Yaroslav.Savelev
archive.raspberrypi.org error
Mon Jul 23, 2018 3:12 am
After I installed new version of raspbian i tried to upgrade my system and there was en error:
The repository 'http://archive.raspberrypi.org/debian stretch Release' does no longer have a Release file.
awrc
Re: archive.raspberrypi.org error
Mon Jul 23, 2018 3:40 pm
I'm encountering the same problem. Specifically, attempting 'apt-get update' produced the following errors:
E: The repository 'http://archive.raspberrypi.org/debian stretch Release' does no longer have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Trying it again a couple of times seems to have resulted in the error going away. Just a transient error, perhaps? It'd be nice to know what caused it though, and if this was something that was fixed at the repository end, rather than apt-get just dropped to a lower level of security to get around it.
A
Paeryn
Mon Jul 23, 2018 6:43 pm
I had that error yesterday, though I'm sure elsewhere in the output it indicated that the site was unreachable (or some such). I take it something like this happens (I don't know the inner workings of apt but a rough guess) :-
In times of high load apt might see the site at first and assume the repo is available but then a subsequent request to get the Release file fails because the server is too busy, this causes apt to assume the repo is invalid and so it gives up.
Usually trying again later will work (may take a few attempts).
DirkS
Mon Jul 23, 2018 6:46 pm
Probably just a little networking blip.
BTW: was the message you posted all you got?
I just had the same message, but before that there was a clear message 'service unavailable' with an IP address:
Get:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease [15.0 kB]
Ign:2 http://archive.raspberrypi.org/debian stretch InRelease
Err:3 http://archive.raspberrypi.org/debian stretch Release
  503  Service Unavailable [IP: 93.93.135.188 80]
Get:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages [11.7 MB]
Reading package lists... Done
Running update again solved the problem
DirkS
Mon Jul 23, 2018 6:48 pm
Probably 'service unavailable' as I mentioned in my previous post.
Paeryn
Mon Jul 23, 2018 7:06 pm
That will be what it said, I knew gist of it but couldn't remember off the top of my head the exact phrase apt used.
Feriman
Tue Jul 24, 2018 8:19 pm
I got same error in my configuration.
antus
Fri Jul 27, 2018 11:33 am
This is still hapenning. I just attempted to install some build utils and got (same host ip)
Need to get 853 kB/5,103 kB of archives.
After this operation, 16.6 MB of additional disk space will be used.
Err http://archive.raspberrypi.org/debian/ jessie/main dh-autoreconf all 12~bpo8+1
Err http://archive.raspberrypi.org/debian/ jessie/main debhelper all 10.2.2~bpo8+1
E: Failed to fetch http://archive.raspberrypi.org/debian/p ... +1_all.deb 503 Service Unavailable [IP: 93.93.135.188 80]
I then cut and paste the URL straight out of the terminal in to firefox on windows and the file loaded. Thinking it was pi wierdness I found this thread which said several retries later the error went away. I tried again on the pi, and all good. Some archive.raspberrypi.org maintainers might need to look at the server logs to see whats up.
Quite possibly its high server load on their side and the host cant keep up....
Fri Jul 27, 2018 11:46 am
If I run a apt-get update && apt-get dist-upgrade across my fifteen Raspberries I'll see that same error on about three of them.
It looks like a bug in some web workload balancer / caching system somewhere out in the wild of the internets because one minute after a failure it works perfectly normally.
This is a doctor free zone.
gopackgo90
Fri Jul 27, 2018 6:03 pm
I'm seeing the same error on one Raspberry Pi 3 and one Raspberry Pi 3 B+, both running Raspbian Stretch. I was getting the 503 error message, but now the Release file doesn't even look to be attempted. I also haven't gotten any updates in a few weeks, which seems unusual.
pi@raspberrypi:~ $ sudo apt-get update
Hit:1 http://archive.raspberrypi.org/debian stretch InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
pi@raspberrypi:~ $ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  lxkeymap python-cairo python-gtk2 python-xklavier
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Edit: Maybe this is normal. After looking at another PC running Ubuntu, doing apt-get update only shows InRelease files as well. But I still haven't gotten any updates since 7/16 according to /var/log/apt/history.log:
Start-Date: 2018-07-16 21:33:57
Commandline: apt-get upgrade
Requested-By: pi (1000)
Upgrade: postgresql-common:armhf (181+deb9u1, 181+deb9u2), postgresql-client-9.6:armhf (9.6.7-0+deb9u1, 9.6.9-0+deb9u1), rc-gui:armhf (1.20, 1.21), raspberrypi-ui-mods:armhf (1.20180530, 1.20180706), lxplug-ptbatt:armhf (0.3, 0.4), libsystemd0:armhf (232-25+deb9u2, 232-25+deb9u4), libgs9:armhf (9.20~dfsg-3.2+deb9u1, 9.20~dfsg-3.2+deb9u2), udev:armhf (232-25+deb9u2, 232-25+deb9u4), piclone:armhf (0.9, 0.10), libmagic1:armhf (1:5.30-1+deb9u1, 1:5.30-1+deb9u2), libpq5:armhf (9.6.7-0+deb9u1, 9.6.9-0+deb9u1), apache2-data:armhf (2.4.25-3+deb9u4, 2.4.25-3+deb9u5), libudev1:armhf (232-25+deb9u2, 232-25+deb9u4), libpq-dev:armhf (9.6.7-0+deb9u1, 9.6.9-0+deb9u1), dpkg:armhf (1.18.24, 1.18.25), libmagic-mgc:armhf (1:5.30-1+deb9u1, 1:5.30-1+deb9u2), postgresql-9.6:armhf (9.6.7-0+deb9u1, 9.6.9-0+deb9u1), libudev-dev:armhf (232-25+deb9u2, 232-25+deb9u4), systemd-sysv:armhf (232-25+deb9u2, 232-25+deb9u4), postgresql:armhf (9.6+181+deb9u1, 9.6+181+deb9u2), libpam-systemd:armhf (232-25+deb9u2, 232-25+deb9u4), ghostscript:armhf (9.20~dfsg-3.2+deb9u1, 9.20~dfsg-3.2+deb9u2), shared-mime-info:armhf (1.8-1, 1.8-1+deb9u1), systemd:armhf (232-25+deb9u2, 232-25+deb9u4), lxplug-network:armhf (0.11, 0.12), postgresql-contrib-9.6:armhf (9.6.7-0+deb9u1, 9.6.9-0+deb9u1), libgs9-common:armhf (9.20~dfsg-3.2+deb9u1, 9.20~dfsg-3.2+deb9u2), file:armhf (1:5.30-1+deb9u1, 1:5.30-1+deb9u2), pipanel:armhf (20180621~152457, 20180706~092558), apache2-bin:armhf (2.4.25-3+deb9u4, 2.4.25-3+deb9u5), ca-certificates:armhf (20161130+nmu1, 20161130+nmu1+deb9u1), apache2:armhf (2.4.25-3+deb9u4, 2.4.25-3+deb9u5), apache2-utils:armhf (2.4.25-3+deb9u4, 2.4.25-3+deb9u5), libdpkg-perl:armhf (1.18.24, 1.18.25), patch:armhf (2.7.5-1, 2.7.5-1+deb9u1), libfaad2:armhf (2.8.0~cvs20161113-1, 2.8.0~cvs20161113-1+deb9u1), devscripts:armhf (2.17.6+deb9u1, 2.17.6+deb9u2), dpkg-dev:armhf (1.18.24, 1.18.25), postgresql-client-common:armhf (181+deb9u1, 181+deb9u2), tzdata:armhf (2018c-0+deb9u1, 2018e-0+deb9u1)
End-Date: 2018-07-16 21:37:06
Start-Date: 2018-07-16 21:40:42
Commandline: apt-get -y dist-upgrade
Install: libc-ares2:armhf (1.14.0-1~bpo9+1, automatic), python3-gi-cairo:armhf (3.22.0-2, automatic), libhttp-parser2.8:armhf (2.8.1-1~bpo9+1, automatic), nodejs-doc:armhf (8.11.1~dfsg-2~bpo9+1, automatic), python3-cairo:armhf (1.10.0+dfsg-5, automatic)
Upgrade: nodered:armhf (0.18.7-1, 0.18.7-3), nodejs:armhf (4.8.2~dfsg-1, 8.11.1~dfsg-2~bpo9+1), sense-emu-tools:armhf (1.0, 1.1)
Remove: nodejs-legacy:armhf (4.8.2~dfsg-1)
End-Date: 2018-07-16 21:41:23
silvia
Tue Feb 05, 2019 8:56 am
Hi All,
I'm having the same problem with Raspbian Stretch and apt-get... I can't install or even update!
pi@RPi-gateway:~ $ sudo apt-get update
Ign:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Err:3 http://raspbian.raspberrypi.org/raspbian stretch Release
  404  Not Found [IP: 5.153.225.207 80]
E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does no longer have a Release file.
However, I can ping the IP address listed in the error.
From what I've read here, it seems like I'll have to keep on trying...!
driverav
Tue Feb 05, 2019 9:02 am
I'm seeing exactly the same thing with the same IP address - I expect this is a temporary repo outage.
Tue Feb 05, 2019 11:19 am
I believe the repos were being updated. During this short time certain files may be unavailable. Try again after an hour or so.
lehangajanayake
Wed Apr 10, 2019 3:37 pm
Guys check wether you have changed the following file: /etc/dhcpcd.conf
i had the same issue after changing that file. the cuase may be IPv6 adrresse and the domain names.
If you are going to mess with ip's be carefull even tough an experienced one!!
lrhorer
Tue Jul 09, 2019 11:45 am
The main question here is, "Why is apt trying to get resources from a target in Wheezy?" We are on Stretch, and the sources.list file only contains:
deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free rpi
I don't see any way this could be anything but errata in the distribution
plugwash
Sat Jul 13, 2019 3:28 pm
Have you looked in /etc/apt/sources.list.d ?
qunootalsahi
Fri Dec 13, 2019 3:09 am
hi every body can any one help me in this error
W: The repository 'http://archive.raspbian.org/raspbian wheezy Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
E: Failed to fetch http://archive.raspbian.org/raspbian/di ... ce/Sources 404 Not Found [IP: 93.93.128.191 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Return to “Raspbian”
