Milliways
[Solved]:How to change Disk identifier
Sat Aug 26, 2017 11:08 am
I have routinely duplicated SD Cards for use in multiple PI.
I have processes to allocate unique hostnames.
Now that boot is based on PARTUUID it would be useful to allocate unique Disk identifier.
Is there an existing script to change Disk identifier, and the cmdline.txt and /etc/fstab entries?
Re: How to change Disk identifier
Sat Aug 26, 2017 11:36 am
I believe there is an option in the fdisk advanced menu to change the disk uuids
hommar
Sat Aug 26, 2017 12:55 pm
resize_root script change UUID
RonR
Sat Aug 26, 2017 5:54 pm
Here's a script I wrote to do that to an image file.
Usage is:
image-set-ptuuid imagefile ptuuid
ptuuid must be 8 hex digits.
Milliways
Sun Aug 27, 2017 1:31 am
Thanks for the script. I have looked through it, and it looks quite comprehensive, and would be good for modifying images to burn.
I must admit I was hoping someone had already done something that just modifies the partition table (which I should be able to do on a live Pi, like I do with hostname).
I was thinking of trying something like the following to dump the partition table, then re-write.
sfdisk --dump /dev/mmcblk0 > mmcblk0.dump
RonR
Sun Aug 27, 2017 3:12 am
The disk identifier is the Partition UUID (PTUUID displayed in blkid) and is stored just prior to the partition table in the MBR The PARTUUID's aren't actually stored anywhere, they're simply PTUUID-01 for partition 1 and PTUUID-02 for partition 2 You can change PTUUID on a live system with fdisk as I did on an image file in the script:
fdisk /dev/mmcblk0 <<EOF > /dev/null
p
x
i
0x${PTUUID}
r
p
w
EOF
Or manually run fdisk and enter p, x, I, 0x_disk_identifier, r,p,w
Similarly for /boot/cmdline.txt and /etc/fstab:
PARTUUID="$(sed -n 's|^.*PARTUUID=\(\S\+\)\s.*|\1|p' /boot/cmdline.txt)"
if [ "${PARTUUID}" != "" ]; then
  sed -i "s|PARTUUID=\S\+\s|PARTUUID=${PTUUID}-02 |" /boot/cmdline.txt
  sed -i "s|${PARTUUID:0:(${#PARTUUID} - 1)}|${PTUUID}-0|" /etc/fstab
fi
Or manually run nano on /boot/cmdline.txt and /etc/fstab and change the PARTUUID's.
RonR
Sun Aug 27, 2017 6:24 am
The attached set-diskid script will set the disk identifier (partition table UUID), cmdline.txt, and fstab on /dev/mmcblk0 to the disk identifier of your choice.
Usage:
sudo ./set-diskid diskid
diskid must be 8 hex digits.
set-diskid.zip
(635 Bytes) Downloaded 275 times
Milliways
Sun Aug 27, 2017 10:50 am
Usage:
I ran the script with
sudo set-diskid $(uuid | cut -c-8)
and it worked OK.
One minor issue, the script responded with "Re-reading the partition table failed.: Device or resource busy", but the change was successful.
Re: [Solved]:How to change Disk identifier
Sun Aug 27, 2017 5:24 pm
That message is normal and to be expected when you are changing the partition that is in use at the time. Nothing to worry about.
RonR
Sun Aug 27, 2017 11:35 pm
That message comes from fdisk, not the script, and is normal as rpdom explained.
Return to “Raspbian”
