sylvaing26
xtables GeoIP and kernel update
Tue Apr 11, 2017 3:18 pm
sorry for my bad english...
Since I've upgraded my pi to the last kernel, I'm unable to reinstall Geoip
Or, for the previous version, it work as perfection.
This is my steps :
sudo apt-get install libncurses5-dev
sudo wget https://raw.githubusercontent.com/notro ... rpi-source -O /usr/bin/rpi-source && sudo chmod +x /usr/bin/rpi-source && /usr/bin/rpi-source -q --tag-update
sudo rpi-source
sudo apt-get install git autoconf automake libtool xutils-dev
git clone git://git.code.sf.net/p/xtables-addons/xtables-addons
cd xtables-addons
libtoolize --force
aclocal
./autogen.sh
autoheader
autoconf
./configure
sudo make install
sudo depmod
But with the kernel 4.9.20-v7+ they doesn't work
Xtables work but the xt_geoip module is not loaded
Do you have the same issue ?
Many thanks
topguy
Re: xtables GeoIP and kernel update
Wed Apr 12, 2017 1:42 pm
With a new kernel, you will have to rebuild and reinstall the kernel module I guess.. or have you already done that with no errors and the module is still not loaded ?
What does "modprobe xt_geoip" say ?
sylvaing26
Wed Apr 12, 2017 1:45 pm
Yes of course
With the previous version it's ok.
But with 4.9.20-v7+, it doesn't work. I have no error during the compilation and the installation...
sylvaing26
Wed Apr 12, 2017 1:48 pm
topguy wrote: What does "modprobe xt_geoip" say ?
He say "FATAL: Module xt_geoip not found"
My module is located in /lib/modules/4.9.20-v7+/extra/xt_geoip.ko
topguy
Wed Apr 12, 2017 1:50 pm
I saw a tip suggestion "depmod -a" ( https://bbs.archlinux.org/viewtopic.php?id=195565 )
sylvaing26
Wed Apr 12, 2017 2:22 pm
It doesn't work
I've just upgraded the kernel to 4.9.21
And it work now...
I think is a bug the linux kernel source installed with rpi-source beacouse in my /lib/modules/4.9.20-v7+/ folder, i haven't the simlinks to "build" and "source" linux folder.
Return to “Raspbian”
