djdjdjole
RFS building
Mon Dec 17, 2012 1:53 pm
Hello. I am interested if someone tried to build root file system for Rospberry, using BuildRoot, ie. u-boot, kernel and RFS. I would like to use NFS, because it is good during development phase. If so, it would be nice to share details with community.
Regards
summers
Re: RFS building
Mon Dec 17, 2012 3:45 pm
When I get time, i'll be building up a very minimal OS from scratch. e.g. linux with busybox in a ramdisk. But hasn't happened yet - indeed haven't yet gout round to setting up an operational toolchain ...
From what I've seen, doesn't seem worth using uboot - as much as anything the binary blob that the GPU starts up from sets up everything needed to get the kernel up and running - so no point to running uboot.
djdjdjole
Re: RFS building
Mon Dec 17, 2012 4:21 pm
Well, I was thinking about u-boot because it enables me (I think) to work from NFS, which I found to be usefull during RFS building. Or maybe it is also possible with already mentioned blob, but I don't know how.
Regards
cellux
Re: RFS building
Wed Jan 09, 2013 1:21 pm
Check out this buildroot-based RPi system I'm currently working on:
https://github.com/cellux/rpi-buildroot
Today morning I got to the point where the (buildroot-built) RPi kernel boots and mounts the (also buildroot-built) root fs over NFS.
I had to switch to the rpi-3.6.y kernel branch to make this happen, as rpi-3.2.27 produced a seemingly dwc_otg-related kernel oops (also discussed in http://www.raspberrypi.org/phpBB3/viewt ... 71&t=18545)
Return to “Linux Kernel”
