akatsuki
Bluetooth Woes
Sun Mar 17, 2013 8:57 pm
So, I wanted to make my pi an A2DP Sink, I have been following mainly monkey houses tutorial http://kmonkey711.blogspot.de/ ; so here are the details for my adaptor
lsusb
Bus 001 Device 008: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
its a cheap bluetooth module, I cracked it open its a CSR Chip based module ( The datasheet is locked by CSR themselves) I am more of an low level hardware EE than CSE.
anyways, I know the bluetooth service is running
/etc/init.d/bluetooth status
[ ok ] bluetooth is running.
but when I scan It doesn't show any of the devices not my laptop or any of my mobiles (2x Nokia E71 and a Samsung S3)
pi@raspberrypi // $ hcitool scan
Scanning ...
pi@raspberrypi // $ sudo hcitool scan
Scanning ...
Anything I am doing wrong ?
When I try to establish a connection with my phone ( The problem in pairing that works and yes I have added to trusted
bluez-test-device trusted XX:XX:XX:XX:XX:XX yes
) it fails "Connection could not be established".
Any help or insights on what I am doing wrong would be appreciated!!
OtherCrashOverride
Re: Bluetooth Woes
Mon Mar 18, 2013 5:36 am
I had this issue too. For me the solution was to plug the bluetooth USB device directly into the Pi's USB port instead of an external hub. Check the system log for device timeout messages.
akatsuki
Re: Bluetooth Woes
Mon Mar 18, 2013 5:41 am
The bluetooth is plugged directly into the pi's usb port and not via a hub.
Cloudcentric
Re: Bluetooth Woes
Mon Mar 18, 2013 8:14 am
Have you installed all the Bluez packages, I also install the Blueman GUI
bluez
bluez-firmware
blueman
bluez-utils
bluez-tools
I know everything about nothing"
akatsuki
Re: Bluetooth Woes
Mon Mar 18, 2013 12:48 pm
I do have installed the Bluez Packages but how do you install the blueman GUI? its not showing up under preferences.
Cloudcentric
Re: Bluetooth Woes
Mon Mar 18, 2013 5:59 pm
akatsuki wrote:I do have installed the Bluez Packages but how do you install the blueman GUI? its not showing up under preferences.
If you apt-get install blueman it will be under Preferences in lxde menu "bluetooth maanger"
Return to “Raspbian”
