raspi-user.france
Disk space eaten up by old kernels/modules - remove old kernels
Fri Dec 21, 2018 3:26 pm
I'm running low on disk space on my Raspberry Pi running Raspbian Lite. I searched around and found that most of the disk space is used by old kernel modules (I think). What I see is:
/lib/modules $ ls -A
4.14.20+     4.14.33-v7+  4.14.44+     4.14.72-v7+  4.14.78+     4.14.81-v7+  4.9.60+     4.9.68-v7+  4.9.76+
4.14.20-v7+  4.14.37+     4.14.44-v7+  4.14.73+     4.14.78-v7+  4.9.53+      4.9.60-v7+  4.9.70+     4.9.76-v7+
4.14.21+     4.14.37-v7+  4.14.48+     4.14.73-v7+  4.14.79+     4.9.53-v7+   4.9.64+     4.9.70-v7+  4.9.77+
4.14.21-v7+  4.14.39+     4.14.48-v7+  4.14.74+     4.14.79-v7+  4.9.56+      4.9.64-v7+  4.9.73+     4.9.77-v7+
4.14.24+     4.14.39-v7+  4.14.54+     4.14.74-v7+  4.14.80+     4.9.56-v7+   4.9.65+     4.9.73-v7+  4.9.79+
4.14.24-v7+  4.14.42+     4.14.54-v7+  4.14.77+     4.14.80-v7+  4.9.57+      4.9.65-v7+  4.9.75+     4.9.79-v7+
4.14.33+     4.14.42-v7+  4.14.72+     4.14.77-v7+  4.14.81+     4.9.57-v7+   4.9.68+     4.9.75-v7+
/lib/modules $ du -hs
3.3G    .
/lib/modules $
Is this normal or am I doing something wrong? I would like to remove all old kernels (except the current one 4.14.81-v7 and maybe one previous one).
I'm anxious to just delete these folders manually with "sudo rm -r ..." as this might break something else (thinking of dependencies). I tried and searched if "apt ..." can be used to get rid of old kernels but also with no luck so far.
Any ideas, hint, comments or background information on what I see regarding my disk usage and how to get rid of the old kernels?
fbe
Re: Disk space eaten up by old kernels/modules - remove old kernels
Fri Dec 21, 2018 3:58 pm
Don't run rpi-update.
ericcooper
Fri Dec 21, 2018 5:02 pm
The latest version of the raspberrypi-kernel package in stretch ships the 4.14.79{,-v7+} modules directories. I guess the .80 and .81 versions came from pi-update, which as mentioned you don't need to be using, just apt update and upgrade.
So you can manually remove (rm -r) modules directories older than 4.14.79. There aren't any dependencies on them other than the corresponding kernels themselves, which are probably no longer present (check /boot to be sure).
Fri Dec 21, 2018 5:10 pm
If you must run rpi-update run
PRUNE_MODULES=1 rpi-update
Although the best strategy is NEVER run rpi-update.
This is a doctor free zone.
MrEngman
Fri Dec 21, 2018 5:51 pm
I'm running Raspbian lite on most of my PI and have used sudo rm -r /lib/modules/... to remove old kernel version module directories and haven't noticed any issues.
raspi-user.france
Sat Jan 05, 2019 8:41 am
Thanks for the feedback - I manually removed the old kernels/moduls and it seems to be working fine (and finally giving me back my disk-space)!
One question: what is the purpose of "rpi-update" at all (if one should not use it and it only messes up an installation)?
Sat Jan 05, 2019 8:56 am
Originally it was the only way to update the kernel, modules and bootloader for the Pi. Now that they have all been packaged up neatly, it is not needed by 99% of users.
Now it is used to get experimental versions of the kernel etc for testing purposes. Some of these kernels will eventually be packaged up and become available via apt-get as normal. Generally if you use rpi-update you should be aware that the resulting updates may not have been fully tested yet and could break your system. You are expected to be able to fix it yourself f that happens.
Return to “Raspbian”
