Looks like there is some kind of deadlock when looking at threads' backtraces (and as you can see most of the stack frames are broken) :
Thread 12 (Thread 0x705ff450 (LWP 524)):
#0 0x76cfa518 in do_futex_wait.constprop () from /lib/libpthread.so.0
#1 0x76cfa64c in __new_sem_wait_slow.constprop.0 () from /lib/libpthread.so.0
Cannot access memory at address 0x0
#2 0x769b307c in ?? () from /lib/libvcilcs.so
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 11 (Thread 0x71607450 (LWP 523)):
#2 0x76d5abd0 in vchiu_queue_pop () from /lib/libvchiq_arm.so
Cannot access memory at address 0x54
#3 0x769b3530 in ?? () from /lib/libvcilcs.so
Thread 10 (Thread 0x71e07450 (LWP 522)):
#0 0x76cf80b4 in pthread_cond_wait@@GLIBC_2.4 () from /lib/libpthread.so.0
#1 0x76d66e6c in ?? () from /lib/libvcos.so
Thread 9 (Thread 0x72cf4450 (LWP 521)):
#0 0x76a74990 in nanosleep () from /lib/libc.so.6
#1 0x72cf4910 in ?? ()
Thread 8 (Thread 0x734f4450 (LWP 520)):
#2 0x76d8d3ec in eglSwapBuffers () from /lib/libEGL.so
#3 0x76fc1340 in GE::BaseWindow::SwapBuffersBase (this=0x72300e58) at /home/drich/projects/GammaEngine/src/egl/BaseWindow.cpp:160
#4 0x745b74b0 in OpenGLES20Window::SwapBuffers (this=0x72300e50)
at /home/drich/projects/GammaEngine/backends/opengles20/src/OpenGLES20Window.cpp:146
#5 0x0005a2b0 in Stream::run (this=0x1616a0) at /home/drich/projects/BCFlight/controller_rpi/Stream.cpp:185
#6 0x00092494 in Thread::ThreadEntry (this=0x1616a0) at /home/drich/projects/BCFlight/libcontroller/Thread.cpp:121
#7 0x76cf1e1c in start_thread () from /lib/libpthread.so.0
#8 0x76aa7e60 in ?? () from /lib/libc.so.6
Thread 7 (Thread 0x73cf4450 (LWP 519)):
Cannot access memory at address 0x1
#0 0x76a9ea80 in poll () from /lib/libc.so.6
#1 0x73cf4910 in ?? ()
Thread 5 (Thread 0x74fff450 (LWP 517)):
Cannot access memory at address 0xbc
/opt/vc/bin/vcdbg log assert -f
1730622.085: assert( h ) failed; ../../../../../vcfw/rtos/common/rtos_common_mem.c::mem_unlock line 5149
1730622.134: assert( is_aligned_32(g_mgr.handles[handle].header) ) failed; ../../../../../vcfw/rtos/common/rtos_common_mem.c::get_header line 872
1730622.173: assert( pPrivate->allocator->valid(h, buffer->nAllocLen) ) failed; ../../../../../middleware/openmaxil/core/ril_top.c::process_ril_buffer line 2252
1730622.225: assert( is_aligned_32(g_mgr.handles[handle].header) ) failed; ../../../../../vcfw/rtos/common/rtos_common_mem.c::get_header line 872
1730622.269: assert( pPrivate->allocator->lock_count((RIL_MEM_HANDLE_T)buffer->pBuffer) == 0 ) failed; ../../../../../middleware/openmaxil/core/ril_top.c::process_ril_buffer line 2255
1730622.335: assert( is_aligned_32(g_mgr.handles[handle].header) ) failed; ../../../../../vcfw/rtos/common/rtos_common_mem.c::get_header line 872
1730640.165: assert( is_aligned_32(g_mgr.handles[handle].header) ) failed; ../../../../../vcfw/rtos/common/rtos_common_mem.c::get_header line 872
1730640.278: assert( h ) failed; ../../../../../vcfw/rtos/common/rtos_common_mem.c::lock_big_internal line 4856
1730640.337: assert( h && h->ref_count != 0 ) failed; ../../../../../vcfw/rtos/common/rtos_common_mem.c::lock_big_internal line 4857
1730640.421: assert( is_aligned_32(g_mgr.handles[handle].header) ) failed; ../../../../../vcfw/rtos/common/rtos_common_mem.c::get_header line 872
1730640.498: assert( h ) failed; ../../../../../vcfw/rtos/common/rtos_common_mem.c::lock_big_internal line 4856
1730640.614: assert( h && h->ref_count != 0 ) failed; ../../../../../vcfw/rtos/common/rtos_common_mem.c::lock_big_internal line 4857
/opt/vc/bin/vcdbg log msg -f
1730592.475: video_decode:24:EmptyThisBuffer(3e730480,11207,0->130)
1730592.498: video_decode:24: queueBuffer (input : 11207)
1730592.515: video_decode:24:qb RIL:2
1730592.559: video_decode:24:RIL: extract from fifo: len:11207 flags:118 time:0
1730592.594: video_decode:24:RIL: decoding 11207 bytes, 0us, flags 118, (cb:0x3e7c1400)
1730592.620: video_decode:24:RIL: asking for more
1730592.822: video_decode:24:cb:consumed_input_buffer(3e730480,0b,0f) RIL:2
1730600.261: video_decode:24:RIL:cb:entered with buffer = 0x3e7c9d50, frame_info = 0x3e7d9564, status = 0, cb= 0x3e7c1400
1730600.284: video_decode:24:RIL:cb:next_frame_time:0
1730600.357: video_decode:24:RIL:cb:IDR time:0, cb:0x3e7c1400, ar:0/0, crop:0x0 1024x576, interval:16666666, interlace:0,0,0
1730600.411: video_decode:24:RIL:output dec_frames_full:3e7c3770 out:0
1730600.460: decode: display frame 3e7c9d50 T=0 sts=0
1730600.486: video_render:25:RIL:display_image 3e7c9d50 state 4
1730600.571: video_render:25:RIL: update arrived, dst 912 x 914
1730600.609: video_render:25:RIL: cb:0 tx:-1 cb=[img:3e7c9d10 t:-1] inuse=[10]
1730600.672: video_render:25:RIL: doing update on dn:0 img:3e7c9d50,other fs:0 tx:2 1024x576-(24x83)912x914
1730600.849: video_render:25:RIL:return omx buffers:free 0
1730600.879: video_render:27:RIL:display_image 3e7c9d50 state 4
1730600.953: video_render:27:RIL: update arrived, dst 912 x 914
1730600.991: video_render:27:RIL: cb:0 tx:-1 cb=[img:3e7c9d10 t:-1] inuse=[10]
1730601.051: video_render:27:RIL: doing update on dn:0 img:3e7c9d50,other fs:0 tx:2 1024x576-(984x83)912x914
1730601.208: video_render:27:RIL:return omx buffers:free 0
1730601.245: video_decode:24:RIL: disp_cb passed 3e7c9d50/0/0x118
1730605.496: video_decode:24:EmptyThisBuffer(3e730480,2821,0->130)
1730605.515: video_decode:24: queueBuffer (input : 2821)
1730605.528: video_decode:24:qb RIL:2
1730605.567: video_decode:24:RIL: extract from fifo: len:2821 flags:118 time:0
1730605.600: video_decode:24:RIL: decoding 2821 bytes, 0us, flags 118, (cb:0x3e7c1cf8)
1730605.624: video_decode:24:RIL: asking for more
1730605.738: video_decode:24:cb:consumed_input_buffer(3e730480,0b,0f) RIL:2
1730606.188: video_render:25:RIL:cb:freeing cb:0 b:3e7c9d10 t:-1
1730606.204: video_render:25:RIL:cb:sending 3e7c9d10 to disp queue
1730606.229: video_render:25:RIL:cb:use=[00]
1730606.258: video_render:27:RIL:cb:freeing cb:0 b:3e7c9d10 t:-1
1730606.278: video_render:27:RIL:cb:sending 3e7c9d10 to disp queue
1730606.297: video_render:27:RIL:cb:use=[00]
1730606.329: video_render:25:RIL:release_images:releasing 3e7c9d10
1730606.350: video_render:25:RIL:return omx buffers:free 0
1730606.379: video_render:27:RIL:release_images:releasing 3e7c9d10
1730606.412: video_render:27:RIL:return omx buffers:free 0
1730611.861: video_decode:24:RIL:cb:entered with buffer = 0x3e7c9d90, frame_info = 0x3e7d9564, status = 0, cb= 0x3e7c1cf8
1730611.878: video_decode:24:RIL:cb:next_frame_time:0
1730611.949: video_decode:24:RIL:cb:P time:0, cb:0x3e7c1cf8, ar:0/0, crop:0x0 1024x576, interval:16666666, interlace:0,0,0
1730611.997: video_decode:24:RIL:output dec_frames_full:3e7c37e4 out:0
1730612.048: decode: display frame 3e7c9d90 T=0 sts=0
1730612.074: video_render:25:RIL:display_image 3e7c9d90 state 4
1730612.156: video_render:25:RIL: update arrived, dst 912 x 914
1730612.191: video_render:25:RIL: cb:0 tx:-1 cb=[img:3e7c9d50 t:-1] inuse=[10]
1730612.254: video_render:25:RIL: doing update on dn:0 img:3e7c9d90,other fs:0 tx:2 1024x576-(24x83)912x914
1730612.438: video_render:25:RIL:return omx buffers:free 0
1730612.470: video_render:27:RIL:display_image 3e7c9d90 state 4
1730612.543: video_render:27:RIL: update arrived, dst 912 x 914
1730612.581: video_render:27:RIL: cb:0 tx:-1 cb=[img:3e7c9d50 t:-1] inuse=[10]
1730612.637: video_render:27:RIL: doing update on dn:0 img:3e7c9d90,other fs:0 tx:2 1024x576-(984x83)912x914
1730612.792: video_render:27:RIL:return omx buffers:free 0
1730612.825: video_decode:24:RIL: disp_cb passed 3e7c9d90/0/0x118
1730617.391: video_decode:24:EmptyThisBuffer(3e730480,1734,0->130)
1730617.413: video_decode:24: queueBuffer (input : 1734)
1730617.425: video_decode:24:qb RIL:2
1730617.468: video_decode:24:RIL: extract from fifo: len:1734 flags:118 time:0
1730617.501: video_decode:24:RIL: decoding 1734 bytes, 0us, flags 118, (cb:0x3e7c1b54)
1730617.573: video_decode:24:RIL: asking for more
1730619.032: video_decode:24:EmptyThisBuffer(3e730480,0,0->130)
1730619.214: video_decode:24: queueBuffer (input : 0)
1730619.280: video_decode:24:saveBuffer(130,3e730480) Held:1
1730619.328: video_decode:24:cb:consumed_input_buffer(3e730480,0b,0f) RIL:2
1730620.371: video_decode:24:EmptyThisBuffer(3e730480,9,0->130)
1730620.420: video_decode:24: queueBuffer (input : 9)
1730620.445: video_decode:24:qb RIL:2
1730620.507: video_decode:24:RIL: extract from fifo: len:9 flags:118 time:0
1730620.550: video_decode:24:RIL: decoding 9 bytes, 0us, flags 118, (cb:0x3e7c1898)
1730620.589: video_decode:24:RIL: asking for more
1730620.673: video_decode:24:timer retry on 130
1730620.742: video_decode:24:sendBuffers(130):3e730480 9/118
1730621.018: video_decode:24:RIL: extract from fifo: len:9 flags:118 time:0
1730621.078: video_decode:24:RIL: decoding 9 bytes, 0us, flags 118, (cb:0x3e7c1780)
1730621.119: video_decode:24:RIL: asking for more
1730621.413: video_decode:24:cb:consumed_input_buffer(3e730480,0b,0f) RIL:3
1730622.407: video_decode:24:cb:consumed_input_buffer(3e730480,0b,0f) RIL:2
1730622.848: video_render:25:RIL:cb:freeing cb:0 b:3e7c9d50 t:-1
1730622.868: video_render:25:RIL:cb:sending 3e7c9d50 to disp queue
1730622.894: video_render:25:RIL:cb:use=[00]
1730622.924: video_render:27:RIL:cb:freeing cb:0 b:3e7c9d50 t:-1
1730622.939: video_render:27:RIL:cb:sending 3e7c9d50 to disp queue
1730622.964: video_render:27:RIL:cb:use=[00]
1730622.996: video_render:25:RIL:release_images:releasing 3e7c9d50
1730623.019: video_render:25:RIL:return omx buffers:free 0
1730623.047: video_render:27:RIL:release_images:releasing 3e7c9d50
1730623.082: video_render:27:RIL:return omx buffers:free 0
1730626.638: video_decode:24:RIL:cb:entered with buffer = 0x3e7c9d10, frame_info = 0x3e7d9564, status = 0, cb= 0x3e7c1b54
1730626.662: video_decode:24:RIL:cb:next_frame_time:0
1730626.733: video_decode:24:RIL:cb:P time:0, cb:0x3e7c1b54, ar:0/0, crop:0x0 1024x576, interval:16666666, interlace:0,0,0
1730626.788: video_decode:24:RIL:output dec_frames_full:3e7c3858 out:0
1730626.842: decode: display frame 3e7c9d10 T=0 sts=0
1730626.869: video_render:25:RIL:display_image 3e7c9d10 state 4
1730626.955: video_render:25:RIL: update arrived, dst 912 x 914
1730626.998: video_render:25:RIL: cb:0 tx:-1 cb=[img:3e7c9d90 t:-1] inuse=[10]
1730627.057: video_render:25:RIL: doing update on dn:0 img:3e7c9d10,other fs:0 tx:2 1024x576-(24x83)912x914
1730627.231: video_render:25:RIL:return omx buffers:free 0
1730627.261: video_render:27:RIL:display_image 3e7c9d10 state 4
1730627.341: video_render:27:RIL: update arrived, dst 912 x 914
1730627.377: video_render:27:RIL: cb:0 tx:-1 cb=[img:3e7c9d90 t:-1] inuse=[10]
1730627.435: video_render:27:RIL: doing update on dn:0 img:3e7c9d10,other fs:0 tx:2 1024x576-(984x83)912x914
1730627.591: video_render:27:RIL:return omx buffers:free 0
1730627.623: video_decode:24:RIL: disp_cb passed 3e7c9d10/0/0x118
1730639.527: video_render:25:RIL:cb:freeing cb:0 b:3e7c9d90 t:-1
1730639.543: video_render:25:RIL:cb:sending 3e7c9d90 to disp queue
1730639.568: video_render:25:RIL:cb:use=[00]
1730639.603: video_render:27:RIL:cb:freeing cb:0 b:3e7c9d90 t:-1
1730639.632: video_render:27:RIL:cb:sending 3e7c9d90 to disp queue
1730639.664: video_render:27:RIL:cb:use=[00]
1730639.720: video_render:25:RIL:release_images:releasing 3e7c9d90
1730639.758: video_render:25:RIL:return omx buffers:free 0
1730639.793: video_render:27:RIL:release_images:releasing 3e7c9d90
1730639.836: video_render:27:RIL:return omx buffers:free 0
If you see anything relevant that can help me...
Edit: I just discovered that the top-right low power icon (yellow lightning) is continuously displayed (was hidden by HDMI overscan), can it be the cause of all of this ?
EDIT 2 : Okay I have a different bug now, my thread is not blocked, but the video_render frame is freezed (it seems that the video_decode does not output anything)
log msg is tatally different, :
2364351.320: video_decode:4:qb RIL:304001
2364351.355: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364369.618: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364374.961: video_decode:4:EmptyThisBuffer(3e7301a0,8400,0->130)
2364374.982: video_decode:4: queueBuffer (input : 8400)
2364375.003: video_decode:4:qb RIL:304002
2364375.039: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364378.635: video_decode:4:EmptyThisBuffer(3e7301a0,3763,0->130)
2364378.657: video_decode:4: queueBuffer (input : 3763)
2364378.674: video_decode:4:qb RIL:304003
2364378.707: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364389.602: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364397.856: video_decode:4:EmptyThisBuffer(3e7301a0,2800,0->130)
2364397.877: video_decode:4: queueBuffer (input : 2800)
2364397.895: video_decode:4:qb RIL:304004
2364397.928: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364400.232: video_decode:4:EmptyThisBuffer(3e7301a0,41,0->130)
2364400.252: video_decode:4: queueBuffer (input : 41)
2364400.269: video_decode:4:qb RIL:304005
2364400.302: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364400.680: video_decode:4:EmptyThisBuffer(3e7301a0,9,0->130)
2364400.699: video_decode:4: queueBuffer (input : 9)
2364400.713: video_decode:4:qb RIL:304006
2364400.745: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364414.058: video_decode:4:EmptyThisBuffer(3e7301a0,8520,0->130)
2364414.078: video_decode:4: queueBuffer (input : 8520)
2364414.095: video_decode:4:qb RIL:304007
2364414.135: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364426.468: video_decode:4:EmptyThisBuffer(3e7301a0,4908,0->130)
2364426.489: video_decode:4: queueBuffer (input : 4908)
2364426.507: video_decode:4:qb RIL:304008
2364426.540: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364438.510: video_decode:4:EmptyThisBuffer(3e7301a0,3165,0->130)
2364438.531: video_decode:4: queueBuffer (input : 3165)
2364438.547: video_decode:4:qb RIL:304009
2364438.580: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364439.006: video_decode:4:EmptyThisBuffer(3e7301a0,41,0->130)
2364439.026: video_decode:4: queueBuffer (input : 41)
2364439.060: video_decode:4:qb RIL:304010
2364439.096: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364449.617: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364452.594: video_decode:4:EmptyThisBuffer(3e7301a0,10137,0->130)
2364452.617: video_decode:4: queueBuffer (input : 10137)
2364452.633: video_decode:4:qb RIL:304011
2364452.668: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364465.255: video_decode:4:EmptyThisBuffer(3e7301a0,3544,0->130)
2364465.276: video_decode:4: queueBuffer (input : 3544)
2364465.293: video_decode:4:qb RIL:304012
2364465.326: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364477.118: video_decode:4:EmptyThisBuffer(3e7301a0,3201,0->130)
2364477.138: video_decode:4: queueBuffer (input : 3201)
2364477.156: video_decode:4:qb RIL:304013
2364477.189: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364477.872: video_decode:4:EmptyThisBuffer(3e7301a0,41,0->130)
2364477.891: video_decode:4: queueBuffer (input : 41)
2364477.907: video_decode:4:qb RIL:304014
2364477.940: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364478.352: video_decode:4:EmptyThisBuffer(3e7301a0,9,0->130)
2364478.372: video_decode:4: queueBuffer (input : 9)
2364478.388: video_decode:4:qb RIL:304015
2364478.421: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364489.601: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364491.878: video_decode:4:EmptyThisBuffer(3e7301a0,8631,0->130)
2364491.900: video_decode:4: queueBuffer (input : 8631)
2364491.916: video_decode:4:qb RIL:304016
2364491.951: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364504.754: video_decode:4:EmptyThisBuffer(3e7301a0,3817,0->130)
2364504.775: video_decode:4: queueBuffer (input : 3817)
2364504.793: video_decode:4:qb RIL:304017
2364504.834: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364517.279: video_decode:4:EmptyThisBuffer(3e7301a0,2648,0->130)
2364517.297: video_decode:4: queueBuffer (input : 2648)
2364517.315: video_decode:4:qb RIL:304018
2364517.351: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364518.336: video_decode:4:EmptyThisBuffer(3e7301a0,542,0->130)
2364518.357: video_decode:4: queueBuffer (input : 542)
2364518.372: video_decode:4:qb RIL:304019
2364518.406: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364518.834: video_decode:4:EmptyThisBuffer(3e7301a0,41,0->130)
2364518.853: video_decode:4: queueBuffer (input : 41)
2364518.873: video_decode:4:qb RIL:304020
2364518.906: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364519.317: video_decode:4:EmptyThisBuffer(3e7301a0,9,0->130)
2364519.335: video_decode:4: queueBuffer (input : 9)
2364519.349: video_decode:4:qb RIL:304021
2364519.383: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364529.605: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364532.885: video_decode:4:EmptyThisBuffer(3e7301a0,8616,0->130)
2364532.904: video_decode:4: queueBuffer (input : 8616)
2364532.921: video_decode:4:qb RIL:304022
2364532.953: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
2364545.665: video_decode:4:EmptyThisBuffer(3e7301a0,5091,0->130)
2364545.684: video_decode:4: queueBuffer (input : 5091)
2364545.700: video_decode:4:qb RIL:304023
2364545.732: video_decode:4:RIL:output dec_frames_full:3e7c67fc out:0
Don't know if another backtrace can help :
Thread 12 (Thread 0x705ff450 (LWP 328)):
#0 0x76aa0bac in ioctl () from /lib/libc.so.6
#1 0x76d58cac in vchiq_queue_message () from /lib/libvchiq_arm.so
#2 0x769b3028 in ?? () from /lib/libvcilcs.so
Thread 11 (Thread 0x70fdb450 (LWP 327)):
Cannot access memory at address 0x8
Thread 10 (Thread 0x71bb4450 (LWP 326)):
Thread 9 (Thread 0x72cf4450 (LWP 325)):
Thread 8 (Thread 0x734f4450 (LWP 324)):
#0 0x76a46d00 in ?? () from /lib/libc.so.6
#1 0x76c4c28c in std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string() () from /lib/libstdc++.so.6
#2 0x00000258 in ?? ()
Thread 7 (Thread 0x73cf4450 (LWP 323)):
Thread 6 (Thread 0x744f4450 (LWP 322)):
#1 0x744f4910 in ?? ()
Thread 5 (Thread 0x74fff450 (LWP 321)):
vcgencmd version
Nov 16 2016 12:27:23
Copyright (c) 2012 Broadcom
version 14ca844c69c2883572677a5cd7b02443eb653e4e (clean) (release)
