tigernero
Tvheadend for Raspbian Buster?
Fri Jun 28, 2019 8:04 am
I installed raspbian Buster image
but it doesn't bring with it the repositories for tvhead
nor the official repositories have buster sources.
having a tvhat I have to go back to stretch?
B.Goode
Re: Tvheadend for Raspbian Buster?
Fri Jun 28, 2019 10:08 am
It isn't specifically about the TV HAT, but this prior reply from an RP Engineer implies the HAT must have been tested with Raspbian Buster.
https://www.raspberrypi.org/forums/view ... 4#p1485250
(Because they would have needed to be running Buster to check compatibility with the new RPi4 hardware.)
Alternatively it might just be yet another item of software that is 'broken' with Buster that will have to be sorted out in the fullness of time...
itsmedoofer
Fri Jun 28, 2019 12:08 pm
No mention of Buster at http://apt.tvheadend.org/
Like B.Goode said we are a bit too early doors here and will just have to wait for the rest of the world to catch up.
Fri Jun 28, 2019 1:01 pm
Have you tried getting the *.deb files from http://archive.raspberrypi.org/debian/p ... adend-dmo/ and installing them on Buster?
This is a doctor free zone.
tigernero
Fri Jun 28, 2019 1:10 pm
thank you I will try
snapper
Sat Jun 29, 2019 8:26 am
Hi, i've tried pulling down the last version & installing, but got a load of unmet dependencies. Tried to correct the dependencies, but found that most were not available to Buster branch of Raspian. I've also tried a recompile of the source, but the autobuild script gave a bunch of errors that exceeded my knowledge to resolve. I think we may have to wait for a Pi Buster version to surface.
Sat Jun 29, 2019 10:45 am
I ended up adding the Stretch repo to /etc/apt/sources.list and /etc/apt/sources.list.d/raspi-list
That downloaded these packages:
Start-Date: 2019-06-29  11:34:50
Commandline: apt install tvheadend
Install: libpackage-stash-perl:armhf (0.38-1, automatic), libdvbcsa1:armhf (1.1.0-2, automatic), xmltv-util:armhf (0.6.1-1, automatic), libxmltv-perl:armhf (0.6.1-1, automatic), libossp-uuid-perl:armhf (1.6.2-1.5+b5, automatic), libhttp-daemon-perl:armhf (6.01-3, automatic), libnet-libidn-perl:armhf (0.12.ds-3+b1, automatic), libhttp-message-perl:armhf (6.18-1, automatic), libavformat57:armhf (7:3.2.14-1~deb9u1+rpt1, automatic), libb-hooks-op-check-perl:armhf (0.22-1+b1, automatic), libavfilter6:armhf (7:3.2.14-1~deb9u1+rpt1, automatic), libwww-robotrules-perl:armhf (6.02-1, automatic), libencode-locale-perl:armhf (1.05-1, automatic), dtv-scan-tables:armhf (0+git20171226.07b18ec-1, automatic), libmodule-runtime-perl:armhf (0.016-1, automatic), libauthen-sasl-perl:armhf (2.1600-1, automatic), dvb-apps:armhf (1.1.1+rev1500-1.2, automatic), libparams-validate-perl:armhf (1.29-1+b1, automatic), libxmlrpc-lite-perl:armhf (0.717-2, automatic), libnet-ssleay-perl:armhf (1.85-2+b1, automatic), liblist-moreutils-perl:armhf (0.416-1+b3, automatic), libxml-sax-base-perl:armhf (1.09-1, automatic), libhtml-form-perl:armhf (6.03-1, automatic), libfile-slurp-perl:armhf (9999.26-1, automatic), liburiparser1:armhf (0.9.1-1, automatic), libdata-dump-perl:armhf (1.23-1, automatic), libtask-weaken-perl:armhf (1.06-1, automatic), libterm-progressbar-perl:armhf (2.22-1, automatic), libdatetime-perl:armhf (2:1.50-1+b1, automatic), libswresample2:armhf (7:3.2.14-1~deb9u1+rpt1, automatic), libopencv-imgproc2.4v5:armhf (2.4.9.1+dfsg1-2, automatic), libdata-optlist-perl:armhf (0.110-1, automatic), libtry-tiny-perl:armhf (0.30-1, automatic), libjson-perl:armhf (4.02000-1, automatic), libxml-sax-perl:armhf (1.00+dfsg-1, automatic), libarchive-zip-perl:armhf (1.64-1, automatic), libhttp-negotiate-perl:armhf (6.01-1, automatic), libebur128-1:armhf (1.2.4-2, automatic), libvariable-magic-perl:armhf (0.62-1+b1, automatic), libdate-manip-perl:armhf (6.76-1, automatic), liblwp-useragent-determined-perl:armhf (1.07-1, automatic), libdevel-callchecker-perl:armhf (0.008-1, automatic), libdbi-perl:armhf (1.642-1+b1, automatic), libemail-valid-perl:armhf (1.202-1, automatic), libb-hooks-endofscope-perl:armhf (0.24-1, automatic), libhttp-cache-transparent-perl:armhf (1.4-1, automatic), libxml-regexp-perl:armhf (0.04-1, automatic), libalgorithm-c3-perl:armhf (0.10-1, automatic), libexception-class-perl:armhf (1.44-1, automatic), libexporter-tiny-perl:armhf (1.002001-1, automatic), libhttp-date-perl:armhf (6.02-1, automatic), liblwp-mediatypes-perl:armhf (6.02-1, automatic), libspecio-perl:armhf (0.43-1, automatic), libclass-singleton-perl:armhf (1.5-1, automatic), libfcgi-perl:armhf (0.78-2+b2, automatic), libnet-dns-perl:armhf (1.19-1, automatic), libclass-c3-xs-perl:armhf (0.14-1+b3, automatic), libmodule-implementation-perl:armhf (0.09-1, automatic), libpackage-stash-xs-perl:armhf (0.29-1, automatic), libperlio-gzip-perl:armhf (0.19-1+b4, automatic), libdevel-lexalias-perl:armhf (0.05-2+b1, automatic), libxml-treepp-perl:armhf (0.43-1, automatic), libsub-quote-perl:armhf (2.005001-1, automatic), libsub-identify-perl:armhf (0.14-1+b1, automatic), libsub-exporter-perl:armhf (0.987-1, automatic), libmime-tools-perl:armhf (5.509-1, automatic), libdatetime-format-builder-perl:armhf (0.8100-2, automatic), libclass-methodmaker-perl:armhf (2.24-1+b4, automatic), libregexp-common-perl:armhf (2017060201-1, automatic), libclass-xsaccessor-perl:armhf (1.19-3+b6, automatic), libwww-perl:armhf (6.36-2, automatic), libparams-util-perl:armhf (1.07-3+b3, automatic), libio-html-perl:armhf (1.001-1, automatic), libdevel-caller-perl:armhf (2.06-2+b1, automatic), libterm-readkey-perl:armhf (2.38-1, automatic), libhdhomerun3:armhf (20161117-2, automatic), libemail-address-perl:armhf (1.912-1, automatic), libnet-http-perl:armhf (6.18-1, automatic), libsub-install-perl:armhf (0.928-1, automatic), libpostproc54:armhf (7:3.2.14-1~deb9u1+rpt1, automatic), libvpx4:armhf (1.6.1-3+deb9u1, automatic), libnet-smtp-ssl-perl:armhf (1.04-1, automatic), libjson-xs-perl:armhf (3.040-1+b1, automatic), libio-socket-ssl-perl:armhf (2.060-3, automatic), libdynaloader-functions-perl:armhf (0.003-1, automatic), libdigest-bubblebabble-perl:armhf (0.02-2, automatic), libconvert-binhex-perl:armhf (1.125-1, automatic), libclass-inspector-perl:armhf (1.32-1, automatic), libdatetime-format-strptime-perl:armhf (1.7600-1, automatic), libref-util-perl:armhf (0.204-1, automatic), libfile-sharedir-perl:armhf (1.116-2, automatic), libhtml-tagset-perl:armhf (3.20-3, automatic), libparams-classify-perl:armhf (0.015-1+b1, automatic), libva1:armhf (1.7.3-2, automatic), libclass-method-modifiers-perl:armhf (2.12-1, automatic), libfile-listing-perl:armhf (6.04-1, automatic), libsub-name-perl:armhf (0.21-1+b2, automatic), libdatetime-format-sqlite-perl:armhf (0.11-2, automatic), libx264-148:armhf (2:0.148.2748+git97eaef2-1+rpi1, automatic), libdatetime-timezone-perl:armhf (1:2.23-1+2019a, automatic), libass5:armhf (1:0.13.4-2, automatic), libx265-95:armhf (2.1-2, automatic), liblwp-protocol-https-perl:armhf (6.07-2, automatic), librole-tiny-perl:armhf (2.000006-1, automatic), libhtml-tree-perl:armhf (5.07-2, automatic), libdatetime-format-iso8601-perl:armhf (0.08-2, automatic), libxml-libxslt-perl:armhf (1.96-1+b1, automatic), libexporter-lite-perl:armhf (0.08-1, automatic), libio-stringy-perl:armhf (2.111-3, automatic), libavcodec57:armhf (7:3.2.14-1~deb9u1+rpt1, automatic), libxml-twig-perl:armhf (1:3.50-1.1, automatic), libnamespace-clean-perl:armhf (0.27-1, automatic), libmailtools-perl:armhf (2.18-1, automatic), perl-openssl-defaults:armhf (3, automatic), libnet-dns-sec-perl:armhf (1.11-1, automatic), libreadonly-perl:armhf (2.050-1, automatic), libsoap-lite-perl:armhf (1.27-1, automatic), libavutil55:armhf (7:3.2.14-1~deb9u1+rpt1, automatic), libtie-ixhash-perl:armhf (1.23-2, automatic), libdatetime-locale-perl:armhf (1:1.23-1, automatic), libtypes-serialiser-perl:armhf (1.0-1, automatic), libfont-afm-perl:armhf (1.20-2, automatic), libhttp-cookies-perl:armhf (6.04-1, automatic), libwebpmux2:armhf (0.5.2-1, automatic), libxml-namespacesupport-perl:armhf (1.12-1, automatic), tvheadend-data:armhf (4.2.4-dmo1~bpo9+1~rpt1, automatic), libdevel-stacktrace-perl:armhf (2.0300-1, automatic), libcommon-sense-perl:armhf (3.74-2+b18, automatic), libfile-homedir-perl:armhf (1.004-1, automatic), libclass-factory-util-perl:armhf (1.7-3, automatic), libswscale4:armhf (7:3.2.14-1~deb9u1+rpt1, automatic), libxml-libxml-perl:armhf (2.0134+dfsg-1, automatic), libpadwalker-perl:armhf (2.3-1+b1, automatic), libopencv-core2.4v5:armhf (2.4.9.1+dfsg1-2, automatic), libtimedate-perl:armhf (2.3000-2, automatic), libdigest-hmac-perl:armhf (1.03+dfsg-2, automatic), libfile-chdir-perl:armhf (0.1008-1, automatic), libnet-domain-tld-perl:armhf (1.75-1, automatic), libclass-data-inheritable-perl:armhf (0.08-3, automatic), libva-x11-1:armhf (1.7.3-2, automatic), libemail-find-perl:armhf (0.10-dfsg-3, automatic), libxml-parser-perl:armhf (2.44-4, automatic), libva-drm1:armhf (1.7.3-2, automatic), libdbd-sqlite3-perl:armhf (1.62-3, automatic), libxml-sax-expat-perl:armhf (0.51-1, automatic), libeval-closure-perl:armhf (0.14-1, automatic), libhtml-fromtext-perl:armhf (2.07-1, automatic), libsub-exporter-progressive-perl:armhf (0.001013-1, automatic), libref-util-xs-perl:armhf (0.117-1+b1, automatic), libxml-dom-perl:armhf (1.44-2, automatic), tvheadend:armhf (4.2.4-dmo1~bpo9+1~rpt1), libxml-perl:armhf (0.08-3, automatic), libhtml-parser-perl:armhf (3.72-3+b2, automatic), libparams-validationcompiler-perl:armhf (0.30-1, automatic), liburi-perl:armhf (1.76-1, automatic), libclass-c3-perl:armhf (0.34-1, automatic), libio-sessiondata-perl:armhf (1.03-1, automatic), libnet-ip-perl:armhf (1.26-2, automatic), liblog-tracemessages-perl:armhf (1.4-5, automatic), liblingua-preferred-perl:armhf (0.2.4-4, automatic), libavresample3:armhf (7:3.2.14-1~deb9u1+rpt1, automatic), libunicode-string-perl:armhf (2.10-1+b3, automatic), libmro-compat-perl:armhf (0.13-1, automatic), libnamespace-autoclean-perl:armhf (0.28-1, automatic), libfile-which-perl:armhf (1.23-1, automatic), libxml-xpathengine-perl:armhf (0.14-1, automatic), libxml-writer-perl:armhf (0.625-1, automatic), libhtml-format-perl:armhf (2.12-1, automatic)
End-Date: 2019-06-29  11:42:14
Some of those are missing from Buster.
tigernero
Sat Jun 29, 2019 1:08 pm
when will the "buster" packages for tvheadend be available?
since your tvhat should be able to run correctly even on the buster? thank you.
because your efforts will surely be greater than having to wait for those of tvheadend itself.
I like having my tvhat with "buster" and pizero w as I already do with stretch
Sat Jun 29, 2019 2:41 pm
I got tvheadend running with the packages from Stretch on Buster. Then couldn't get Kodi running so that Raspberry is back to running Stretch.
Roken
Sat Jun 29, 2019 6:07 pm
Useful thread. I'm going to repurpose one of my 3B+, and set up the 4 to carry out the server functions. At least I know now that one of the opther Pis will have to serve tvheadend for me.
Headless PI. OMG, someone cut it's head off. Oh, hang on. it didn't have one to start with.
tigernero
Sat Jun 29, 2019 6:12 pm
the problem is that those who today buy a raspberry and a tvhat and have no stretch image available, on the site there is only the buster version of 06-20-2019 and try to install tvhead by command: "sudo apt install tvheadend" yes will find it unable to do so. I think it is necessary to import tvheadend as on stretch in your repositories
itsmedoofer
Sat Jun 29, 2019 6:22 pm
For reference old images can be found here.
https://downloads.raspberrypi.org/raspbian/images/
tigernero
Sat Jun 29, 2019 7:04 pm
thanks, the problem is average user who takes raspbian image on the site convinced to be able to interface his tvhat with tvheadend as explained also on Pi hut and find the software that allows to interface with tvhat not available.
grkblood13
Sun Jul 14, 2019 1:06 pm
The following link provides instructions for installing on Buster. Be sure to run sudo apt-get -f install after installation to resolve unmet deps.
https://markclarkstone.co.uk/downloads/rpi/readme.txt
mihailolja
Tue Jul 16, 2019 10:08 am
Thanks Grkblood for this!
Mihailolja
tigernero
Tue Jul 16, 2019 2:03 pm
The problem is that the modified tvheadend version that the raspbian had included in stretch supported video transcoding,
while the tvhedend release from their repositories does not exist.
in fact you can read the word = Transcoding support is unavailable on these distros.
so although we use momentarily the single debs to have tvheadend on the raspbian buster, I'd like to know if the foundation itself will put us on hand as for stretch so as to also have active transcoding.
Tue Jul 16, 2019 10:16 pm
That doesn't build on Raspbian Buster on my RPi3B (Raspbian 2019-07-10 version).
Return to “Raspbian”
