/boot/start.elf /pi/boot/
sudo rm -rf /pi/lib/modules/*
sudo cp -ar firmware/modules/* /pi/lib/modules/
sudo rm -rf /pi/opt/vc
sudo cp -ar firmware/hardfp/opt/vc /pi/opt/vc
sync
sudo ./autounmount.sh
- This seems to work well for Raspian.
On Arch, even with a kernel I've compiled using the right config.gz from the device seems to be failing to boot. Very early in the process I get:
vchiq_get_state: g_state.remote->initialised != 1 (0).
Screenshot attached.
I assume I must be missing something for Arch, and would appreciate if anyone could fill me in.
Thanks,
-Russ.
aaa801
Re: Updating kernel on arch
Wed Jul 10, 2013 5:38 pm
ruzz
Wed Jul 10, 2013 6:52 pm
Thanks, though I've tried that, it's part of the script abobe.
The same scripts I use seem to work perfectly for raspbian by the way..
Anyone have a good workflow for Arch linux kernel?
Thanks,
-R.
Return to “Linux Kernel”
