Has anyone managed to use 'avconv' to encode 4k video?
Posted: Mon May 01, 2017 1:07 am
by HypnoToad
on Jessie?
I'm trying to encode some still frames taken from the camera and would like to view them on a 4k display, but I'm getting 'malloc' errors.
I've encoded videos in the past at lower resolutions without issue.
Here's the command line I'm using:
avconv -i %04d.jpg -c:v libx264 -crf 20 -preset slow -vf scale=2880:2160 c:a copy ../4k_test.mp4
and here is the error message I get:
x264 [error]: malloc of size 19779248 failedme=10000000000.00 bitrate=   0.0kbits/s
Video encoding failed
Killed
Is there a way of getting this to work?
Re: Has anyone managed to use 'avconv' to encode 4k video?
Posted: Tue May 02, 2017 8:52 am
by jamesh
Hmm , a 19MB allocation doesn't seem too bad, but it depends what has already been allocated. Some sort of swap space would help, but it would be quite slow.
Posted: Wed May 10, 2017 12:15 am
by HypnoToad
Thanks, I'll try setting up a swap file and see if I still get the same problem.
