BorbingoBoy
Toggling GL and Boot Mode w/o raspi-config
Sat Jan 20, 2018 4:13 pm
Do you use RetroPie and PIXEL at the same time? Do you not want to to use raspi-config to toggle GL and boot mode every time? Do you prefer to save time and sanity? Well, fear not, this script is for you!
BorbingoBoy wrote:
Thu Jan 25, 2018 4:23 pm
Thank you, DougieLawson, for making it happen! :)
How to use: Copy the code below and paste it in a new empty file with the name of your choice (for example, 'gl'), the sh extension isn't necessary. Open terminal and enter sudo cp [file name] /usr/bin/. Finally, enter sudo chmod -rwxr-xr-x /usr/bin/[file name]. You are done!
To run it, just enter sudo [file name]. I made it option-based, the menus should be self-explanatory. That's it!
#!/bin/bash
if [ $(id -u) -ne 0 ]; then
  printf "Reminder: use sudo!\n"
  exit 1
fi
echo GL toggler for Raspbian.
echo Code is mainly copied from raspi-config. BorbingoBoy 2018
echo Special thanks to DougieLawson
# Start of functions
# Enable GL driver
do_G1() {
        if ! grep -q -E "^dtoverlay=vc4-kms-v3d" /boot/config.txt; then
          ASK_TO_REBOOT=1
        fi
        sed /boot/config.txt -i -e "s/^dtoverlay=vc4-fkms-v3d/#dtoverlay=vc4-fkms-v3d/"
        sed /boot/config.txt -i -e "s/^#dtoverlay=vc4-kms-v3d/dtoverlay=vc4-kms-v3d/"
          printf "dtoverlay=vc4-kms-v3d\n" >> /boot/config.txt
        fi
        STATUS="The full KMS GL driver is enabled."
# Disable GL driver
do_G3() {
        if grep -q -E "^dtoverlay=vc4-f?kms-v3d" /boot/config.txt; then
          ASK_TO_REBOOT=1
        fi
        sed /boot/config.txt -i -e "s/^dtoverlay=vc4-kms-v3d/#dtoverlay=vc4-kms-v3d/"
        STATUS="The GL driver is disabled."
# Boot to CLI
do_CLI() {
         systemctl set-default multi-user.target
         ln -fs /etc/systemd/system/autologin@.service /etc/systemd/system/getty.target.wants/getty@tty1.service
# Boot to desktop
do_DSKTP() {
           systemctl set-default graphical.target
# End of functions
# Dialog enable/disable
echo What would you like to do?
PS3='Choice: '
options=("Enable GL" "Disable GL" "Cancel and Reboot" "Cancel")
select opt in "${options[@]}"
do
    case $opt in
        "Enable GL")
            do_G1
            break
        "Disable GL")
            do_G3
            break
        "Cancel and Reboot")
            reboot
            break
        "Cancel")
            break
        *) echo invalid option;;
    esac
done
# Dialog for changing boot mode
echo Where would you like to boot next?
PS3='Choice: '
options=("To Desktop" "To CLI" "Cancel and Reboot" "Cancel")
do
    case $opt in
        "To Desktop")
            do_DSKTP
            break
        "To CLI")
            do_CLI
            break
            reboot
            break
        "Cancel")
            break
    esac
done
# Dialog for confirming final reboot
echo Reboot?
PS3='Choice: '
options=("Yes" "No")
do
    case $opt in
        "Yes")
            reboot
            break
        "No")
            break
    esac
done
Original post
I have ExaGear and RetroPie installed on my Raspberry Pi 3, Raspbian Jessie. In order to play 3D games and such, GL driver must be on (and booting to desktop is, of course, required), but in order to use RetroPie, the GL driver must be off, and booting to CLI is required.
Which commands should I use instead of using raspi-config to toggle (full) GL driver and to change boot mode (desktop/CLI)?
By the way, I am planning to create two shell scripts to toggle GL driver, change boot mode and restart, so that I wouldn't have to enter all of the commands every time.
Thank you!
3.1415926535897932384626433832795028841971693993751058209749445923078164062862089986280348253421170679821480865132823066470938446095505822317253594081284811174502841027019385211055596446229489549303819644288109756659334461284756482337867831652712019091456
Re: Toggling OpenGL Driver w/o raspi-config?
Sat Jan 20, 2018 4:42 pm
Read /usr/bin/raspi-config it's a bash shell script, you should be able to see how it makes the change.
You can also "source" /usr/bin/raspi-config and use the functions in it in your own programs (without using the menus).
https://bash.cyberciti.biz/guide/Source_command
This is a doctor free zone.
BorbingoBoy
Sat Jan 20, 2018 6:23 pm
#!/bin/sh
# Enable
#       if ! grep -q -E "^dtoverlay=vc4-kms-v3d" $CONFIG; then
#         ASK_TO_REBOOT=1
#       fi
		sed $CONFIG -i -e "s/^dtoverlay=vc4-fkms-v3d/#dtoverlay=vc4-fkms-v3d/"
		sed $CONFIG -i -e "s/^#dtoverlay=vc4-kms-v3d/dtoverlay=vc4-kms-v3d/"
			printf "dtoverlay=vc4-kms-v3d\n" >> $CONFIG
		fi
#       STATUS="The full KMS GL driver is enabled."
# Disable
#       if grep -q -E "^dtoverlay=vc4-f?kms-v3d" $CONFIG; then
#         ASK_TO_REBOOT=1
#       fi
        sed $CONFIG -i -e "s/^dtoverlay=vc4-kms-v3d/#dtoverlay=vc4-kms-v3d/"
#       STATUS="The GL driver is disabled."
I should use this, right?
Sat Jan 20, 2018 6:27 pm
Probably, I've never looked because that OpenGL stuff doesn't interest me.
BorbingoBoy
Sat Jan 20, 2018 6:54 pm
To CLI, GL off:
#!/bin/sh
# Disable GL driver
#         ASK_TO_REBOOT=1
#       fi
# Boot to CLI
        if [ $SYSTEMD -eq 1 ]; then
        else
          [ -e /etc/init.d/lightdm ] && update-rc.d lightdm disable 2
          sed /etc/inittab -i -e "s/1:2345:respawn:\/sbin\/getty --noclear 38400 tty1/1:2345:respawn:\/bin\/login -f pi tty1 <\/dev\/tty1 >\/dev\/tty1 2>&1/"
        fi
reboot
I get:
sed: no input files
sed: no input files
./nogl_cli_test.sh: 10: ./nogl_cli_test.sh: Syntax error: ";;" unexpected
To desktop, GL on:
#!/bin/sh
# Enable GL driver
#         ASK_TO_REBOOT=1
#       fi
		fi
# Boot to desktop
        if [ -e /etc/init.d/lightdm ]; then
          if id -u pi > /dev/null 2>&1; then
            else
              update-rc.d lightdm enable 2
            fi
            sed /etc/lightdm/lightdm.conf -i -e "s/^\(#\|\)autologin-user=.*/autologin-user=pi/"
            disable_raspi_config_at_boot
#         else
#            whiptail --msgbox "The pi user has been removed, can't set up boot to desktop" 20 60 2
          fi
#       else
#         whiptail --msgbox "Do sudo apt-get install lightdm to allow configuration of boot to desktop" 20 60 2
#         return 1
        fi
reboot
I get:
sed: no input files
sed: no input files
And the prompt wouldn't appear.
Could you help me, please?
Sat Jan 20, 2018 8:52 pm
Turn the code from /usr/bin/raspi-config into three functions
do_G1() {
          ASK_TO_REBOOT=1
        fi
        fi
  do_G2() {
        if ! grep -q -E "^dtoverlay=vc4-fkms-v3d" /boot/config.txt; then
          ASK_TO_REBOOT=1
        fi
        sed /boot/config.txt -i -e "s/^#dtoverlay=vc4-fkms-v3d/dtoverlay=vc4-fkms-v3d/"
          printf "dtoverlay=vc4-fkms-v3d\n" >> /boot/config.txt
        fi
        STATUS="The fake KMS GL driver is enabled."
  do_G3() {
          ASK_TO_REBOOT=1
        fi
You can then call any one of those to set full vc4-kms-v3d call do_G1(), fake vc4-fkms-v3d call do_G2() or legacy call do_G3() from your main line code. Since you're editing /boot/config.txt you'll need to run as root (sudo)
BorbingoBoy
Tue Jan 23, 2018 4:05 pm
Thank you, it worked! What should I replace $SYSTEMD with, though?
Thanks again!
Wed Jan 24, 2018 9:23 am
Sorry I have no idea what you're asking.
BorbingoBoy
Wed Jan 24, 2018 1:49 pm
I'm sorry if I wasn't clear. I'm trying to find what I should replace $SYSTEMD with here (also code from raspi-config):
# Boot to CLI
        else
        fi
It doesn't appear to work if the string isn't defined.
Thu Jan 25, 2018 7:43 am
# Boot to CLI
        else
        fi
Change that to
# Boot to CLI
BorbingoBoy
Yaay, I finally made it! Thank you, DougieLawson, for making it happen! :)
How to use: Copy the code below and paste it in a new empty file with the name of your choice (for example, 'gl'), the sh extension isn't necessary. Open terminal and enter sudo cp [file name] /usr/bin/. Finally, enter sudo chmod -rwxr-xr-x /usr/bin/[file name]. I made it option-based, the menus should be self-explanatory. You are done!
To run it, just enter sudo [file name]. That's it!
#!/bin/bash
  exit 1
fi
# Enable GL driver
do_G1() {
          ASK_TO_REBOOT=1
        fi
        fi
# Disable GL driver
do_G3() {
          ASK_TO_REBOOT=1
        fi
# Boot to CLI
do_CLI() {
# Boot to desktop
do_DSKTP() {
# End of functions
PS3='Choice: '
do
    case $opt in
        "Enable GL")
            do_G1
            break
        "Disable GL")
            do_G3
            break
            reboot
            break
        "Cancel")
            break
    esac
done
PS3='Choice: '
do
    case $opt in
        "To Desktop")
            do_DSKTP
            break
        "To CLI")
            do_CLI
            break
            reboot
            break
        "Cancel")
            break
    esac
done
echo Reboot?
PS3='Choice: '
do
    case $opt in
        "Yes")
            reboot
            break
        "No")
            break
    esac
done
Return to “Raspbian”
