rafaelramos
Unable to connect to mirrordirector.raspbian.org:http:
Fri Feb 24, 2017 2:32 pm
Error in "mirror.nbtelecom.com.br"
mahjongg
Re: Error in mirror mirror.nbtelecom.com.br
Fri Feb 24, 2017 9:17 pm
You have a list with mirrors in a text file, you can edit out this particular mirror if it bothers you.
rafaelramos
Sun Feb 26, 2017 2:11 am
Where is this text file?
plugwash
Sun Feb 26, 2017 2:41 am
Can you please tell me what country you are in and what ISP you are using?
cjan
Sun Feb 26, 2017 7:06 am
got this error too
http://mirrordirector.raspbian.org jessie Release.gpg
Sun Feb 26, 2017 9:05 am
I hit an error today when updating my Pis. It looks like apt is trying to use IPv6 which doesn't work with my ISP (Virgin Media). I forced apt to use IPv4 and all was good.
Sun Feb 26, 2017 12:26 pm
rpdom wrote:I hit an error today when updating my Pis. It looks like apt is trying to use IPv6 which doesn't work with my ISP (Virgin Media). I forced apt to use IPv4 and all was good.
You can get IPv6 working in ten minutes from now.
https://tunnelbroker.net/new_tunnel.php
This is a doctor free zone.
Sun Feb 26, 2017 12:50 pm
I will upgrade to IPv6 when it is globally accepted. I have no interest in hacks for now.
Sun Feb 26, 2017 1:48 pm
rpdom wrote: I will upgrade to IPv6 when it is globally accepted. I have no interest in hacks for now.
It's fairly well used, it's been available in the wild for 21 years. Hurricane Electric isn't a hack, it's just a useful way to get IPv6 when your ISP (like mine) is still living in the 20th century.
IPv6 will suddenly become the fashionable feature very soon as the IPv4 addresses are already exhausted and NAT or CG-NAT is an absolute stinking pile of hackage.
gmc
Sun Feb 26, 2017 2:38 pm
Also having problems connecting.
W: Failed to fetch http://mirrordirector.raspbian.org/raspbian/dists/jessie/Release.gpg  Cannot initiate the connection to mirrordirector.raspbian.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 2a00:1098:0:80:1000:75:0:3 80]
Do we have to switch to IPv6 to get this working?
Update: A quick google:
apt-get -o Acquire::ForceIPv4=true update
botura
Re: ...
Sun Mar 05, 2017 3:07 pm
This mirror is still not working... impossible to update raspberry...
Anyway I can remove this mirror from my system?
I´m in Brazil.
rafaelramos
Re: ...
Fri Mar 10, 2017 2:11 pm
botura wrote:This mirror is still not working... impossible to update raspberry...
I´m in Brazil.
@botura,
I'm in Brazil, too.
I solved this issue with this:
1 - edit the file:
/etc/apt/sources.list
2 - remove the line:
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
3 - add the line:
deb ftp://raspbian.c3sl.ufpr.br/raspbian/raspbian/ jessie main contrib non-free rpi
Raspbian is now updating correctly in Brazil and with great speed!
ktb
Re: Unable to connect to mirrordirector.raspbian.org:http:
Fri Mar 10, 2017 2:59 pm
Yeah, I switched mirrordirector to archive until the mirroring issues get worked out. It has still been a problem for me here in the USA.
NB_Noc
Wed Mar 15, 2017 4:54 pm
The URL of NB Telecom RaspiberryPI Mirror has some capital letters in URL. We create a link to offer lowcase URL now. Please try again!
Wed Mar 15, 2017 5:34 pm
NB_Noc wrote:The URL of NB Telecom RaspiberryPI Mirror has some capital letters in URL. We create a link to offer lowcase URL now. Please try again!
Upper/lower case between https:// or http:// and the first slash isn't a problem.
so https://www.raspberrypi.org/ is identical to https://WWW.RASPBERRYPI.ORG/ and is identical to https://www.RaspberryPi.org/ it's only the sub-directories beyond that that are case sensitive.
Return to “Raspbian”
