AJSG1969
Manual Wifi setup DISABLED WPA_Supplicant
Mon Dec 18, 2017 10:59 am
I'm trying to connect a Pi3 to my local network but have had to disable WPA_Supplivant (apt-get remove) and disabled Avahi Daemon.
I have tried to make sure the bult in interface (wlan0) sees the SSID and it does using
sudo iwlist wlan0 scan
Tried editing the old /etc/network/interfaces file to include:
auto wlan0
allow-hotplug wlan0
iface wlan0 inet static
address 123.456.789.123
netmask 255.255.255.0
gateway 123.456.789.121
wpa-passphrase password
wpa-ssid myssid
Does anyone have any suggestions as to what might be going wrong?
Thanks.
Re: Manual Wifi setup DISABLED WPA_Supplicant
Thu Dec 21, 2017 5:42 am
Take all of that stuff out of /etc/network/interfaces.
Add the fixed IP stuff in /etc/dhcpcd.conf.
Add the WiFi credentials in a
network={
 ssid="myssid"
 psk="password"
block at the bottom of /etc/wpa_supplicant/wpa_supplicant.conf
Reboot and it should connect.
This is a doctor free zone.
AJSG1969
Thu Dec 21, 2017 2:54 pm
I've tried that but it ends up enabling Wifi on the wrong adapter.
I have also tried re-enabling wpa_supplicant and making two separate config files:
wlan0_wpa_supplicant.conf
wlan1_wpa_supplicant.conf
With real SSID/pass in wlan0 and test/test for wlan1
Unfortunately it connects wlan1 to the SSID parameters of wlan0!!
I changed sudo nano /etc/network/interfaces to
source-directory /etc/network/interfaces.d
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
wpa-conf /etc/wpa_supplicant/wlan0_wpa_supplicant.conf
auto wlan1
allow-hotplug wlan1
iface wlan1 inet manual
wpa-conf /etc/wpa_supplicant/wlan1_wpa_supplicant.conf
Ideally I need to onbord wifi to connect and the USB adapter to remain disconnected
Thanks.
davesteele
Thu Dec 21, 2017 8:54 pm
Comitup would handle this the way you want.
https://davesteele.github.io/comitup/
Return to “Raspbian”
