duicleme
How to start OpenGL for RPI4
Tue Sep 17, 2019 2:52 pm
... How to start OpenGL for Raspberry Pi 4 .... I couldn't start OpenGL.
I am see Example and Excute but that messaging "RPI4 not Support"
PeterO
Re: How to start OpenGL for RPI4
Tue Sep 17, 2019 3:30 pm
We aren't mind readers !
You need to tell us much more info about what you are trying to do.
Where is the example you are using ?
PeterO
duicleme
Wed Sep 18, 2019 12:52 pm
// I am typing this code ... It's a raspberrypi2 code ..
// I know .. may be changed someone......
// but I don't konw ... help me.
#include < stdio.h>
#include < unistd.h>
#include < bcm_host.h>  /*for  BCM GPU  */
#include < EGL/egl.h>  /*for  EGL */
#include < EGL/eglext.h>
#include < GLES/gl.h>  /* for OpenGL ES */
int main(int argc, const char **argv) {
    /* var for screen */
    uint32_t screenWidth, screenHeight;
    /*var for  EGL */
    EGLDisplay gDisplay;
    EGLSurface gSurface;
    EGLContext gContext;
    EGLConfig gConfig;
    EGLBoolean result;
    EGLint numConfig;
    int32_t success = 0;
    /*for put printing screen on raspberrypi  */
    static EGL_DISPMANX_WINDOW_T nativeWindow;
    DISPMANX_ELEMENT_HANDLE_T dispmanElement;
    DISPMANX_DISPLAY_HANDLE_T dispmanDisplay;
    DISPMANX_UPDATE_HANDLE_T dispmanUpdate;
    VC_RECT_T dst_rect, src_rect;
    /* for eglChooseConfig( ) fucntion */
    static const EGLint attribute_list[] = {
        EGL_RED_SIZE, 8,
        EGL_GREEN_SIZE, 8,
        EGL_BLUE_SIZE, 8,
        EGL_ALPHA_SIZE, 8,
        EGL_DEPTH_SIZE, 16,  /*  It's needed for color depth buffering . */
        EGL_SURFACE_TYPE, EGL_WINDOW_BIT,
        EGL_NONE
    /* for eglCreateContext( ) function  */
    static const EGLint context_attributes[] = {
        EGL_CONTEXT_CLIENT_VERSION, 1,  /* OpenGL ES 1.x는 1, OpenGL ES 2는 2 */
        EGL_NONE
    bcm_host_init();  /* BCM GPU Init  */
    /*object for  connecting EGL display */
    gDisplay = eglGetDisplay(EGL_DEFAULT_DISPLAY);
    /* EGLDisplay  Init  */
    result = eglInitialize(gDisplay, NULL, NULL);
    /*  an object for setting a EGL FrameBuffer    */
    result = eglChooseConfig(gDisplay, attribute_list, &gConfig, 1, &numConfig);
    /* for using OpenGL ES  on  EGL  */
    result = eglBindAPI(EGL_OPENGL_ES_API);
    /* a contextt for randering */
    gContext = eglCreateContext(gDisplay, gConfig, EGL_NO_CONTEXT, context_attributes);
    /* getting full screen size  */
    success = graphics_get_display_size(0 /* LCD */, &screenWidth, &screenHeight);
    dst_rect.x = 0;
    dst_rect.y = 0;
    dst_rect.width = screenWidth;
    dst_rect.height = screenHeight;
    src_rect.x = 0;
    src_rect.y = 0;
    src_rect.width = screenWidth < < 16;
    src_rect.height = screenHeight < < 16;
    dispmanDisplay = vc_dispmanx_display_open(0 /* LCD */);
    dispmanUpdate = vc_dispmanx_update_start(0);
    dispmanElement = vc_dispmanx_element_add(dispmanUpdate, dispmanDisplay,
                0/*layer*/, &dst_rect, 0/*src*/,
                &src_rect, DISPMANX_PROTECTION_NONE,
                0 /*alpha*/, 0/*clamp*/, (DISPMANX_TRANSFORM_T)0/*transform*/);
    nativeWindow.element = dispmanElement;
    nativeWindow.width = screenWidth;
    nativeWindow.height = screenHeight;
    vc_dispmanx_update_submit_sync(dispmanUpdate);
    gSurface = eglCreateWindowSurface(gDisplay, gConfig, &nativeWindow, NULL);
    result = eglMakeCurrent(gDisplay, gSurface, gSurface, gContext);
    glClearColor(0.15f, 0.25f, 0.35f, 1.0f);
    glClear(GL_COLOR_BUFFER_BIT);
    glViewport(0, 0, screenWidth, screenHeight);
    eglSwapBuffers(gDisplay, gSurface);
    getchar();
    bcm_host_deinit();
    return 0;
// Compile Option .. Command
// pi@raspberrypi ~ $ gcc -o hello_egl hello_egl.c -I/opt/vc/include -I/opt/vc/include/interface/vcos/pthreads/ -I/opt/vc/include/interface/vmcs_host/linux -L/opt/vc/lib -lbcm_host -lEGL -lGLESv1_CM
dividuum
Fri Sep 20, 2019 7:57 pm
The Pi4 no longer supports the closed source Broadcom GL driver. You'll have to rewrite that to either use DRM to create a surface or X. There's examples and links in the OpenGL subforum for both ways.
info-beamer hosted - A user and programmer friendly digital signage platform for the Pi: https://info-beamer.com/hosted
Gavinmc42
Fri Sep 27, 2019 8:32 am
Most of the mesa demos work now
https://www.mesa3d.org/download.html
Some will work on Pi3B's if you use Gentoo64 which uses the OpenGL drivers.
Have not tried them on 3B+/Buster.
I have also got OpenGL working with Go and Free Pascal.
Pi4 and OpenGl are pretty mainstream now, have a look at Linux OpenGL tutorials.
I'm dancing on Rainbows.
