MIT70
Buster & Pi4: Same Image on Different RAM Size OK?
Thu Jun 27, 2019 9:18 pm
Since the 4GB board in made of Unobtainium here locally, if I get a 2GB Pi and do all the configuration and installation can I just transfer the SD card and USB-C disk to a 4GB board when I can get one? [I use the USB SSD for post-boot storage, the SD card is just for booting.]
My specific worry is there might be space reserved for a memory image on the disk and it would not work correctly on a 4GB device.
I did a search and didn't find this addressed, so I apologize if this is already asked and answered.
Thanks.
Re: Buster & Pi4: Same Image on Different RAM Size OK?
Thu Jun 27, 2019 9:28 pm
Should be fine, but I wouldn't recommend using the USB-C port for a disk. Apart from being the power connector, it is USB2 only. Much better to connect a disk to one of the two USB3 ports.
MIT70
Thu Jun 27, 2019 9:37 pm
My error, I meant USB 3. I had fantasies of Thunderbolt appearing on the Pi 4.
spl23
Fri Jun 28, 2019 7:16 am
Yes, absolutely. There's nothing RAM-specific in the setup.
Return to “Raspbian”
