mob-i-l
Contact: Website Facebook Google+ Twitter YouTube
A beep that works in Raspbian Stretch
Sat Feb 03, 2018 4:08 pm
Here is a Bash-function for Raspberry Pi that beeps with a frequency (Hz) for a time (s) that can have decimals.
raspi-beep () { ( speaker-test -t sine -c 2 -s 2 -f $1 & TASK_PID=$! ; sleep $2 ; kill -s SIGINT $TASK_PID ) > /dev/null
Test:
raspi-beep 440 .7 ; raspi-beep 880 .5
There is a beep in Raspbian Stretch, but that doesn't work, but you can install it:
sudo apt install beep
I think the original beep should be fixed so that it works with e.g. the songs in https://github.com/ShaneMcC/beeps .
Also
ESC [ 10 ; n ] Set bell frequency in Hz.
ESC [ 11 ; n ] Set bell duration in msec.
does not work in Linux Console (that you can change to by e.g. Ctrl+Alt+F1 in X and back with Ctrl+Alt+F7).
printf "\e[10;440]\e[11;700]\a\e[10;880]\e[11;500]\a"
should sound as above, but is now silent. See
man console_codes
. This ought also be fixed.
Have Pi0&1A&1B&1B+&2B&3B&4B w/ Raspbian. Started w/ BASIC on ABC80&ZX81 then Forth, Z80… https://scratch.mit.edu/users/mobluse/ https://github.com/mobluse/ https://twitter.com/mobluse/ https://YouTube.com/MOBiL4u/
scruss
Re: A beep that works in Raspbian Stretch
Sat Feb 03, 2018 8:06 pm
beep is an ancient (c. 2002) command for making the PC Speaker make (horrid, square-wave) noise. As the Raspberry Pi has no PC speaker compatibility (or pcspkr module), it's not likely to work. Also, since beep is an upstream Debian package, the replacement package would have to be called something other than beep. So your compatibility is shot from the outset.
It might be better to convert these scripts to RTTTL or sox/play synth commands.
sparkie777
Sat Feb 03, 2018 8:41 pm
like this
play -n synth .3 sine A
scruss
Sun Feb 04, 2018 1:01 am
Yup. Or even:
play -n synth pl "F2" pl "G2" pl "C3" pl "D3" pl "E3" pl "F3" pl "F#3" pl "G3" pl "A3" pl "A#3" pl "B3" pl "C4" pl "C#4" pl "D4" pl "D#4" pl "E4" pl "F4" pl "F#4" pl "G4" pl "G#4" pl "A4" pl "A#4" pl "B4" pl "C5" pl "C#5" pl "D5" pl "D#5" pl "E5" pl "F5" pl "F#5" pl "G5" pl "G#5" pl "A5" pl "A#5" pl "B5" pl "C6" delay 0 0.05 0.1 0.15 0.2 0.25 0.3 0.35 0.4 0.45 0.5 0.55 0.6 0.65 0.7 0.75 0.8 0.85 0.9 0.95 1 1.05 1.1 1.15 1.2 1.25 1.3 1.35 1.4 1.45 1.5 1.55 1.6 1.65 1.7 1.75 remix - fade 0 6 .1 reverb norm -1
which, if you're of a certain age, you'll remember as the “Bagpuss wakes up” sound. In reality, it's all 36 strings of an Autoharp® strummed slowly with a touch of reverb.
I'd like to hear beep try that one …
mob-i-l
Mon Feb 05, 2018 4:31 pm
Thanks!
An alternative to above is after
sudo apt install sox
raspi-beep2 () { play -n -c 2 synth $2 sin $1 2> /dev/null; }
raspi-beep2 440 .7 ; raspi-beep2 880 .5
It is slightly louder. The first alternative is built-in.
Return to “Raspbian”
