PlanB
Identifying OS fully
Sat Nov 18, 2017 6:47 am
I've got a version of Jessie lite that responds to cat /etc/os-release with
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
Trouble is it wouldn't let me apt-get install libopencv-dev or libusb-1.0-0-dev until I overhauled it with
apt-get autoremove && sudo apt-get -f install && sudo apt-get update && sudo apt-get upgrade -y
Thing is the overhauled version still identifies the same as before. Is there some other cmd to pin down different variants of the OS? I'm troubled that sd cards with different behaviours can't be labeled in some way.
ghans
Re: Identifying OS fully
Sat Nov 18, 2017 8:47 am
cat /boot/issue.txt
lsb_release -a
PlanB
Sat Nov 18, 2017 10:52 am
Same result for both
ghans
Sat Nov 18, 2017 10:57 am
Please post the full output of all three commands mentioned in this thread.
ghans
PlanB
Sat Nov 18, 2017 1:09 pm
root@raspberrypi:/home/pi# cat /etc/os-release
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
root@raspberrypi:/home/pi# cat /boot/issue.txt
Raspberry Pi reference 2016-05-27
Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 5add7283d4db4eaad785de41a6750e909e5a04cf, stage2
root@raspberrypi:/home/pi# lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 8.0 (jessie)
Release: 8.0
Codename: jessie
topguy
Fri Nov 24, 2017 1:46 pm
If you needed to run those commands it was most likely because of other "apt-get" commands from earlier that had not completed properly.
Also starting with "apt-get update" is a good idea. But none of these commands will change the observed OS version, you have just upgraded a few components of that OS. So the word "overhauling" has no meaning in this context.
Return to “Raspbian”
