andrea2277
Raspbian boot fast
Tue Jan 29, 2013 11:36 am
Hi guys,
if possible set the etc/inittab for fast boot in Raspbian?
I have tried this information:
http://www.raspberrypi.org/phpBB3/viewt ... =53&t=7884
but don't work..this is the error message:
(none) login: pi (automatic login)
unable to determine your tty name
INIT: id "c1" respawning too fast: disabled for 5 minutes
Is possible boot with 10-15 sec in Raspbian??
Bye!
RaTTuS
Re: Raspbian boot fast
Tue Jan 29, 2013 12:11 pm
yes sort of .. depends YMMV
in inititab
change
1:2345:respawn:/sbin/getty --noclear 38400 tty1
to
1:2345:respawn:/bin/login -f pi tty1 </dev/tty1 >/dev/tty1 2>&1
this will auto log you into terminal 1
now as for speeding things up -
you could disable some of the stuff that starts up when you boot - or just boot to single user mode
how fast and why
Covfefe
andrea2277
Tue Jan 29, 2013 3:32 pm
Hi RaTTuS,
thanks for your reply..
I have use:
and it's ok.. but don't autologin into LXDE..
for solving this problem, i have:
1. sudo nano /etc/inittab
change
to
1:2345:respawn:/bin/login -f root tty1 </dev/tty1 >/dev/tty1 2>&1
2. sudo nano /etc/profile
in the bottom i have add-> startx
3. sudo passwd root
i have change my root password...
At the moment the boot with autologin (user->root) work... but the LXDE start is very very slow.. it's 120-150 sec !!!!
bye
-rst-
Thu Jan 31, 2013 3:28 pm
LXDE start just is very slow (slow'ish CPU, usually high resolutions, non-accelerated X, ...) ...not sure that mine takes over 2 minutes though, but I don't use it that much (no icons on the desktop etc.).
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
Return to “Raspbian”
