madCoder24
OpenMax Video Split Screen
Fri Apr 29, 2016 2:34 pm
I am curious if OpenMax is able to do split screen similar to a video game. Would it require multiple components for each individual stream? I assume it would since each stream would be different. I noticed that OpenMax has a video_splitter component. Would this functionality be performed with that component?
6by9
Re: OpenMax Video Split Screen
Fri Apr 29, 2016 8:44 pm
Video splitter splits one stream to feed more than one destination. It does not merge multiple inputs.
It sounds like you just want to create multiple video_render components with different display regions.
madCoder24
Fri Apr 29, 2016 10:53 pm
If there are multiple video_render components, would the ports ever conflict? If that is the case then would each port need to be disabled and re-enabled for each render component individually. This way the render component would be able to render it's individual stream. I hope I am on the right track, but I feel I am off base.
Thanks for the answers.
6by9
Sat Apr 30, 2016 8:11 pm
No conflict as you always reference a component handle and port number. Each video render will have a different handle, and they all perform totally independently when it comes to port and component states.
madCoder24
Mon May 09, 2016 6:03 pm
Thanks for the information. This is helpful. So the individual video_render components will each be part of their own video pipeline? Each pipeline will have it's own video_decode components which send data to their appropriate video_render components. That makes sense.
Return to “OpenMAX”
