G-Virus
Differences between a Generic Linux Kernel and a Raspberry Kernel
Thu Nov 02, 2017 12:14 am
Hello everyone. Could you guys tell me what the differences between the generic linux kernel which can be dowloaded from kernel.org and the official raspberry kernel? For example, can I use a default config file from the raspberry's kernel with the generic kernel?
Thanks in advance
The Traveler
Re: Differences between a Generic Linux Kernel and a Raspberry Kernel
Thu Nov 02, 2017 12:49 am
Kernels are compiled for different architectures and different capabilities. A kernel contains code that tells it how to interact with hardware, address memory, handle I/O and a number of other things. Config files are specific to the kernel they produce so you really don't want to try and use a config from one kernel to another.
Here's a starting point: https://www.linuxhint.com/linux-kernel- ... beginners/
Cheers.
Retired IT professional, C programmer and "beardie weirdie".
RPi interests: Developing an Infinite Improbability Drive
“Thinking outside of the box allows you to get rewards outside of your reach.” Matshona Dhliwayo
Thu Nov 02, 2017 12:51 am
What differences would you like?
Note:Having anything remotely humorous in your signature is completely banned on this forum.
G-Virus
Thu Nov 02, 2017 11:33 am
Cheers.
Thank you for the link. I just thought the kernels from kernel.org also contains #ifdef ARM ... #endif sections to specify hardware differences, because we can set ARCH variable and use toolchain so the kernel will be built for ARM architecture.
swahren
Sat Nov 11, 2017 2:19 pm
In short:
Raspberry Kernel = Official kernel + several improvements
It's possible to use a Raspberry Pi with the generic Linux kernel, but there are currently some missing features (Bluetooth, devicetree overlay) and boards (both Compute Modules, Sense hat). Also the Raspberry Pi kernel uses optimized drivers which will never be accepted for the upstream Kernel like the dwc_otg or the BCM2835 MMC driver.
No, please following these instructions.
feelslikeautumn
Sat Nov 11, 2017 3:35 pm
Why does a generic kernel fail to load (no progression from rainbow screen) when using the pi bootloader, but works via e.g. grub2?
swahren
Mon Nov 13, 2017 8:20 pm
This should work, maybe you need to specify the upstream device tree blob in the config.txt.
nimish
Tue Nov 14, 2017 12:27 am
Hmm, someone tried to get the bcm2835-sdhost driver into the mainline kernel but the main issue is that the existing driver is quite out of date. They dropped the thread a year ago as far as I can tell, but the maintainer was helping them with code reviews, so it's not like it couldn't be done.
swahren
Tue Nov 14, 2017 8:26 pm
There are multiple MMC drivers, which could be very confusing. Which driver is quite out of date (sdhci-bcm2835 or bcm2835 aka sdhost)?
sdhci-bcm2835 has been dropped in favor for sdhci-iproc (Linux 4.7). The sdhost has been merged in 4.12.
There is no need for another MMC driver since both interfaces are supported now. The only disadvantage is the missing DMA support in sdhci-iproc.
Return to “Linux Kernel”
