marranxo
Re: Need advice with tuneled JPEG decoder + resizer
Mon Nov 26, 2018 11:01 am
6by9 wrote:
Thu Nov 08, 2018 5:34 pm
marranxo wrote:
Thu Nov 08, 2018 4:57 pm
Well, the sample https://github.com/6by9/userland/blob/h ... ode.c#L117 just throws error if you set WIDTH to 80 and HEIGHT to 60. Something should be wrong there.
I'm testing with latest firmware plus a couple of bits and the port_format_commit succeeds at 80x60. However I'm also on the 4.19 kernel and appear to be seeing VCHIQ issues so some of the output files are corrupt. Sorry, investigating those takes priority (and also explains some of the other issues I've been having).
Any good news about this issues? Thanks.
marranxo
Thu May 02, 2019 1:23 pm
Is there any fix to theese problems/bugs that hungs the gpu? If not, are you trying to adress the issue or is it stalled? Thanks.
Return to “OpenMAX”
