mdoe
OMX_VIDEO_PARAM_QUANTIZATIONTYPE
Thu Sep 22, 2016 6:07 pm
I was wondering if anyone is able to tell me if OMX_VIDEO_PARAM_QUANTIZATIONTYPE is available to use with AVC encoding? I gather from snippets on other forums that with rate control disabled, OMX_IndexParamVideoQuantization can be used for QpI and QpP , but before I went down that road, knowing that some options aren't available, I thought I'd ask as I can't find anything definitive.
Thanks!
M
6by9
Re: OMX_VIDEO_PARAM_QUANTIZATIONTYPE
Thu Sep 22, 2016 8:21 pm
It looks like it is supported by video_encode.
Do note in the docs (raw, or pretty versions).
Query / set the quantization parameters for P and I frames. Only used if rate control has been disabled.
It will reject the parameter if nQpB is != 0.
Despite being called a param, OMX_IndexParamBrcmVideoEncodeQpP appears to be settable dynamically to vary QpP. Likewise OMX_IndexParamBrcmVideoInitialQuant for QpI.
They all affect the same internal structure, just that the those two will also poke the codec if it is opened.
mdoe
Fri Sep 23, 2016 7:53 am
Thanks 6by9 :D
Can I bounce an idea off you please? I've been playing with the quantization parameters in Intels Quicksync hardware encoder, I found that depending on source input you can more or less constrain the resulting bitrate of the output stream. That is, when you know what type of input (action/still) you have, you set the Q accordingly and you tend to get a consistent bit rate over the duration. Variable, but within a comfortable average range.
My thought was that I could tweak the quantization when encoding with the Rpi to better constrain output, as sometimes it runs away with the bitrate causing huge stream killing spikes, which I assume is down to some default Q setting in the variable bitrate.
Does that sound reasonable?
6by9
Fri Sep 23, 2016 7:30 pm
It sounds possible, but not something I could say how well it would work.
Return to “OpenMAX”
