spock
starting omxplayer in .profile
Wed Dec 05, 2018 12:44 pm
i would like to start omxplayer automatically after booting. so i have put it into .profile and it works fine but i also need to be able to quit it with esc. why doesn't this work if i put stuff in .profile? how can i achieve this in a non-complicated way? :)
ksharindam
Re: starting omxplayer in .profile
Wed Dec 05, 2018 5:00 pm
to control omxplayer, such as quit by pressing Esc, you have to run omxplayer in terminal.
To run omxplayer in fullscreen in xterm, use this command...
xterm -fullscreen -e omxplayer -b file.mp4
You have to put this command in .profile
My Qt projects at ... https://github.com/ksharindam
spock
Wed Dec 05, 2018 6:54 pm
thanks for your answer! :)
what i forgot to say is that i boot to the cli and not to x.
isn't xterm for x?
ksharindam
Thu Dec 06, 2018 1:49 pm
Yes, xterm requires xserver.
If you are running it in cmdline , then it should not require any terminal for keyboard input.
I dont know why it is not taking keyboard input.
fbe
Thu Dec 06, 2018 9:03 pm
/home/pi/.profile is executed not on boot but on login as user pi.
I appended a line to /home/pi/.profile
omxplayer /opt/vc/src/hello_pi/hello_video/test.h264
and omxplayer is running after login and stopping on <esc> no matter whether I automatically or manually login as pi on the CLI or login via ssh.
I'm running current Raspian Stretch with desktop (without recommended software).
spock
Fri Dec 07, 2018 3:23 pm
hm... strange!
i did it like you and can't esc. :(
spock
Tue May 21, 2019 8:47 am
it still doesn't work for me.
i am using the CLI. if start omxplayer directly from the command prompt it works.
but if i start it from a .sh script (i noticed it doesn't only happen if i put it into .profile) then it doesn't react to any keyboard presses. i have to reset the pi afterwards.
does nobody else have that problem? :)
Return to “Raspbian”
