manicgeek
Kernel Source
Mon Apr 11, 2016 11:07 am
Why aren't there tarballs available for download?
Why am I being forced to install git when I have no use for it, just so I can get a copy of your specific kernel source?
Since 1995 I've been able to download linux kernel source code as a tarball, why doesn't Raspberry Pi conform to that?
r3d4
Re: Kernel Source
Mon Apr 11, 2016 11:35 am
manicgeek wrote:Why aren't there tarballs available for download?
@Hear : github.com/raspberrypi/linux ?
you can haz zip archive #github.com/raspberrypi/linux/archive/rpi-4.1.y.zip
its not tar.gz or even .xz but as long as some way to decode a 'zip' file is avalable that should suffice ,
... hopefully :| you are not on a pay per kb dial-up or mobile
manicgeek wrote:Since 1995 I've been able to download linux kernel source code as a tarball, why doesn't Raspberry Pi conform to that?
manicgeek
Re: Kernel Source
Mon Apr 11, 2016 12:15 pm
The zip options doesn't work, you end up with corrupted files.
Try it download it, unzip and and run a make mrproper. You'll end up with errors about one of the driver file makefiles having no rules to make mrproper.
procount
Re: Kernel Source
Mon Apr 11, 2016 2:47 pm
Replace .zip with .tar.gz in the URL, so:
#github.com/raspberrypi/linux/archive/rpi-4.1.y.tar.gz
manicgeek
Re: Kernel Source
Wed Apr 13, 2016 8:42 am
Thank you for that.
Return to “Linux Kernel”
