mihalop
OpenMAX blending of video and alpha mask
Wed Apr 20, 2016 12:50 pm
I am trying to modify omxplayer to allow for a alpha/transparency mask for videos. In the optimal scenario, you would specify multiple " --transparent 'x1 y1 x2 y2' " options to allow for specifying transparent regions within the playback viewport defined by "--win".
I am digging into omxplayer code and OpenMAX IL spec. As far as I have understood up to now, the only way to achieve this is by preparing the mask in a buffer and using OMX_IndexConfigCommonColorBlend or OMX_IndexConfigCommonPlaneBlend to blend the the two components outputs.
Since I have zero experience with OpenMAX, is the above correct? Would this affect video playback performance/load? Has anyone done anything similar?
Yodeck - Digital Signage on the Raspberry Pi
Free Raspberry Pi 3 Player for all screens on Annual Plan
dom
Re: OpenMAX blending of video and alpha mask
Wed Apr 20, 2016 1:15 pm
OMX_IndexConfigCommonPlaneBlend and OMX_IndexConfigCommonColorBlend are not supported.
You can check the supported parameters for each component here: http://home.nouwen.name/RaspberryPi/doc ... omponents/
Do you really need transparency in the video?
The more usual scenario is to create a RBGA overlay on top of the video which has transparency where you want the video to show (e.g. as Kodi does for GUI overlay).
6by9
Wed Apr 20, 2016 1:27 pm
Adding RGBA support to video_render is on my list of things to do, but it's a long list for the amount of spare time I have.
Not sure if that really helps you that much in this case anyway.
dividuum
Sat Apr 23, 2016 1:54 pm
One way to do this (for up to 720p videos) is to render the video into an opengl texture, then combine that texture with transparency mask from other texture using a shader. I've successfully done that with my software info-beamer. But 1080p isn't possible that way as the memory bandwidth (?) isn't enough for that.
gl.setup(1920, 1080)
local video = resource.load_video "video.mp4"
local image = resource.load_image "image.png"
local shader = resource.create_shader[[
    uniform sampler2D Texture;
    uniform sampler2D Transparency;
    varying vec2 TexCoord;
    void main() {
        gl_FragColor = texture2D(Texture, TexCoord) * texture2D(Transparency, TexCoord).a;
function node.render()
    shader:use{
        Transparency = image;
    video:draw(0, 0, WIDTH, HEIGHT)
end
Example output: http://i.imgur.com/INoSclW.jpg
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
mihalop
Mon Apr 25, 2016 8:25 pm
@dom:
Thanks for the link, thought that the Pi had the full OpenMAX spec supported. An overlay won't do, I am trying to show things rendered behind the video, on regions of the Linux framebuffer.
@6by9:
Indeed it won't help much, usually videos do not have an alpha channel and the transparent regions change in each playback.
@dividuum:
The end result would be exactly what I need. I had this solution in mind, using egl_render, but did not look into it since I thought it would cause hiccups on playback. I also use OpenGL for other animations and it would probably not take the load. And, also, 1080p videos are required. Have you tried that on a Pi 3? Perhaps it performs better.
Overall, I can't seem to find a feasible way to achieve this, so I will probably revert to rendering the X content in a buffer in arm space and copying it to a mmapped GPU texture. Using glTexSubImage2D is just too slow, can't get over 15-20 fps :-(
dividuum
Mon Apr 25, 2016 10:28 pm
mihalop wrote:The end result would be exactly what I need. I had this solution in mind, using egl_render, but did not look into it since I thought it would cause hiccups on playback. I also use OpenGL for other animations and it would probably not take the load. And, also, 1080p videos are required. Have you tried that on a Pi 3? Perhaps it performs better.
A bit, but combining two 1920x1080 textures (the mask image and the video rendered into a texture) using a shader is still too much when running at 60fps. It's fast enough for 30fps but the overall output feels jerky in that case.
mihalop wrote:Overall, I can't seem to find a feasible way to achieve this, so I will probably revert to rendering the X content in a buffer in arm space and copying it to a mmapped GPU texture. Using glTexSubImage2D is just too slow, can't get over 15-20 fps :-(
What's the best way of doing that? I remember investigating that a while ago but couldn't find a way to do that. Any hints welcome.
mihalop
Fri May 27, 2016 5:19 pm
I am using the mailbox interface to get lock on a GPU memory allocations. I also get a ARM-space pointer to it and have mmapped /dev/mem. I get the CPU to directly copy raster data into GPU space, and it works fine with DispmanX resources. But I need to use a GL texture. Just today I found out that textures are stored in Tile Format or Linear-tile Format.
@dom:
Saw in VideoCore IV docs that there is a Texture Datatype of RGBA32R, "Raster format 8-bit per channel red, green, blue, alpha", which is exactly what I need in order to avoid tiling/swizzling huge overhead. But as far as I can see, this is not exposed by the firmware. Why? Could this be added?
Return to “OpenMAX”
