Swampy42
Re: Realtek wireless adapter not connecting in Stretch (Jessie OK)
Sun Nov 04, 2018 2:36 pm
Tested and It worked! :o
Did you fork this repository from chunkeey?
Thank you very much :D
Linux is like wigwam: no Gates, no Windows and Apache inside.
fiisch
Thu Nov 08, 2018 10:33 pm
You're welcome! :-)
Yes, I forked from chunkeey, but was too lazy for a pull request...
Swampy42
Sat Nov 17, 2018 11:54 am
The script from drmullins is not working for me now:
/root/rtl8192su/r92su/main.c:1333:25: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
  .change_virtual_intf = r92su_change_virtual_intf,
/root/rtl8192su/r92su/main.c:1333:25: note: (near initialization for ‘r92su_cfg80211_ops.change_virtual_intf’)
/root/rtl8192su/r92su/main.c: In function ‘r92su_if_setup’:
/root/rtl8192su/r92su/main.c:1741:6: error: ‘struct net_device’ has no member named ‘destructor’; did you mean ‘priv_destructor’?
  ndev->destructor = free_netdev;
cc1: some warnings being treated as errors
scripts/Makefile.build:328: die Regel für Ziel „/root/rtl8192su/r92su/main.o“ scheiterte
make[2]: *** [/root/rtl8192su/r92su/main.o] Fehler 1
Makefile:1527: die Regel für Ziel „_module_/root/rtl8192su/r92su“ scheiterte
make[1]: *** [_module_/root/rtl8192su/r92su] Fehler 2
make[1]: Verzeichnis „/usr/src/linux-headers-4.14.79+“ wird verlassen
Makefile.r92su:24: die Regel für Ziel „all“ scheiterte
make: *** [all] Fehler 2
I changed the script for me like drmullins posted in:
https://github.com/raspberrypi/linux/issues/2185
#!/bin/bash
# Install r92su kernel module replacing r8712u
apt-get update
apt-get install raspberrypi-kernel-headers
cd ~
git clone https://github.com/asig/rtl8192su.git
cd rtl8192su
make -f Makefile.r92su
UPDATES=/lib/modules/$(uname -r)/updates
if [ ! -d $UPDATES ] ; then
mkdir $UPDATES
echo creating $UPDATES
fi
cp r92su/r92su.ko $UPDATES
if [ ! -e /etc/modprobe.d/blacklist-r8712u.conf ] ; then
echo "blacklist r8712u" >/etc/modprobe.d/blacklist-r8712u.conf
fi
depmod
Crazyhorse605
Mon Nov 26, 2018 2:38 pm
Thanks for all this work. I tried it on the older kernel, 4.14.79 and the connection continusly dropped.
Updated to 4.14.82 and the makefile does not work. I have :
sudo make -f Makefile.r92su
make -C /lib/modules/4.14.82-v7+/build M=/home/pi/rtl8192su/r92su CONFIG_R92SU=m CONFIG_R92SU_WPC=y EXTRA_CFLAGS="-DDEBUG -DCONFIG_R92SU=m -DCONFIG_R92SU_WPC=y"
make[1]: *** /lib/modules/4.14.82-v7+/build: No such file or directory. Stop.
Makefile.r92su:24: recipe for target 'all' failed
make: *** [all] Error 2
I cannot see anything like in the other directory and have run all calls in the example file above.
Swampy42
Sat Dec 01, 2018 10:52 am
Hello Crazyhorse605,
Remove the rtl8192su folder in home, before you try it.
I also had the problem, but I can't remember whether this was reason.
MrEngman
Sat Dec 01, 2018 1:49 pm
/lib/modules/4.14.82-v7+/build is a symlink to the kernel source/headers directory.
You can create the link using command like
sudo ln -s /home/pi/src/linux /lib/modules/$(uname -r)/build
Change /home/pi/src/linux to the directory where your Linux source/headers are.
Swampy42
Fri May 31, 2019 4:48 pm
New problems with kernel 4.19.42 while executing the script:
make[1]: Verzeichnis „/usr/src/linux-headers-4.19.42+“ wird betreten
  CC [M]  /root/rtl8192su/r92su/michael.o
  CC [M]  /root/rtl8192su/r92su/aes_ccm.o
  CC [M]  /root/rtl8192su/r92su/eeprom.o
  CC [M]  /root/rtl8192su/r92su/event.o
  CC [M]  /root/rtl8192su/r92su/debug.o
  CC [M]  /root/rtl8192su/r92su/main.o
/root/rtl8192su/r92su/main.c: In function ‘r92su_bss_add_work’:
/root/rtl8192su/r92su/main.c:716:10: error: implicit declaration of function ‘ACCESS_ONCE’ [-Werror=implicit-function-declaration]
   node = ACCESS_ONCE(node->next);
/root/rtl8192su/r92su/main.c:716:8: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
/root/rtl8192su/r92su/main.c: In function ‘r92su_stop’:
/root/rtl8192su/r92su/main.c:1566:8: warning: assignment makes pointer from integer without a cast [-Wint-conversion]
scripts/Makefile.build:303: die Regel für Ziel „/root/rtl8192su/r92su/main.o“ scheiterte
Makefile:1524: die Regel für Ziel „_module_/root/rtl8192su/r92su“ scheiterte
make[1]: Verzeichnis „/usr/src/linux-headers-4.19.42+“ wird verlassen
creating /lib/modules/4.19.42+/updates
cp: der Aufruf von stat für 'r92su/r92su.ko' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
Return to “Raspbian”
