Hamburger Pi
jessie: openarena doesn't work?
Thu Dec 27, 2018 4:18 am
When I try playing OpenArena (via apt-get) I get a entirely DIFFERENT error.
ioq3 1.36+u20161101+dfsg1-2+deb9u1/Raspbian linux-arm Aug  8 2017
----- FS_Startup -----
We are looking in the current search path:
/home/pi/.openarena/baseoa
/usr/lib/openarena/baseoa
/usr/lib/openarena/baseoa/z_oacmp-volume1-v3.pk3 (370 files)
/usr/lib/openarena/baseoa/pak6-patch088.pk3 (711 files)
/usr/lib/openarena/baseoa/pak6-patch085.pk3 (559 files)
/usr/lib/openarena/baseoa/pak6-misc.pk3 (229 files)
/usr/lib/openarena/baseoa/pak5-TA.pk3 (139 files)
/usr/lib/openarena/baseoa/pak4-textures.pk3 (1753 files)
/usr/lib/openarena/baseoa/pak2-players.pk3 (669 files)
/usr/lib/openarena/baseoa/pak2-players-mature.pk3 (231 files)
/usr/lib/openarena/baseoa/pak1-maps.pk3 (100 files)
/usr/lib/openarena/baseoa/pak0.pk3 (1042 files)
5803 files in pk3 files
execing default.cfg
couldn't exec q3config.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
----- Client Initialization -----
Couldn't read q3history.
----- Initializing Renderer ----
Trying to load "renderer_opengl2_arm.so" from "/usr/lib/ioquake3"...
QKEY found.
----- Client Initialization Complete -----
----- R_Init -----
SDL using driver "x11"
Initializing OpenGL display
Display aspect: 1.778
...setting mode 3: 640 480
Couldn't get a visual
...WARNING: could not set the given mode (3)
----- Client Shutdown (Client fatal crashed: GLimp_Init() - could not load OpenGL subsystem) -----
RE_Shutdown( 1 )
And when I open the crash log...
execing default.cfg
QKEY found.
----- R_Init -----
RE_Shutdown( 1 )
mahjongg
Re: jessie: openarena doesn't work?
Thu Dec 27, 2018 11:54 am
No wonder, you were replying to an obsolete thread, I have split off your post from it, so you can start a new question.
And locked the thread from 2015,
Thu Dec 27, 2018 12:07 pm
execing default.cfg
QKEY found.
----- R_Init -----
RE_Shutdown( 1 )
execing default.cfg
QKEY found.
----- R_Init -----
RE_Shutdown( 1 )
Start with a fresh install of Raspbian Stretch with Desktop (Jessie is no longer current)
https://www.raspberrypi.org/downloads/raspbian/
Update Stretch
sudo apt update
sudo apt full-upgrade
Install OpenArens
sudo apt update
sudo apt install openarena
The version in repositories is 0.8.8
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
Return to “Raspbian”
