playing .mp4 files with hello_video
Posted: Tue Jul 17, 2012 11:13 am
by av2kk
I am trying to modify hello_video example to play .mp4 files. I tried changing the following line in video.c
format.eCompressionFormat = OMX_VIDEO_CodingAVC;
to
format.eCompressionFormat = OMX_VIDEO_CodingMPEG4;
but the program hangs when trying to open .mp4 .
On investigation I found it is failing the follwing test.
ilclient_enable_port_buffers(video_decode, 130, NULL, NULL, NULL) == 0)
Thanks for any help.
Krish
Re: playing .mp4 files with hello_video
Posted: Tue Jul 17, 2012 3:44 pm
by dom
OMX_VIDEO_CodingMPEG4 is the encoded video format of MPEG4. Nothing to do with a container format of mp4 (which most likely is still encoded as AVC/H264).
To play video inside a container like mp4 you will need another library that parses containers, like libavcodec.
Look at omxplayer
https://github.com/huceke/omxplayer/
Posted: Wed Jul 18, 2012 10:36 am
by av2kk
Thanks Dom.
While I am trying to work on the OMXplayer code, can you suggest any link from where I can down load the OMXPlayer.bin so that I can carry on with my main project which is to play audio video files based on GPS input. I intend to use the OMXPlayer.bin in my program using system("./OMXPlayer <file name>");
Krish
Posted: Wed Jul 18, 2012 12:29 pm
by dom
If you update to new image:
http://www.raspberrypi.org/archives/1605
omxplayer is preinstalled.
Posted: Wed Jul 18, 2012 2:32 pm
by marosg
I would like to try to make some changes to omxplayer for myself, to see how these things work. It is long time since I did some programming. Fortunately omxplayer is written in C. Can you suggest some easy to follow steps how to get omxplayer source and compile it on Pi myself ? I have no idea how to do it properly, how to get all things that are needed.
Thank you
Posted: Thu Jul 19, 2012 12:29 pm
by av2kk
I got the latest Debian (15-7-2012) and tried omxplayer. but the display shows up the first frame for a second and the program quits with a have a nice day!
=============== terminal response
$omxplayer -ohdmi test.mp4
file : test.mp4 reult 13 format mov,mp4,m4a,3gp,3g2,mj2 audio streams 1 video streams 1 chapters 0 subtitles 0
Video codec omx-h264 width 640 height 296 profile 578 fps 23.976025
Audio codec aac channels 2 samplerate 44100 bitspersample 16
have a nice day ;)
the omxplayer.log file has a number of entries .The last lines are (for some unknwon reason I am unable to attach the omxplayer.log file to the post)
00:00:00 T:0 DEBUG: COMXAudio::Initialize Input bps 16 samplerate 44100 channels 2 device hdmi buffer size 352800 bytes per second 176400 passthrough 0 hwdecode 0
00:00:00 T:0 DEBUG: OMXThread::Create - Thread with id 1163154528 started
00:00:00 T:0 DEBUG: pcm->nPortIndex : 232
00:00:00 T:0 DEBUG: pcm->eNumData : 0
00:00:00 T:0 DEBUG: pcm->eEndian : 1
00:00:00 T:0 DEBUG: pcm->bInterleaved : 1
00:00:00 T:0 DEBUG: pcm->nBitPerSample : 16
00:00:00 T:0 DEBUG: pcm->ePCMMode : 0
00:00:00 T:0 DEBUG: pcm->nChannels : 2
00:00:00 T:0 DEBUG: pcm->nSamplingRate : 44100
00:00:00 T:0 DEBUG: OMX_AUDIO_ChannelLF
00:00:00 T:0 DEBUG: OMX_AUDIO_ChannelRF
00:00:00 T:0 DEBUG: pcm->nPortIndex : 100
00:00:00 T:0 ERROR: OMXPlayerAudio::WaitCompletion - wait for eos timed out
00:00:00 T:0 DEBUG: OMXThread::Run - Exited thread with id 1153860704
00:00:00 T:0 DEBUG: OMXThread::StopThread - Thread stopped
00:00:00 T:0 DEBUG: OMXThread::Run - Exited thread with id 1163154528
00:00:00 T:0 ERROR: COMXCoreComponent::DecoderEventHandler OMX.broadcom.audio_mixer - OMX_ErrorPortUnpopulated (0), cannot parse input stream
Does it mean something is wrong with the test.mp4 file. I down loaded this movie trailer from the web and renamed it.
Posted: Thu Jul 19, 2012 4:21 pm
by KenT
av2kk wrote:I got the latest Debian (15-7-2012) and tried omxplayer. but the display shows up the first frame for a second and the program quits with a have a nice day!
[snip]
It looks like there is a bug introduced into the version of omxplayer that is in wheezy raspbian in that it prematurely terminates the playing of short videos. If you have a previous version of omxplayer you will probably find that your file plays OK but cannot be paused as its a short file.
Posted: Fri Jul 20, 2012 1:28 am
by av2kk
I tried a longer file (5 mins) with the same result. Is this also considered short?
1.How can this bug be brought to the notice of the author?
2. How can I get the earlier version and replace the present . I am new to linux and will appreciate step by step instructions.
My goal is to play .mp4 files and have full control on pausing ,replaying etc. programatically.
Posted: Wed Jul 25, 2012 5:28 am
by Ocean20
I can play mp3 sound files using the analogue output and omxplayer. I can't play AVI videos with omxplayer which only plays the sound of the video. I can play an AVI video with mplayer but don't get sound. Hmmm what should I do?
