KeithSloan
HTML Editor.
Thu Feb 06, 2014 11:35 pm
Is there a good HTML editor for Raspbian?
Could not find Kompozer or Nvu, which are okay but not great
Re: HTML Editor.
Thu Feb 06, 2014 11:47 pm
vi or emacs (pick your poison)
and
sudo apt-get install tidy
so you can check syntax and clean it up.
We don't need no stinking GUIs.
This is a doctor free zone.
gkreidl
Re: HTML Editor.
Fri Feb 07, 2014 12:29 am
KeithSloan wrote:Is there a good HTML editor for Raspbian?
This is nothing for Dougie, but of you are looking for a WYSIWYG Editor it's contained in the IceApe (Firefox) suite (Composer).
Minimal Kiosk Browser (kweb)
Re: HTML Editor.
Fri Feb 07, 2014 12:31 am
Best of luck running bloatware like that on a RPi.
treii28
Re: HTML Editor.
Thu Oct 05, 2017 4:06 pm
I have verified that while a bit top-heavy, most of the JetBrains IDEs will run on raspberry pi. (of course, that doesn't mean the full compiler support or other features may work as expected depending upon what you have installed)
But I have used WebStorm, PHPStorm, CLion and Android Studio IDEs for editing. ( the latter two require a bit of tweaking to get any of the compliling, debugging or code execution to function)
How I install is download the tarball somewhere, extract (with sudo) to /usr/local. I chmod -R to myuserid.www-data just to make it easier to work with the files.
I then create a symlink so upgrading is easier:
> cd /usr/local
> sudo ln -s WebStorm-xx.xx.xx WebStorm
> cd bin
> sudo ln -s ../WebStorm/bin/webstorm.sh webstorm
buja
Re: HTML Editor.
Thu Oct 05, 2017 4:48 pm
Bluefish is in the repository, so you install it easily:
sudo apt install bluefish
(or sudo apt-get install bluefish if you like old style better)
Laui
Re: HTML Editor.
Fri Oct 06, 2017 2:50 pm
I use Bluefish too. Its good
Return to “Raspbian”
