marranxo
hello_jpeg not working on Raspberry 2 B+
Wed Dec 16, 2015 3:32 pm
Hi all,
I'm working in a project that must decode several jpeg images per second. I started with opencv until I realized that it overloads the CPU and started to search for a more acurate solution using GPU instructions and that's why I'm starting with OpenMAX. I've compiled the sources with the rebuild.sh script succesfully but when I run the binary several error take place:
Did not receive executing stat -1
No EOS event on image resizer -1
In addition the output buffer seems to contain random data.
Any tips? Thanks.
dickon
Re: hello_jpeg not working on Raspberry 2 B+
Wed Dec 16, 2015 4:32 pm
Often, the answer is to give more RAM to the GPU. What's your current split?
marranxo
Thu Dec 17, 2015 8:27 am
I set gpu mem to 256. Also free -m displays 735 mem / 99 swap. Could xrdp cause memory race conditions?
PeterO
Thu Dec 17, 2015 9:40 am
marranxo wrote:. Could xrdp cause memory race conditions?
Since you mention xrdp , are you using the PI remotely (e.g. logging in over the network from a PC) ?
PeterO
marranxo
Thu Dec 17, 2015 10:25 am
Yes, I was working with the raspberry from a windows pc with xrdp until yesterday, now with vncserver.
PeterO
Thu Dec 17, 2015 10:38 am
I think your problem is that the demo is using the GPU, and that will only display on the on board devices (comp/HDMI/LCD).
PeterO
JPB-HK
Tue Jan 26, 2016 3:41 am
I am running into the same problem.
  • * Running Raspberry Pi 2 with Raspberry Pi 7" display
    * Boot into command line mode to the 7" display (rotated with lcd_rotate=2)
    * gpu_mem=256
I get the errors:
No EOS event on image decoder -1
Not sure what I am doing wrong.
Thanks for any help!
NCR 310 - ZX81 - Apple II+ - Dell/Intel - Mac mini... Raspberry Pi!
Return to “OpenMAX”
