3rdGear
Raspberry Pi as a remote keyboard
Sun Mar 18, 2018 12:16 am
I have a project in mind and I need some help.
1) ssh into my raspberry pie. [easy done]
2) have the Raspberry pie connected to a PC via a usb cable [the usb cable would need to have two male ends] [easy done]
3) push keyboard command from the raspberry to the pc via the USB cable.
So if someone could point me in the right direction on how to make the raspberry push keyboard commands to a pc via a usb cable that would be a great help.
Thank you in advance.
Pete Smith
Re: Raspberry Pi as a remote keyboard
Sun Mar 18, 2018 7:52 am
Pete Smith
If you have a Raspberry Pi Zero then you can use Gadget Mode.
Please be aware USB needs a Host & Slave so connecting 2 slaves will not work.
Retired disgracefully.....
......to a more gentile life !
vladnt
Tue Mar 20, 2018 7:08 pm
Realized on Zero W, through VNC. Mouse + keyboard + USB flash drive.
I can send an archive to the mail, with scripts and code in python
https://github.com/vladrobot/Raspberry-GadgetFS.git
Return to “Raspbian”
