thunderhawk
Re: how to compile ffmpeg for Pi2 (iterating to a working bu
Thu Oct 27, 2016 7:33 am
I found the problem and SOLVED: when you build the xvid it put links to library into /usr/local/lib/ so you have to remove libxvidcore.so and libxvidcore.so.4.
Then it works!
mcgyver83
Sat Jan 14, 2017 5:07 pm
I tried the script in post report.php?f=67&p=702809 but I get
pi@raspberrypi:~$ sh extra.sh
# Start building some external libraries for ffmpeg on Raspberry Pi 2
# This is a COMPLETE source download and rebuild of some ffmpeg external libraries on Raspberry Pi 2
# Once day, ask someone about which if these works and is *the best* for the Pi2
# sudo ./configure --host=arm-unknown-linux-gnueabi
#   versus
# sudo ./configure --host=armv71-unknown-linux-gnueabihf
#   versus
# sudo ./configure --host=arm-unknown-linux-gnueabihf
Do you wish to re-download every Source library as we go ? [y/n,default=n]Y
Do you wish to press Enter between each library build ? [y/n,default=n]n
extra.sh: 75: extra.sh: Syntax error: "(" unexpected (expecting "}")
Any hints?
Return to “Graphics programming”
