TheProrok29
VSC on RPI 4B
Sat Jun 29, 2019 12:08 am
Hi. I have a RPi 4B and latest Raspbian OS. I want to try Visual Studio Code on the new board. When I installed app he not start. I see only blank black screen with title VCS. Why this happend? Can I do something different to run this app?
Re: VSC on RPI 4B
Sat Jun 29, 2019 11:46 am
Debian based Operating systems use packages, Apps are usually associated with Android.
So the question is what did you download and where did you download it from ?
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
hippy
Re: VSC on RPI 4B
Sat Jun 29, 2019 12:57 pm
Later versions of VSC do not work on a Pi, behave exactly as described. You need to use a version which actually works on a Pi.
TheProrok29
Re: VSC on RPI 4B
Sun Jun 30, 2019 8:20 pm
I used a mental shortcut. I know difference between app and packages. Problem is that the latest version of VSC doesn.t work on ARM processors. The latest working version is VSC 1.29. I found this information on official ARM fork page on github.
polomint
Re: VSC on RPI 4B
Mon Jul 08, 2019 6:19 am
I have been looking about for a while and even tried the headmelted instructions for code-oss, but have had no luck with it (it seems to lock up with a blank window).
Has anyone had any luck getting an older version of vscode installed on the Pi4? Maybe someone has found some reliable way to get it running? I'm not too bothered about the newest versions, it is mainly for creating and editing dotnet-core webservices :)
Cheers !
DirkS
Re: VSC on RPI 4B
Mon Jul 08, 2019 6:24 am
Cheers !
As mentioned above: v 1.29 should work. Download the deb file from headmelted's repo and install it...
polomint
Re: VSC on RPI 4B
Mon Jul 08, 2019 6:31 am
Cheers !
Thank you, I think that may have been the one that I had issues with, but I have reinstalled the Pi so will give it another shot :)
Re: VSC on RPI 4B
Mon Jul 08, 2019 8:57 am
v1.29 worked fine on a 4B for me.
Return to “Raspbian”
