razza30
Start at boot and restart app on exit
Fri Aug 25, 2017 5:35 pm
I am looking to set up my Pi as a dedicated camera streaming to the network. I want it to start the camera on boot and should FFmpeg or raspivid crash, then it restart the apps.
I have used a similar script before, but it just won't work here :( it starts fine but when I kill raspivid or FFMpeg, it doesn't restart.
The script (/home/pi/picamrjp.sh) as follows:
#!/bin/bash
while ! raspivid -o - -t 0 -fps 25 -b 6000000 | ffmpeg -re -f h264 -i - -vcodec copy -g 50 -f avi udp://239.0.1.23:1234
do
  sleep 1
  echo "Restarting program..."
done
I intend to call it from rc.local eventually but can't get it to work in a terminal first.
Help appreciated :-)
topguy
Re: Start at boot and restart app on exit
Fri Aug 25, 2017 6:26 pm
Using "while !" means that you still are checking the return value of the command. So if the command return 0 ( which I think is "true" in bash ) your script will end because "!0" = "not true" = "false".
Using "while (true)" ( or equivalent in bash ) and moving the command into the do/done block it should never exit the loop.
Return to “Raspbian”
