davesteele
A Python asyncio example using the PiHut 3D XMas Tree
Sat Dec 02, 2017 4:36 am
Here's some demonstration code, using Python asyncio, to blink the lights on the PiHut 3D XMas Tree.
https://github.com/davesteele/pihut-xmas-asyncio
#!/usr/bin/python3
import asyncio
import random
import RPi.GPIO as GPIO
# time in seconds
ONTIME = 1.5
OFFTIME = .3
# Random range in the times (between 0 and 1)
PLUSORMINUS = .3
GPIO.setmode(GPIO.BCM)
def calcplusorminus(val, var):
    """return random number in the range val +/- (var*100)%"""
    factor = (1.0 - var) + (random.random() * 2 * var)
    return factor * val
async def blink_led(ledno):
    ontime = calcplusorminus(ONTIME, PLUSORMINUS)
    offtime = calcplusorminus(OFFTIME, PLUSORMINUS)
    GPIO.setup(ledno, GPIO.OUT)
    while True:
        GPIO.output(ledno, GPIO.HIGH)
        await asyncio.sleep(ontime)
        GPIO.output(ledno, GPIO.LOW)
        await asyncio.sleep(offtime)
loop = asyncio.get_event_loop()
tasks = [asyncio.ensure_future(blink_led(x)) for x in range(2, 28)]
loop.run_forever()
loop.close()
Return to “Raspbian”
