art6050
Building Kernel
Wed Feb 10, 2016 6:49 pm
I am trying to build kernel for raspberry according to https://www.raspberrypi.org/documentati ... uilding.md.
This command:
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- zImage modules dtbs
gives this error:
make[1]: `include/generated/mach-types.h' is up to date.  CHK     include/generated/bounds.h
  CC      arch/arm/kernel/asm-offsets.s
In file included from include/linux/spinlock.h:87:0,
                 from include/linux/seqlock.h:35,
                 from include/linux/time.h:5,
                 from include/uapi/linux/timex.h:56,
                 from include/linux/timex.h:56,
                 from include/linux/sched.h:19,
                 from arch/arm/kernel/asm-offsets.c:14:
./arch/arm/include/asm/spinlock.h:8:28: fatal error: linux/prefetch.h: No such file or directory
 #include <linux/prefetch.h>
compilation terminated.
make[1]: *** [arch/arm/kernel/asm-offsets.s] Error 1
make: *** [prepare0] Error 2
How can I fix it?
bodge99
Re: Building Kernel
Fri Apr 01, 2016 2:54 pm
I'm unsure if this is the problem... as I've not compiled a kernel for the Pi yet, but I remember something similar when I was looking at modding a bespoke (buggy) driver written for kernel 2.x to 4.2 .
The code was looking for a prefetch.h in /linux/prefetch.h whereas it should have been written as /include/linux/prefetch.h .
I seem to remember finding out that the driver's author had symlinked the relevant file as a "quick fix" aka bodge.
Hope this helps...
Bodge99.
neilo24
Re: Building Kernel
Thu Apr 21, 2016 9:57 am
I want to recompile the kernel with specific module related to camera application only and rest of the module which is un necessary want to exclude from the system. is it possible....??? if it is possible how it could be?? whats works i need to do??
what research required?? I have connect the RPi with modem and remotely access by means of xming and putty software. so basically my question is regarding optimisation and security.
dettus
Re: Building Kernel
Tue Jul 26, 2016 5:12 am
well, you could always try using a system builder.
for example, mine:
http://www.dettus.net/detLFS/
it is a selection of shell scripts. The first one is downloading the packages, the second one is building a cross compiler, and the third is compiling the kernel. You could try it out, maybe it helps?
Computer science is not about using a computer. It is about unleashing its powers.
dettus
Re: Building Kernel
Tue Jul 26, 2016 5:14 am
neilo24 wrote:Hello,
yes, it is not only very possible, but HIGHLY encouraged.
just look at the .config. there you see all the modules that are going to be compiled once you run make zImage. just set them to =n instead of =m, and you are going to save A LOT of compilation time. worst case scenario would be that your device XYZ does not work any more. don't worry, just recompile again.
Return to “Linux Kernel”
