JohnBeardmore
Raspbian life cycle
Wed Jul 26, 2017 6:59 am
From the point of view of the embedded system designer, it's desirable to have an OS which can be patched to fix security issues etc, but it's also good not to have to do OS re-installs on all devices in a system too frequently, as the raw OS image needs a lot of customising.
So...
Is there a policy on how frequently there are major Raspbian releases?
Is there a policy on how long a release will be supported once superseded by the next?
Is there documentation of anticipated future releases?
Is there documentation of the release history of Raspbian?
Many thanks, J/.
Author of oBeMS open source Building energy Management System.
Automatic Meter Reading (AMR), Building Management System (BMS),
Building Energy Management System (BEMS), Infrastructure Control System (ICS).
See: http://t4sustainability.co.uk/oBeMS/
mattmiller
Re: Raspbian life cycle
Wed Jul 26, 2017 9:54 am
No
No
No
a little - not worth bothering with really
RaTTuS
Wed Jul 26, 2017 9:59 am
raspbian follow debian so that's your best bet
Covfefe
B.Goode
Wed Jul 26, 2017 10:39 am
There are Release Notes going back nearly 4 years -
http://downloads.raspberrypi.org/raspbi ... _notes.txt]
Wed Jul 26, 2017 11:37 am
Note there is a difference between Raspbian release and kernel releases. You can use more recent kernels quite happily on older Raspbian releases, so if you need a kernel security update, you will be able to get those. The latest tested kernels are made available under the usual apt-get upgrade options, or you can build you own from the Raspberry Pi github source - that's pretty easy.
JohnBeardmore
Wed Jul 26, 2017 8:31 pm
Thanks all !
This query arises because of a project we're doing with a university. They require that,
"Network security on the Pi boxes ... needs to be ... compliant with University security policy. All standard accounts (eg "pi") must be disabled, and no direct root access. All access must be via named personal accounts or non-standard generic ones if you must". So far so good.
They then say "All access must be audited by the OS on each individual box". I'm not entirely sure what they mean by this, particularly 'audited'.
They continue, "Remote access will again be via the University VPN initially using a named ... account". Fair enough.
And now the interesting bit, "OS on the Pi boxes must be kept updated and patched at all times, and the OS itself must be current and within support lifecycle". For the various versions of Raspbian that we use then, we need to know which ones the RPF regard as 'current', i.e. supported with security patches etc, and ideally, when they will cease to be 'current' so we can schedule OS upgrades in advance.
They continue "Any out-of-date OS with any known vulnerabilities connected to the University network may be disconnected without notice". Fair enough, but this action would disable the heating controls in seven buildings and a small district heating network, and knock a students PhD project on the head. It would therefore be really great, to be able to get clear and definitive answers from the RPF to the above questions.
At a minimum, it would be great if the RPF could keep a web page which lists the following for each major Raspbian release:
1) date of first distribution,
2) when it is expected to be, or was superseded, and
3) when support (particularly security patches) is expected to cease or did cease.
I don't think telling them that it's 'kinda like Debian' is going to cut it. If they ask me 'is this a supported version of OS' I need to be able to give them an accurate answer, otherwise we all look a bit mickey mouse.
Many thanks, J/.
Martin Frezman
Wed Jul 26, 2017 8:58 pm
Raspbian is basically "rolling"- meaning that if you do:
apt-get update && apt-get dist-upgrade
on a regular basis (say, weekly, via a cron job), you will always be running the latest and greatest. For example, the transition from "Wheezy" to "Jessie" was accomplished this way, by many of the folks on this board, including YHN. You don't really need to "EOL" one version and start up (i.e., install) a new version, like you do with some distros.
So, unless I've missed something, that should solve your issues.
If this post appears in the wrong forums category, my apologies.
JohnBeardmore
Thu Jul 27, 2017 1:33 am
That's interesting as an idea, but wasn't it the change from "Wheezy" to "Jessie" where they stopped reading inittab at boot time as they had a new way to start demons etc ?
While the new ways might be better, if you change something like that from a cron job, you run the risk that you'd break the system by never starting any useful processes again.
Ok, in the end you'd figure it out and fix it, but in the mean time you'd shut down seven buildings and a heat main. Could be unpopular.
For embedded applications you need stability and a chance to test the effects of upgrades.
I've heard that Ubuntu do an LTS version (Long Term Support). This appears to be available for the Pi, (see for example https://insights.ubuntu.com/2016/06/20/ ... -the-rpi2/).
It would be with great regret, but I wonder if I'd be better off using that in some ways.
Any thoughts folks ?
Cheers, J/.
Martin Frezman
Thu Jul 27, 2017 3:38 am
All that you say is correct. And I don't think that anyone actually does the "update/upgrade thing in a crontab", for just the reason you mention - that you could wake up one day running a completely different (and most likely broken) system. But it is a theoretically correct way to achieve the goal of "keeping up with everything", which seemed to be chief among your requirements.
It seems you are correct that Raspbian is not the system for your needs. Unfortunately, it is the best supported (some might say the *only* really supported) system, as far as these support forums go. My experience with the Ubuntus is that they don't work as well as Raspbian, they seem to be less stable (I think the whole LTS thing might be x86 only), and, as mentioned, aren't well supported on this forum.
But it might be the way to go for your requirements...
Thu Jul 27, 2017 4:02 am
My experience of Ubuntu is that it would be a step backwards in reliability when upgrading.
Certainly for any critical and/or remote system you don't want upgrades happening willy nilly according some cron job. Especially not dist-upgrades. Any change to any software or configuration has to be tested thoroughly first.
Although I must say Debian updates have been solid on my desktop machines for a couple of decades now.
In the extreme you will want to be building your own embedded Linux system up from scratch. Keep all the source and builds under your own control.
Another approach is to deploy your application and the libs it needs wrapped in Docker containers. A neat way of doing that is to use the services of resin.io.
runboy93
Thu Jul 27, 2017 11:28 am
Jessie not newest anymore, soon D:
Thu Jul 27, 2017 2:19 pm
How are they intending to handle the easy way anyone with access to the hardware can swap SDCards. The MAC address won't change but the stuff running on the RPi will.
So the malicious hacker does this:
1. Shut's down approved system
2. Boots up their rogue SDCard
3. Does bad stuff
4. Shuts down rogue SDCard
5. Boot up approved SDCard and walks away from a completely unaudited, uncontrolled, unlogged session.
It's much like pulling a HDD from a desktop machine which is then used for nefarious purposes.
If they really need strict control they're going to have to go with PiNet (although that still doesn't prevent the scenario above).
https://www.raspberrypi.org/blog/teaching-pinet/
This is a doctor free zone.
bensimmo
Thu Jul 27, 2017 3:39 pm
SD card problem could be address by a secure 'case' design where there is no access to it or the ports and it is not easily broken in to, etc. Just the needed cables can come out.
I noticed in the add/remove GUI updating option in the desktop it knows which are updates and which are security updates. I assume you can therefore specify apt to somehow only update security updates and not feature updates.
(Someone else may know)
This should keep it stable and stop raspbian tweaks altering things.
Maybe Raspbian isn't the OS for this situation?
Would this be something the Integrator team would look in to?
Thu Jul 27, 2017 8:37 pm
Anything via apt-get will have been thoroughly tested., so should not result in a broken system.
Anything via rpi-update will be bleeding edge, and although a bit tested, not to the level of things that make it to apt-get
Martin Frezman
Thu Jul 27, 2017 9:43 pm
Yes, usually.
But the issue here is that suppose you setup a system with the cronjob as I described earlier. Suppose further that you did this before the big Wheezy -> Jessie switchover. And suppose that you setup your system to auto-start mission critical processes via the /etc/inittab file.
Well, the next time you reboot after the big switchover, your system will be in a state that we, in the laity, would call "broken".
Note: For convenience, you might also want to assume that you setup your system to reboot automatically after each "apt-get update && apt-get dist-upgrade" operation (remember, we assumes you did this weekly via a cronjob). Now, you wake up on the critical morning and find your systems no longer working.
PeterO
Thu Jul 27, 2017 9:53 pm
Have you ever run a "mission critical system" ? Anyone who does this for real for a living would never have an automated update process installing updates onto running, live systems.
That's what testing platforms are for, for testing updates before putting them on the live production platforms. No matter how much testing the OS provider does you always test your applications on an off-line setup to check for unexpected interactions between your particular applications and the OS.
PeterO
Fri Jul 28, 2017 6:54 am
Exactly this. No way would I put auto updates on any of our production systems, or even dev/test ones. I check for new updates, test them and install manually when needed.
As for auto reboots... no. Always manual barring unexpected outages.
hippy
Fri Jul 28, 2017 10:51 am
Indeed; but isn't this exactly the problem here, the Catch-22 ?
Keeping a system up to date non-manually requires using automated means, but automated updating should not be done.
Is the answer therefore that there is no recommended way to keep a system up to date than to ensure it is kept up to date manually ?
Which, for the OP, means that if they want to keep their Pi's up to date to comply with the rules they are under, they will need to regulary check that they are up to date, then manually bring them up to date if they are not. They will need a regime to do this properly.
PeterO
Fri Jul 28, 2017 12:00 pm
The point is that if you want to run mission critical systems you need to put the resources in to processes that ensure updates are not going to break your systems. The normal way to do this is as I described earlier.
PeterO
Fri Jul 28, 2017 2:04 pm
Indeed, they will need the correct process in place. This is the cost of using computers, not just the Pi. It's why you have IT departments.
Martin Frezman
Fri Jul 28, 2017 2:35 pm
Of course, it may be the other way around. Things are the way they are because we have IT departments.
PeterO
Fri Jul 28, 2017 2:41 pm
But in this case it isn't.
PeterO
Fri Jul 28, 2017 3:10 pm
JohnBeardmore,
You will find all logins logged in /var/log/auth.log. Like so:
Jul 27 19:17:01 jhctech1 CRON[11819]: pam_unix(cron:session): session closed for user root
Jul 27 20:17:01 jhctech1 CRON[11840]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 27 20:17:01 jhctech1 CRON[11840]: pam_unix(cron:session): session closed for user root
Jul 27 21:17:01 jhctech1 CRON[11853]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 27 21:17:01 jhctech1 CRON[11853]: pam_unix(cron:session): session closed for user root
Jul 27 21:18:43 jhctech1 su[11861]: Successful su for root by dataplicity
Jul 27 21:18:43 jhctech1 su[11861]: + /dev/pts/4 dataplicity:root
Jul 27 21:18:43 jhctech1 su[11861]: pam_unix(su:session): session opened for user root by (uid=1002)
Jul 27 21:18:43 jhctech1 systemd-logind[509]: New session c1 of user root.
Jul 27 21:18:43 jhctech1 systemd: pam_unix(systemd-user:session): session opened for user root by (uid=0)
Of course if anyone can get root access to your Pi they can remove whatever they like from that log.
Meh.
Best to roll your own OS. Perhaps based on Raspbian. Then you get to dictate the patches, updates and life cycle.
"Any out-of-date OS with any known vulnerabilities connected to the University network may be disconnected without notice". ...... this action would disable the heating controls in seven buildings and a small district heating network, and knock a students PhD project on the head."
Ah, now I see the problem.
You have a mission critical system. I would call a district heating network and years of PhD work a critical mission. BUT you are running it of an un-trusted network that can be pulled out from under you at any time. Those admins are your attackers that can DOS you at a whim.
Really, you should create a network that you can trust and control yourself. Perhaps with your own WiFi access points. Perhaps using cellular connectivity.
Now a days you can even use alternative wireless technologies. For example LoRa http://www.semtech.com/wireless-rf/inte ... t-is-lora/.
LoRa would suite if you are monitoring/controlling systems up to some kilometers away and don't need huge bandwidth.
JohnBeardmore
Sat Jul 29, 2017 12:28 am
Martin:
The other reason for using Raspbian is that if you’re writing an open source thing, you want to develop and distribute it on the platform with the most users which has always predisposed me to Raspbian.
Ubuntu LTS does seem to be supported for Pis. I’ve not looked into it much, but see for example https://insights.ubuntu.com/2016/06/20/ ... -the-rpi2/ - it exists at least. I’ve not had much exposure to Ubuntu for a long time, and it never inspired me. I wouldn’t want to swap to it without good reason.
Heater:
I’d love to build a distribution from scratch, but almost nobody has that sort of spare time, and I suppose the whole idea of the open source movement is that you don’t generally have to.
We do customise Raspbian quite a bit though. Each time I do this it takes quite a few evenings of faffing about.
The Docker idea is an interesting one, but the sort of thing I’ve fallen foul of before is no longer being able to use inittab to launch demons. I doubt Docker would protect you against that sort of change, and presumably it can’t do much if different kernels are needed ?
Runboy93
:) Yes !
Dougie:
Agreee completely. This goes beyond implementing a safe system. This is about policy as much as need.
Pinet looks interesting as a tool for maintaining herds of Pis. Do you know if it’s free / open source ?
Bensimmo:
They aren’t asking for physical security, but the Pis will live in boxes full of mains wiring and relays with big yellow ‘Danger 230 Volt’ stickers on the front. Hopefully this will discourage the casually curious.
An apt-get security-update option would be nice !
Who are the Integrator team ?
Jamesh:
There is a difference between testing a new OS release, and testing all possible interactions with previous use of the OS. When they changed init to something that no longer read inittab, I’ve no doubt they tested it, but it would still break the way I was starting our various demons. Martin has explained it better than me.
PeterO:
Agreed, though it seems that IT support people who have grown up in ‘world of windows’ expect a constant stream of upgrades, necessary or not, and trust Microsoft to apply them.
Jamesh:
Yes, we have IT departments to do this sort of thing. Unfortunately it is they who are making the rule that it’s our problem.
Heater:
Yes, I had thought about LoRa, but timescales are tight, budgets are small, and the system already works over IP.
Thanks all ! J/.
JohnBeardmore
Sat Jul 29, 2017 12:47 am
My preferred approach I suspect, will be to keep upgrading Jessie until it stops being supported with security patches. So can the RPF give any indication of how long this is likely to be ?
Many thanks, J/.
Return to “Raspbian”
