SteveSpencer
FAT32 partition size change
Thu Apr 13, 2017 8:11 am
I see in the newest release of Raspbian (2017-04-10) that the FAT32 partition has changed size.
Is there a particular reason for this?
Steve S
No, I can't think of anything funny that won't offend someone if they want it to...
hommar
Re: FAT32 partition size change
Thu Apr 13, 2017 4:09 pm
The left hand doesn't know what the right hand is doing
ShiftPlusOne
Thu Apr 13, 2017 4:33 pm
To reduce the size a little. Why?
hommar
Thu Apr 13, 2017 9:34 pm
ShiftPlusOne wrote:To reduce the size a little. Why?
Script building was changed:
Old script:
`expr $BOOT_SIZE \* 3`M
i.e. size all files on Mbytes on /boot *3
New script:
$((BOOT_SIZE * 2 /512))
i.e. size all files on bytes on /boot *2
PS old script did not take into account small files
SteveSpencer
Tue Apr 18, 2017 8:42 am
No just idle curiosity. I have scripts that I used to modify the root fs of the img files once downloaded and unzipped.
They stopped working because I had hard-coded the offset. I now do things properly by digging out the actual size, and everything works as it used to.
It is a shame really that the full version is slightly too large for most 4GB cards, as they are convenient for creating boot/root images where the boot stays on the SD, and the root is on a USB drive (not all Pi models, of course, support boot from USB).
Still, no real harm done, and firing on both cylinders again :)
Steve S
ShiftPlusOne
Tue Apr 18, 2017 8:55 am
SteveSpencer wrote:They stopped working because I had hard-coded the offset. I now do things properly by digging out the actual size, and everything works as it used to.
Ah, I am surprised it worked for so long, given that the size of the partition was always calculated from the size of the files.
SteveSpencer wrote:It is a shame really that the full version is slightly too large for most 4GB cards, as they are convenient for creating boot/root images where the boot stays on the SD, and the root is on a USB drive (not all Pi models, of course, support boot from USB).
You should be able to just have bootcode.bin on the SD card, but boot the rest off USB, regardless of the pi model. If that doesn't work, NOOBS lite 2.4 can install rootfs to USB and keep boot on the sd card, which should work well on 4GB cards.
Martin Frezman
Tue Apr 18, 2017 9:10 am
Where would I read more about that?
I always assumed that one has to have to have all of the usual /boot stuff on the SD card - including the kernel, the two *.txt files and all the overlays stuff. I'm guessing that you can redirect where it finds the kernel via config.txt, and that that would also pull in the overlays (from wherever the kernel is), but wouldn't config.txt itself still have to be on the SD card? (See footnotes).
Footnotes:
1) Not that any of this really matters much from a space conservation point of view, given that the size of all the files involved is so small (it's measured in those ancient units that used to matter so much: megabytes).
2) Also, once booted up, the SD card can be removed from the drive. The system doesn't access the SD card once it has booted.
If this post appears in the wrong forums category, my apologies.
ShiftPlusOne
Tue Apr 18, 2017 9:15 am
Martin Frezman wrote:Where would I read more about that?
A little dated now, but the basic information is right https://www.raspberrypi.org/blog/pi-3-b ... rage-boot/
Martin Frezman
Tue Apr 18, 2017 9:38 am
I think you mis-read my question. That URL is about "pure USB booting" which, although fashionable, is not what we were talking about.
The poster to whom I was responding (it may have been you; I can't check that right now, because I am writing this) said that you needed to put bootcode.bin (only) on the SD card. In a "pure USB boot", you don't need to put anything on the SD card.
So, to rephrase my question: Is it possible to do a hybrid boot (i.e., booting from the SD card for the /boot stuff, but with rootfs on USB) with only one file (bootcode.bin) on the SD card? (Or, as I always believed, do you still need the full coterie of /boot stuff to be on the SD card?)
ShiftPlusOne
Tue Apr 18, 2017 11:06 am
Martin Frezman wrote: I think you mis-read my question.
I think you haven't read the article. It also talks about only having bootcode.bin on the SD card.
Martin Frezman
Tue Apr 18, 2017 11:20 am
I guess it is a case of tl;dr.
It'd be nice if you could just answer the question here. I'd be much obliged.
Return to “Raspbian”
