longo92
Contact: Website Skype
Setting encoder input port with color format opaque
Fri Sep 07, 2018 1:29 pm
Is possible to set the OpenMax encoder input with color format OMX_COLOR_FormatBRCMOpaque?
I need because i configure the encoding parameter of the camera video port with MMAL_ENCODING_OPAQUE (for mazimum perfromance), and then attached a callback on that port. So at each frame the callback is triggered, and the buffer should be passed to the OpenMax encoder.
6by9
Re: Setting encoder input port with color format opaque
Fri Sep 07, 2018 1:44 pm
MMAL_ENCODING_OPAQUE != OMX_COLOR_FormatBRCMOpaque They are not compatible.
Why are you trying to mix and match MMAL and IL? Chose one and stick with it. They both use the same components available on the GPU so use the video encoder under MMAL if you've chosen to use the MMAL camera component.
Return to “OpenMAX”
