pmaersk
BGRA to screen, best method?
Thu Mar 03, 2016 4:01 pm
Hi.
I've searched around a little to find some sample code to display a stream of images (in BGRA format) on screen as fullscreen.
What is the best way, in terms of lowest load on cpu/system, to display a BGRA formatted picture as fullscreen?
There seem to be a method involving OpenMax/ilclient and setting up components. The end component may probably be the video_render (port 90), but it may not accept BGRA. In that case a image decode component (port 320/321) may be needed, if it can convert from BGRA to whatever video_render accepts. Does anyone know some example code to look at?
Another method may be to use EGL and define a viewport, clear color, define a rectangular vertex and bind a texture transferring an image to it, if Raspberry Pi's EGL version of glBindTexture() accepts BGRA images.
Which method can be expected to provide the lowest CPU/System overhead?
Best regards
Peter MM
Author of Snowmix. Open Source Videomixer.
6by9
Re: BGRA to screen, best method?
Thu Mar 03, 2016 6:09 pm
video_render not supporting BGRA (or any format with per pixel A) is on my radar to look into.
image_decode is image codec decode (eg JPEG, PNG, GIF), nothing to do with image format conversions.
EGL is an option, but not one I know enough detail on what is possible.
Lightest weight option is to talk to dispmanx directly. It's not the easiest API, but there are a number of internet posts that probably take the guesswork out of it for you. There's also an example in the userland repo at https://github.com/raspberrypi/userland ... o_dispmanx
pmaersk
Thu Mar 03, 2016 6:38 pm
Hi 6by9
Thanks for reply.
6by9 wrote:video_render not supporting BGRA (or any format with per pixel A) is on my radar to look into.
The camera component claim to support RGBA and BGRA (among others), but only RGBA seems to come out of it, so what a component claim does not always hold true. So the image_decode can only decode compressed images. What about the resize (port 60 and 61) component? I read somewhere that that module can convert image formats. I hope to be able to use that to convert camera RGBA frames to BGRA, but haven't figured out yet how.
6by9 wrote:EGL is an option, but not one I know enough detail on what is possible.
Should be possible to create a display and bind a texture thus displaying it, but it requires dispmanx. Should be straightforward although I'm not sure that is the most lightweight option. And I am not sure the glBindTexture() will support BGRA on a Pi. glBindTexture() should, but maybe not on this platform.
6by9 wrote:Lightest weight option is to talk to dispmanx directly. It's not the easiest API, but there are a number of internet posts that probably take the guesswork out of it for you. There's also an example in the userland repo at https://github.com/raspberrypi/userland ... o_dispmanx
That example seems straight forward. However wonder if the dispmanx solution (without EGL) can take a BGRA image and not just pixel by pixel by pixel ... Do you know?
The reason for using BGRA is that I am using it in Snowmix (OSS video mixer), that heavily uses Cairo Graphics and Cairo Graphics uses BGRA internally.
Thanks for the help
Peter Maersk-Moller
6by9
Thu Mar 03, 2016 7:04 pm
pmaersk wrote:The camera component claim to support RGBA and BGRA (among others), but only RGBA seems to come out of it, so what a component claim does not always hold true.
It should hold true.
The A from the camera will always be 0, but it is a 32bit packing. I'm fairly certain that I checked that through V4L2.
pmaersk wrote:So the image_decode can only decode compressed images. What about the resize (port 60 and 61) component? I read somewhere that that module can convert image formats. I hope to be able to use that to convert camera RGBA frames to BGRA, but haven't figured out yet how.
resize can convert between some formats, but it's a great solution as it will also be trying to resize at the same time.
video_splitter may be a better bet as it can do some conversions - I couldn't give you a list off the top of my head though.
None of these help you much though as they'll all still deliver images that you'll try to render through video_render, and that can't cope with per pixel alpha. I recall looking into it for a PiCamera bug and just finding there were a couple of places that just always set a global alpha which overrode the per pixel channel.
As I say, I just don't know.
The reason for using BGRA is that I am using it in Snowmix (OSS video mixer), that heavily uses Cairo Graphics and Cairo Graphics uses BGRA internally.[/quote]
Dispmanx is the lowest level API down onto the composition hardware. video_render and EGL will both use that for getting images onto the video output. The Linux frame buffer is also just another dispmanx layer. It should take almost any ordering of R, G, B, and A, although there are some combinations that won't have an enum brought out because they're too unlikely.
Or am I misreading you and you don't really have per pixel alpha that you care about, but need 32bit/pixel packing? In which case video_render I thought video_render could do it.
Return to “OpenMAX”
