mexus
Re: ASUS USB-AC56 (RTL8812AU/RTL8821AU) Driver compile fails
Mon Jun 12, 2017 10:59 am
MrEngman,
Can you please tell me which driver source are you using to compile your drivers?
MrEngman
Mon Jun 12, 2017 11:58 am
mexus wrote:MrEngman,
I was using this until recently. Now I'm using this
MrEngman
propergol
Mon Jun 19, 2017 3:23 pm
I just try to compile the driver for kernel 4.11.6-v7+ and...failed :lol:
Do you have updated driver dear MrEngman :?:
PS : I use this kernel because an other dongle, em28xx-Hauppauge-DualHD TV tuner, need a kernel patch that works on this kernel version only (from what I understand)
MrEngman
Mon Jun 19, 2017 4:49 pm
propergol wrote:I just try to compile the driver for kernel 4.11.6-v7+ and...failed :lol:
Sorry, but I only have drivers compiled for kernels 4.0, 4.1, 4.4 and 4.9.
MrEngman
propergol
Mon Jun 19, 2017 5:39 pm
MrEngman wrote: Sorry, but I only have drivers compiled for kernels 4.0, 4.1, 4.4 and 4.9.
MrEngman
my bad...it was too hot today here :P
the kernel I am applying the patch / compiling is 4.9 :roll: (the 4.11 was from a previous test)
MrEngman
Mon Jun 19, 2017 5:46 pm
MrEngman
I have a script that will automatically select the driver for the kernel version you are using and install it. Take a look here to see how to install it :- viewtopic.php?p=1133815#p1133815
MrEngman
propergol
Mon Jun 19, 2017 5:59 pm
MrEngman wrote:
MrEngman
MrEngman
Yep, I know it thanks!
PS : I dont know if you remember, one or 2 weeks ago I told you that Libreelec WIFI drivers was more stable blabla...bulshit! : the culprit was one of my router the AC66U that is known to have 5ghz dropout :roll: using your driver on the AC68u 5Ghz is now perfect!
propergol
Mon Jun 19, 2017 6:44 pm
its me...again :mrgreen:
 sudo install-wifi
 *** Raspberry Pi wifi driver installer by MrEngman.
 *** Performing self-update
 *** Relaunching after update
Your current kernel revision = 4.9.33-v7+
Your current kernel build    = #1
Checking for a wifi module to determine the driver to install.
Your wifi module is Bus 001 Device 004: ID 0846:9052 NetGear, Inc.
And it uses the 8812au driver.
Checking for a new 8812au wifi driver module for your current kernel.
A driver does not yet exist for this update.
So the missing driver as you can see is for kernel 4.9.33
MrEngman
Mon Jun 19, 2017 7:15 pm
propergol wrote:its me...again :mrgreen:
 sudo install-wifi
Your current build does not agree with the build for the current Raspbian kernel which is 4.9.33-v7+ #1010. What OS/kernel are you using?
The current driver I have for Raspbian 4.9.33-v7+ is 8812au-4.9.33-v7-1010.tar.gz.
You could try
wget http://fars-robotics.net/8812au-4.9.33-v7-1010.tar.gz
tar xzf 8812au-4.9.33-v7-1010.tar.gz
./install.sh
to install the driver I have but whether it will work with the kernel you are using I don't know.
MrEngman
propergol
Mon Jun 19, 2017 7:54 pm
well I am using Raspbian lite with kernel patched as per instuctions post #24 https://forum.libreelec.tv/thread/2867- ... /?pageNo=2
But I am just following a receip with knowing nearly nothing in Linux :oops:
Anyway I have installed using your instructions and it works.
I must confess than I am starting to get lost between kernel version, patch, firmware :mrgreen:
odemwingie
Wed Jun 21, 2017 11:45 am
Dear MrEngman,
Do you have the driver for Linux raspberrypi 4.9.26v7-aufs #1 SMP Tue May 9 20:14:03 CEST 2017 armv7l GNU/Linux ?
MrEngman
Wed Jun 21, 2017 4:42 pm
odemwingie wrote:Dear MrEngman,
Sorry, I don't.
MrEngman
dadak
Sun Jun 25, 2017 12:26 am
Dear MrEngman,
I ran your "install wifi" script on rpi 3 board running volumio kernal :
uname -a
Linux volumio 4.4.9-v7+ #884 SMP Fri May 6 17:28:59 BST 2016 armv7l GNU/Linux
getting the following :
volumio@volumio:~$./install-wifi.sh
Your current kernel revision = 4.4.9-v7+
Your current kernel build = #884
Your wifi module is Bus 001 Device 005: ID 0bda:a811 Realtek Semiconductor Corp.
Is their a driver that will work for this kernal? I also tried to compile rtl8812au source from git and
compiled fine, but when running "insmod 8812au.ko" get invalid format error.
Any help would be appreciated.
dadak
MrEngman
Sun Jun 25, 2017 9:15 am
dadak wrote:Dear MrEngman,
uname -a
dadak
The drivers were installed on Dropbox but they have made a major change to their web site and its really screwed things up. Really annoying to say the least so I have moved the drivers to a new site. You will need to download and install a new script to use the new site.
Download and install the new version of the script with commands
sudo wget http://www.fars-robotics.net/install-wifi -O /usr/bin/install-wifi
sudo chmod +x /usr/bin/install-wifi
The command
sudo install-wifi -h
will show details on using it.
To install the driver on your current kernel you should just need to run command
sudo install-wifi
This will select the driver you need and automatically download and install it.
MrEngman
dadak
Sun Jun 25, 2017 6:54 pm
Mr. Engman,
Thank you. Your help was appreciated. The script at the new location you provided fixed my issues and got my
rtl8812au chipset adpater working on my raspberry pi 3.
mexus
Wed Jul 05, 2017 5:02 pm
MrEngman
Thanks.
Which platform do you use for:
posting.php?mode=quote&f=66&p=1174196
to compile the driver for RPI?
MrEngman
Wed Jul 05, 2017 5:29 pm
MrEngman
Thanks.
I cross-compile on a PC using Ubuntu 16.0.4.
I have compiled on a Pi but it just takes quite a bit longer.
MrEngman
mexus
Thu Jul 06, 2017 9:12 am
MrEngman,
Can I also ask you to add support for TP-Link - Archer T4U AC1300 (V2) in future builds.
You need to edit os_dep\linux\usb_intf.c
and add this
{USB_DEVICE(0x2357, 0x010D),.driver_info = RTL8812}, /* TP-Link - Archer T4U AC1300*/
somewhere below:
#ifdef CONFIG_RTL8812A
What is the makefile options to compile on the pi?
https://github.com/Grawp/rtl8812au_rtl8 ... ree/4.3.20
CONFIG_PLATFORM_GENERIC = y
or something else. In the other source there was a platform for the RPI
MrEngman
Thu Jul 06, 2017 4:46 pm
Hi mexus,
I thought the driver already included the Archer T4U USB ID. However, a patch I'd added a while back that also included several new wifi USB ID's had the wrong value for the Archer T4U.
I checked out the patch earlier today and I see it has now been updated with the correct value for the T4U.
I've updated the driver source with the correct value and recompiled the drivers for the Raspbian kernels 4.0, 4.1, 4.4 and 4.9 that already have drivers available so the T4U should now work.
MrEngman
xphoto
Wed Jul 19, 2017 8:33 pm
Man, you made my day and saved me hours !
I just downloaded the latest version after upgrading from 4.1.11 to 4.9.37 firmware and it worked out of the box with your script !
thank you so so much !!!
took me 1 min to make it run. :))))
MrEngman wrote: The drivers were installed on Dropbox but they have made a major change to their web site and its really screwed things up. Really annoying to say the least so I have moved the drivers to a new site. You will need to download and install a new script to use the new site.
The command
sudo install-wifi
MrEngman
planflux
Fri Jul 21, 2017 3:21 am
All other solutions for RTL8812au or RTL8821au on the internet failed, and it took me 2 days to compile the kernel, a matched gcc, editting Makefile, and etc. My device had 0bda:a811 (use command $ lsusb). A few of the GIT driver sources didnot work.
I followed the answer posted by the gentleman above, and it immediately worked... I wish I looked at the bottom of this post sooner.
sudo install-wifi -h (remove -h)
biasha
Wed Sep 13, 2017 11:50 am
seems to work fine when i connect to access point, but unable to create own access point :(
i was fallowing bridge section of official documentation
works fine with on-board wifi, fails with USB-AC56...
even tried jessie to exclude recent network mess but no success either.
edit:
i found that Realtek chip requires custom patched hostapd to work. patches are extracted and collected at here.
But still can't make it work :\
g1d30N
Thu Nov 09, 2017 4:59 am
Mr. Enger:
I am running your script and my kernel version is 4.4.50-v7+
My kernel build is #1
My wifi module is Bus 001 Device 008.
It is using the 8812au driver
The script states that a driver does not yet exist for this update.
How do I get my ALFA AWUS036ACH to work ?
I am trying to get it to work with Kali Linkux on a raspberry PI.
Thank you.
MrEngman
Thu Nov 09, 2017 2:04 pm
Mr. Enger:
Thank you.
Sorry, g1d3on, but the drivers I compile and are installed by my script are for use with Raspbian, so will not work with Kali.
rusli
Sun Nov 12, 2017 7:51 am
[Hi Mr EngMan,
Today I cannot seems to update my rtl8812au driver on my ubuntu-mate 16.04.2.
Running kernel 4.9.61-v7+ #1049
As I run install-wifi it gives me an error. It stated that I am not running Raspbian OS. So exiting script.
This script installs drivers for Raspbian.
You do not appear to be using a Raspbian OS so exiting the script.
Return to “Raspbian”
