Gorblimey
PI4 wont update
Sat Jan 25, 2020 6:35 pm
I also can't open web pages. The error is the standard FF "is havng a problem finding that web site." And says no internet connection. My sources list needs to be reconfigured I think but I don't know the procedure. I'm running Buster10.
DirkS
Re: PI4 wont update
Sat Jan 25, 2020 7:00 pm
Well, there's your problem...
Why do you think you *do* have an internet connection?
Try e.g. 'ping 8.8.8.8' and post the full output here.
Gorblimey
Re: PI4 wont update
Sat Jan 25, 2020 7:38 pm
The output for ping 8.8.8.8 is
From 192.168.0.1 icmp_seq=1 Destination Net Unreachable(repetitive loop) until I kill it by Ctrl+C.
Followed by --- 8.8.8.8 ping statistics ---
17 packets transmitted, 0 received, +17 errors, 100% packet loss, time 672ms
DirkS
Re: PI4 wont update
Sat Jan 25, 2020 7:56 pm
So you don't have an Internet connection.
Nothing to do with sources.list
How are you connected to the network?
Gorblimey
Re: PI4 wont update
Sat Jan 25, 2020 8:25 pm
I got a wired connection. It was working fine until a few days ago. My other machine with Linux Mint has no problem with internet connection.
Gorblimey
Re: PI4 wont update
Sat Jan 25, 2020 9:18 pm
I found sudo apt update -allow-releaseinfo-update. Maybe that will save the day. And maybe clearing FF's cache to load web pages again, since I know the internet is up.
Gorblimey
Re: PI4 wont update
Sun Jan 26, 2020 1:33 am
Web pages load again and was able to update. Latest snag is the links on a web page are only active immediately after pressing refresh button. Then they go dead with a few seconds. How to keep links active?
SupaTailsBros
Re: PI4 wont update
Sun Jan 26, 2020 11:41 am
Is your internet working sometimes for your pi, when browsing the web?
Because if it decides to turn of internet after a while, the problem could be the router.
I had the same problem with my router, but it was with wireless connection, so I doubt it could be it.
Maybe, if you have a spare SD Card, flash the image onto it and try and update from that SD Card.
Gorblimey
Re: PI4 wont update
Mon Jan 27, 2020 8:14 pm
The OS has updated and the internet has returned. Need help with audio. It only comes through hdmi interface but I need audio piped in to the head set. What settings should be changed to accomplish that?
klricks
Re: PI4 wont update
Mon Jan 27, 2020 8:23 pm
Right click on the speaker icon and select Analog.
Left click for volume control.
Return to “Raspbian”
