dcaccount
Client email to send emails from command line
Sat Mar 25, 2017 9:50 pm
Can you please advise a client email to send emails from command line without installing any heavy server on my Raspbian Jessie light?
I simply need it to send me reports on the status of the server.
Thank you so much, daniele
Re: Client email to send emails from command line
Sat Mar 25, 2017 10:05 pm
sudo apt-get install mailtools
echo 'Test stuff' | mailx -s 'Test email' someone@example.co.uk
My system has postfix configured and running, you may need that to act as a MTA relay.
This is a doctor free zone.
dcaccount
Sat Mar 25, 2017 10:07 pm
DougieLawson wrote:sudo apt-get install mailtools
Thanks, is it a client or a mail server?
Sat Mar 25, 2017 10:08 pm
Eh?
dcaccount
Sat Mar 25, 2017 10:14 pm
I mean, does it install a mail server or is it just a SMTP client?
I am looking for an application with no impact on the system load,
Sat Mar 25, 2017 10:20 pm
mailtools gives you the mail and mailx commands, nothing more.
dcaccount
Sat Mar 25, 2017 10:21 pm
DougieLawson wrote:mailtools gives you the mail and mailx commands, nothing more.
So it does not install anything running continuously?
Sat Mar 25, 2017 10:25 pm
You won't get a long running mail daemon until you install & configure postfix or sendmail (or equivalent). I like postfix because it's easy to configure (unlike sendmail) and it just chuggs along using minimal resources.
dcaccount
Sat Mar 25, 2017 10:28 pm
Clear, thanks
pcmanbob
Sun Mar 26, 2017 9:40 am
Hi.
If you are happy using a gmail account ( I set one up specifically for my Pi )
then you can use ssmtp and mailutils.
mailutils will allow you to send attached file with your mail.
dcaccount
Sun Mar 26, 2017 10:49 am
pcmanbob wrote:Hi.
Hi is ssmtp already installed in Jessie light or has to be installed?
pcmanbob
Sun Mar 26, 2017 11:07 am
No you have to install both.
sudo apt-get install ssmtp
sudo apt-get install mailutils
if you want help setting it up just ask.
dcaccount
Sun Mar 26, 2017 11:35 am
Clear, thanks for helping, daniele
bonzadog
Mon Jan 01, 2018 3:29 pm
1.1.2018
RPI 3 using the latest Stretch updates
I installed ssmtp and mailutil and set the conf file - see below.
I keep getting mail: cannot send message: Process exited with a non-zero status
I even changed gmail to "accept less secure applications" but still cannot send the email
I can not seem to find a log file but I do get a dead.letter file
Any further help on this?????
ssmtp.conf contents:
# Config file for sSMTP sendmail
# The person who gets all mail for userids < 1000
# Make this empty to disable rewriting.
#root=postmaster
root=
# The place where the mail goes. The actual machine name is required no
# MX records are consulted. Commonly mailhosts are named mail.domain.com
#mailhub=smtp.gmail.com:587
# Where will the mail seem to come from?
#rewriteDomain=
# The full hostname
hostname=host2
# Are users allowed to set their own From: address?
# YES - Allow the user to specify their own From: address
# NO - Use the system generated From: address
#FromLineOverride=YES
AuthUser=me@gmail.com
AuthPass=mypw
UseSTARTTLS=YES
pcmanbob
Mon Jan 01, 2018 3:45 pm
Looking at your configure info.
You are missing the line UseTLS=YES
This is my config file with your info in it for account etc.
root=me@gmail.com
#mailhub=mail
AuthPass=mypw
UseTLS=YES
UseSTARTTLS=YES
rewriteDomain=gmail.com
# The full hostname
hostname=host2
FromLineOverride=yes
also worth logging in to gmail from web browser and see if the is an email in there alerting you to a new device using your account yet another new security feature of gmail.
sparkie777
Mon Jan 01, 2018 4:12 pm
anybody who needs a really simple and secure relay-only mail transport agent?
then you want to install:
apt install nullmailer
probably the most lightweight SMTP server ever :-)
it provides a 'sendmail'-compatible command line interface though.
An example how to send an email from the shell command line:
sendmail -oi -f aaa@domain1.com bbb@domain2.com << !
To: ddd@domain4.com
Subject: test
mail body data
bonzadog
Tue Jan 02, 2018 1:18 pm
root=me@gmail.com
#mailhub=mail
AuthPass=mypw
UseTLS=YES
UseSTARTTLS=YES
# The full hostname
hostname=host2
2.1.2018
Firstly many thanks for your reply.
I copied your conf file into mine and changed the gmail values to my name + PW but am still getting the same error.
So there seem still to be a gmail sign-on problem - even with my google set to less secure applications.
Logging in to gmail with my PW and got signed on but nothing in my input box.
There is nothing in /var/log/mail.log
So now I am really stuck.
BD
pcmanbob
Tue Jan 02, 2018 1:39 pm
OK one last thing to check your gmail password must only contain letters a-z upper and lower case and numbers 0-9.
you must no use any special characters ssmtp does not send them correctly.
I know gmail still works with ssmtp as I have 2 pis sending emails daily and a zero that send me its IP every time it boots all this is on 2 different gmail accounts, so there must be an error in your set up.
bonzadog
Tue Jan 02, 2018 8:44 pm
Ah, there we have it. My password does contain special characters ...
I'll create a new email address and a new password.
I wonder would work using a different provider than Gmail.
Many thanks
BD
pcmanbob
Wed Jan 03, 2018 1:11 am
Yes the Gmail accounts I used for my pi's I set up special just for them using long random letter/number passwords but without any special characters.
People have asked about using other email providers but I have never tried you would need to be able to find all the relevant settings to enter in to the config file.
bonzadog
Thu Jan 04, 2018 8:55 am
After creating a new account with a password in the form of abcd1234
and a password of type efgh1234 and allow the new account to use less than secure apps
I am still getting the "..exit with non zero code...." and an error in the /mail/log to that effect.
I wonder if postfix would be a better solution I would like to be able to receive mails too.
I'll probably need help in setting postfix up since I have not much experience in setting up emails.
Thu Jan 04, 2018 10:10 am
I'm a fan of postfix, it's easy to install and the configuration choices (during installation) suit most folks basic needs.
pcmanbob
Thu Jan 04, 2018 1:38 pm
If you want to receive mails as well then ssmtp is not what you need its only for sending.
RDK
Tue Aug 13, 2019 5:48 am
I'm also trying, without success, to set up my Pi (V3 running Stretch) to send me a message once a day. I have basically followed this procedure:
sudo nano /etc/ssmtp/ssmtp.conf
Here is my conf file:
root=postmaster
#rewriteDomain=
# The full hostname
hostname=MyPi
AuthUser=Me.Pi@gmail.com
# only nimbers and/or letters, no special characters
AuthPass=1234abcd
UseSTARTTLS=YES
UseTLS=YES
Debug=YES
I run this command line :
echo "Hello world email body" | mail -s "Test Subject" me@hotmail.com
and I get this error message:
I have enabled the G-Mail option to allow "less secure apps"
My system is a Raspberry Pi V3 running Stretch, recently updated/upgraded.
I see that I'm not the only one having this issue, I hope someone can help.....RDK
Return to “Raspbian”
