Cumulonimbus
image_decoder doesn' t work with jpeg which has DRI marker segment
Mon Mar 05, 2018 4:48 am
I have some jpeg images which have DRI marker segment, and I try to use image_decoder component to decode them. But it returns OMX_ErrorStreamCorrupt error. The format is no supported by OpenMax in pi?
Any help would be appreciated.
6by9
Re: image_decoder doesn' t work with jpeg which has DRI marker segment
Mon Mar 05, 2018 11:31 am
(Duplicate of viewtopic.php?f=70&t=207061)
Checking the firmware code, there is some handling in there for DRI, but I'm not an expert on that particular code.
Can you post a JPEG which gives you issues somewhere so I can try it and see where it is throwing the error? It's not nice code to find where it bails out, so a test case would be useful.
Seeing as the JPEG encoder will insert restart markers and DRI, I'd be a little surprised if there is an issue on decode, but I don't have a sensible test case set up at the moment.
Cumulonimbus
Mon Mar 05, 2018 12:43 pm
Thanks for your reply.
https://www.dropbox.com/s/laiedgp8zmip60f/img.rar?dl=0
These images from a usb camera.
I have also tryed to remove DRI and RST markers, but it seems not easy.
Return to “OpenMAX”
