matteoraggi
Communicate between raspbian
Fri May 31, 2019 7:42 am
Ho can I communicate easily and quickly between 2 or more raspbian os?
I just need to send a number in real time from one ore multiple raspbian (generally no more of 10) to one raspbian that receive that number.
All the Raspbian are conencted on the web and into the same LAN, rarely into the same wifi.
Raspberry Pi 3 model B - Raspbian 8 Jessie and buster and ubuntu core server 18 lts
Re: Communicate between raspbian
Fri May 31, 2019 8:03 am
The simple answer is MQTT with Mosquitto, HiveMQ or RabbitMQ as the broker.
The publish & subscribe model works for one-to-one, one-to-many, many-to-one and many-to-many messaging.
https://www.hivemq.com/blog/how-to-get- ... with-mqtt/
This is a doctor free zone.
matteoraggi
Fri May 31, 2019 8:36 am
Great! and which is the velocity of the comunication?
Andyroo
Fri May 31, 2019 9:03 am
Depends on how long it takes the number to be created, how busy the LAN / WLAN is, how busy each Pi is and how responsive your programs are to events.
Please remember the Pi is not a real time computer, the kernel has not been built for this and even adding the Linux RTOS additions does not make it one (its better).
Even use cases such as this one are meaningless as your situation and hardware will be totally different.
Define 'real-time' as in my case, I am currently working in blocks of three hours so the process must complete and report back within 179 minutes :o :shock: :o
Without a lot of detail on the environment I think the response will be that you will have to test it on site and see if it is suitable for your needs...
matteoraggi
Fri May 31, 2019 9:35 am
I just have to send a simple signa like one keystroke or one number into a normal LAN/wifi.
Fri May 31, 2019 9:39 am
I just have to send a simple signal like one keystroke or one number into a normal LAN/wifi.
That should be almost instantaneous then.
Return to “Raspbian”
